High-mileage synthetic oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Jun 7, 2020.
  1. Jun 7, 2020 at 9:05 AM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Any one using high-mileage synthetic oil ? If so what results have you noticed ? Would you recommend it ? If so why ? Any experiences and or links appreciated.. I have 134000 and using Synthetic every 5K - runs great - seen 2 B a leak in the right rear corner of the head gasket. Thanks in advance.
  2. Jun 7, 2020 at 11:27 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Take a look here.
    https://www.tacomaworld.com/threads/switching-to-full-synthetic-at-130k.669573/#post-23500439
    Also are actually referring to the Valve Cover Gasket?
    It’s kind of common for them to leak in earlier Tacomas.
    I have not seen many reports of it on later years.
    I personally run Conventional or High Mileage Synthetic Blend.
    But it just depends on the price. Never run full Synthetic that I know of.
    As I usually use the coupon for Firestone or Free Service Tire (Goodyear)
    Yeah, I know.
    I should do it myself.
    But for about $27, I don’t have to “get dirty” and “clean up”
  3. Jun 7, 2020 at 11:58 AM
    george3
    New Jersey
    Thanks - Didn't cost you much to keep clean !
  4. Jun 7, 2020 at 12:08 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Most high-mileage motor oil, whether synthetic or conventional, have additional seal conditioners that could help prevent leaks from starting. Additionally, depending on the manufacturer, they also can have more detergents designed to clean out sludge inside the engine, plus other additives meant to reduce wear.
    Yes, I would recommend high mileage oils on engines with 100K+ miles. You will likely not see immediate results but the potential benefits are worth the extra $2-3 per jug. Over on the oil analysis thread, you can see that high mileage oils do have more additives than the non-high mileage oils.
  5. Jun 7, 2020 at 12:17 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've used mobile1 synthetic high mileage 5-30w in my tundra for years once it passed 100k miles...never had as issue it kept the motor running still like new even after close to 300k miles. Can't beat the price either at wally world.
    SliMbo4.0 likes this.
  6. Jun 7, 2020 at 1:03 PM
    george3
    New Jersey
    Thanks "Over on the oil analysis thread" is that Bob the oil GuY ?
  7. Jun 7, 2020 at 1:06 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I believe the only difference between high mileage synthetic oil and synthetic oil is marketing
  8. Jun 7, 2020 at 1:08 PM
    george3
    New Jersey
    300K sounds good 2 Me ! I started using synthetic from wally world - has the same Initials -Spec's - I was there today and they were out of 5w 20 but had 5w 20 High Mileage - got me Thinking of trying the High Mileage.
  9. Jun 7, 2020 at 1:10 PM
    zoo truck
    None
    Not really. The high mileage version has a different additive package that helps keep the seals and gaskets in the engine more pliable as it ages...same with other mobile 1 synthetic versions.
    SecureIT2021 likes this.
  10. Jun 7, 2020 at 1:15 PM
    zoo truck
    None
    Don't confuse extended performance mobile 1 synthetic with high mileage. Extended performance is if you drive 25k miles a year between oil changes. High mileage is for older vehicles with more than 75k miles on the odo.
  11. Jun 7, 2020 at 1:27 PM
    george3
    New Jersey
    5k OCI 134K - Thanks.
  12. Jun 7, 2020 at 1:33 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    10k oci here with 240k+ on the odometer. I notice that if I don’t use high mileage I lose more oil between oil changes.
  13. Jun 7, 2020 at 2:07 PM
    george3
    New Jersey
    "lose more oil between oil changes." Interesting - must be working !
  14. Jun 7, 2020 at 2:10 PM
    Chuy
    Lakeside, CA
    Silver Taco
  15. Jun 7, 2020 at 3:29 PM
    george3
    New Jersey
  16. Jun 7, 2020 at 4:30 PM
    TexasWhiteIce
    Texas
    sounds like they got to you
  17. Jun 8, 2020 at 11:56 AM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    Hahahaha! Well, they must have got me too then. when I started running the high mileage synthetic on my older vehicles it significantly slowed the oil leaks so when I got my current Taco (2007) with 134,000 on it, I changed from the Mobil One Syn used by the previous owner to Mobil One High Mileage Syn.
  18. Jun 8, 2020 at 12:15 PM
    Hikerbox
    Hikerbox Well-Known Member
    2015 SR5 Access Cab
    Auto parts place across the street doesn't even carry conventional 5w-30, closest you can get is high mileage blend. I think the cost difference has gotten so low nobodys buying conventional anymore.
  19. Jun 8, 2020 at 12:35 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Mobil 1 makes so many different types now, it's getting ridiculous. The store I usually buy it from didn't have the 'advanced' synthetic last time, but had the synthetic. I asked the clerk what's the difference between synthetic and advanced synthetic? He said the label?
    TexasWhiteIce[QUOTED] likes this.
  20. Jun 8, 2020 at 1:00 PM
    TexasWhiteIce
    Texas
    ‘yeah, pretty much just the ink on the label
