High Pitch whistle/whine when cold
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tashier, Jun 22, 2012.
  1. Jun 22, 2012 at 3:59 PM
    Tashier
    Tashier [OP] Well-Known Member
    Sean
    Beaverton, OR
    99 Tacoma V6 Limited
    Air Bar Suspension
    Well,
    I've had this problem almost since the truck was new and heck I thought I would throw it up here. It hasn't posed any issue that I know of other than being annoying.
    Basically when the truck is cold it will whistle from the engine. The pitch goes higher and lower with RPM. I thought maybe it was something in the timing belt but even after I changed the timing belt and waterpump it still did it. I'm pretty sure this is an air noise and not a belt noise as changing the belts made absolutely no difference. Almost like the intake manifold is sucking air when it's cold or something.
  2. Jun 22, 2012 at 6:40 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Did you check your vacuum lines? Kinda sounds like one popped off.
  3. Jun 22, 2012 at 11:21 PM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    Ya, I've looked all over around in there. I never found anything obvious. Such a weird deal, I should record it if I could. I swear it's gotta be the intake manifold. Then when it warms up it seals off and goes away. But, it's ran fine for the last 70,000 miles like that.
  4. Jun 22, 2012 at 11:37 PM
    UOFan
    UOFan Well-Known Member
    Bryan
    NC
    1994 Single Cab DLX, 2013 TRD Sport, 1999 Dodge 2500 360 V8
    5100 Lift + AAL
  5. Jun 23, 2012 at 9:40 AM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
  6. Nov 5, 2012 at 4:29 PM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    Man, I think I have someone's 4 runner, same v6 3400 engine, same problem. Definitely not a belt noise as I intentionally replaced ALL belts, tensioners, waterpump etc. when I did the timing belt. Same exact noise after.
  7. Nov 5, 2012 at 4:31 PM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    I guess another way to describe this noise would be like filling up a balloon and letting a little bit of air slowly leak out making a high pitch squeal. Only when it's cold. When warm, gone. Summertime, no noise ever. Been like this for over 10 years.
