High output Alternator?
Discussion in 'Lighting' started by Blackdawg, Apr 23, 2011.
  1. Sep 11, 2016 at 10:37 PM
    #41
    wildmistyrose
    wildmistyrose New Member
    1999 Tocoma 4wd
    added high power stereo system
    I am new and in need of a ho alternator between 130 to 200 amps ready to buy now 661 972 6243 joe for a 1999 toyota tacoma 4wd ex cab
  2. Aug 5, 2017 at 12:43 PM
    #42
    lostgravity
    lostgravity New Member
    Does anybody know what the specs of the stock alternators (tow vs. non-tow) are? Having trouble findings those... Thanks!
  3. Aug 5, 2017 at 12:57 PM
    #43
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    first gen is 80 amps.
    for 2nd gen
    dtaco06[QUOTED] likes this.
  4. Aug 7, 2017 at 5:21 PM
    #44
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    i have access to some of the best alts made period and only uses OEM parts unless other wise stated.
    We are currently working on a series dual alt billet case for a total of 540A at idle and will have minimal heat soak as the alt will be running nice and cool, low temp and efficient.
    He has a wide range of platforms as well, pretty much any Toyota you can think of, life time warranty on labour as well.
    BenMara likes this.
  5. Sep 7, 2017 at 12:01 PM
    #45
    01MUD.TACO.SC.V6
    01MUD.TACO.SC.V6 Well-Known Member
    Clive
    MAXWELL AFB
    01 Tacoma 4WD SR5 Supercharged
    TRD Supercharger, URD 7th Injector Kit, 2" Body Lift, Rear Manual Air Bag Suspension, Marlin Crawler Rear Bumper
    #45
  6. Sep 9, 2017 at 10:18 PM
    #46
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    cheap enough that if it breaks after warranty you can replace it.
    A good quality alternator that uses OEM parts will cost you double that
    #46
  7. Oct 23, 2017 at 10:11 AM
    #47
    Kadowampus
    Kadowampus Well-Known Member
    Ventura County
    2011 SR5 4x4 extended cab
    front & rear 5100 Bilstein shocks, eibach/toytec coils, .5" lean spacer, 2" AAL, Derped wheels, Smittybuilt 8000, Technora line, Factor 55 Flatlink, ARB Bumper, Curt receiver, frontrunner load bars, eezi-awn 1600, Lightforce lights, pop-n-lock
    What he said :popcorn:
  8. Oct 26, 2017 at 5:51 PM
    #48
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    ill ask
  9. Nov 23, 2019 at 12:02 AM
    #49
    Colt.111
    Colt.111 Active Member
    Colton
    MD
    2008 trd pro
    2 in leveling kit,16x8 fuel anzas, 265x75x16 bfg ko2’s
    So my 08 trd would be able to power a 2000 w rms amp on a stock alt and not ruin the battery or alt?
  10. Nov 27, 2019 at 2:08 PM
    #50
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Are you going to be using all 2000 Watts all the time? Assuming no thermal/electrical losses that is 166.7 Amps.
    With Audio even cranked you never run at full wattage all the time so you might be fine without any crazy upgrades.
  11. Nov 27, 2019 at 9:08 PM
    #51
    Colt.111
    Colton
    MD
    2008 trd pro
    As of right now I’m running a 1300w peak amp. I’m using like a steady 900. I have 0 gauge wire. It dims every light on the truck pretty bad. For some reason it keeps on melting the wire and the fuse housing too. Makes no sense. Not like I can go any bigger than 0 gauge wire. Thanks for the reply tho.
  12. Nov 28, 2019 at 9:45 AM
    #52
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah you can. 0/4 is the largest.
    If your willing every light then no your alt isn't big enough. You also should do the big 3 upgrade.
    You should also be aware of hearing damage you are causing yourself. Go easy on the volume. Hearing damage is not reversible, it's permanent.
    SnowroxKT likes this.
  13. Nov 28, 2019 at 9:56 AM
    #53
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    @Blackdawg I see you're running a GM alt... At least you were 6 years ago, when this thread was made lol...
    What are your thoughts between the GM alt and the Grand Vitara alt people are talking about now? I'm going to do one of these soon. Trying to get some thoughts before I decide which way to go.
  14. Nov 28, 2019 at 11:59 AM
    #54
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm not familiar with that alt. Have a link?
  15. Nov 28, 2019 at 12:01 PM
    #55
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  16. Nov 28, 2019 at 12:07 PM
    #56
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cool!
    I'm sure it works fine. However it's still a denso unit so I'd guess at idle it out puts 30-40 amps max.
    That's the advantage of the GM one, it's 80-100 amps at idle.
    Both with keep everything charged just fine with you driving around a lot though. So it kind of depends on your wants/needs are.
    The GM one isn't any harder to install especially if you get the plug n play harness you can get for it now on eBay or Amazon. Just go to Ace and get a steel spacer from the bolts section, little sanding/filing/grinding it down to fit perfect and your good. Then upgrade your wiring. Easy.
    I'm sure that unit will do just fine though if you wanted it.
    #56
  17. Nov 28, 2019 at 12:15 PM
    #57
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Only reason I was thinking the Grand Vitara alt was that I really wasn't sure how much of a pain in the ass the GM one would be. Sounds like the GM alt isn't all that much harder, or costly. Maybe I need to focus more attention in that direction lol.
    #57
  18. Nov 28, 2019 at 6:26 PM
    #58
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nah it's pretty easy. And really affordable too, $135 bucks I think..not bad for 140 amps and high idle output which no "high ouput" rewound stock one will do.
