Hilux 167 Snorkel for 3.4L Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by MatthewMay1, May 18, 2015.
  1. Aug 21, 2017 at 7:56 AM
    #201
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    It's probably not going to fit 'properly' - it doesn't quite fit 'properly' on the 98 I drive. It's a nice fit, but there is some gapping between the snorkel and the fender. If fit and finish are important, then save up for the Safari Snorkel. The issue here is the molded curve above the front tire. The snorkel is formed for a 'straighter' molded curve, so it doesn't fit flush against the body. It's only noticeable if you have any eye for it...
    Mechanically, it fits just fine. Once fastened to the body/A-pillar it is securely attached.
    ProTip: Use a brand new hole saw blade for this cut
    Any body try using a metal nibbler to cut this large hole?
  2. Aug 22, 2017 at 1:56 AM
    #202
    MatthewMay1
    MatthewMay1 [OP] I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    What he said ^ I haven't seen it installed on a pre-97 that I can recall. If you think it'll work and are not afraid of a bread and butter match, I say go for it. It's not perfect on any truck I have seen. For the price difference, I was okay with the slight fitment gap. Any non-enthusiast would never notice it.
    pray4surf[QUOTED] likes this.
  3. Dec 14, 2017 at 5:07 PM
    #203
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Dorkel is on order :anonymous:
    otis24, AKsavanaman and BYJOSHCOOK like this.
  4. Dec 14, 2017 at 7:28 PM
    #204
    MatthewMay1
    Matthew
    Lone Star Republic
    Finally!
  5. Dec 14, 2017 at 7:35 PM
    #205
    cbechtold
    Cory
    Pleasanton, CA
    #dorkelgang :bananadead:
  6. Dec 14, 2017 at 8:31 PM
    #206
    AKsavanaman
    AKsavanaman Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
  7. Dec 15, 2017 at 4:51 AM
    #207
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I was skeptical of installing but my buddy talked me into it and it was awesome! Just mark everything up and then drink some beer. Makes drilling all the holes easier
  8. Dec 15, 2017 at 7:01 AM
    #208
    AKsavanaman
    Lower 48 :( U.P MI
    I have no reservations with cutting into my fender... it's already got nicks and dings... cutting holes will only make it look better! I'm still LMAO at this #dorkel, I hope it catches on!
    BYJOSHCOOK[QUOTED] likes this.
  9. Dec 28, 2017 at 9:07 PM
    #209
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    I just ordered one of these, what size hole saw should I get?
  10. Dec 28, 2017 at 9:13 PM
    #210
    cbechtold
    Cory
    Pleasanton, CA
    I used a 3.5" hole saw. If you have a Dremel available to you, you'll want it. Makes it easier enlarge the hole a little bit so the snorkel fits on easily. Also nice since it can clean the holes up nicely.
  11. Feb 9, 2018 at 1:47 PM
    #211
    Skeletoy
    Skeletoy Well-Known Member
    RDM, OR
    Stock 3rd gen, Samurai
    Had to turn my snorkel head around backwards because of the blizzard we're experiencing here in MT. I even had to take it off last night and shake the snow out of the head before starting it. I ordered one of these on Ebay, we'll see if it fits ok.
    edit, i ordered both the 3.5" and 3". I'm guessing the 3.5" will be closer
    https://www.ebay.com/itm/391912949316
  12. Feb 9, 2018 at 3:02 PM
    #212
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    I've been
    I've been rocking the head on mine turned inwards at 90 degrees for a few months now. I had one of these Outerwears pre-filters on for quite a while and it worked well. After the first freezing rain I kept hearing a hissing sound and couldn't figure out where it was coming from until I realized the prefilter was iced over and it was sucking air in through a little gap in the corner of the snorkel head lol.
  13. Feb 11, 2018 at 4:22 PM
    #213
    MatthewMay1
    Matthew
    Lone Star Republic
    While I was in Australia, I saw a ton of snorkels with these types of heads on them. Be sure to let us know how it works and I might pick one up
  14. Feb 11, 2018 at 10:52 PM
    #214
    Skeletoy
    RDM, OR
    Ebay said they shipped today from China....so maybe sometime in March i'll see them lol
  15. Feb 12, 2018 at 9:05 AM
    #215
    MatthewMay1
    Matthew
    Lone Star Republic
    You could be surprised!
  16. Feb 13, 2018 at 9:46 AM
    #216
    Skeletoy
    RDM, OR
    Stumbled across this in the 2nd Gen section (blasphemy!)
    https://www.tacomaworld.com/threads/inesshell-bs-and-lazy-af-build.503871/page-13#post-16139632
    Looks like it comes in a 4" flavor and it needs to be adapted with some rubber/silicone pipe couplers.
    Kinda spendy on Ebay:
    https://www.ebay.com/itm/Replaces-4...871755?hash=item336fe8fb4b:g:8aoAAOSw8XBZrtsI
    Looks like it has some type of angled blades on the inside to kick debris and maybe water out the back of it. I noticed that the Ebay one I bought looks to have a similar feature. I'll know for sure when it arrives.
    anyway, one more option for those of us who have to deal with snow all the time.
  17. Feb 24, 2018 at 4:24 PM
    #217
    Skeletoy
    RDM, OR
    Well the less than reliable ebay seller in China sent me a bag of iphone parts instead of the snorkel hats!!!!!!!!!!!!!!!!
    Guess i'll save up for the enginaire one.
  18. Feb 24, 2018 at 7:50 PM
    #218
    MatthewMay1
    Matthew
    Lone Star Republic
    Hahahaha, that's unfortunate for you but hilarious for me!
  19. Feb 24, 2018 at 9:51 PM
    #219
    Skeletoy
    RDM, OR
    Me and mystery EBay seller man came to the agreement he would re-ship the snorkel hats if I gave him a 5-star when i received them.....
    we shall see lol
  20. Mar 7, 2018 at 1:51 PM
    #220
    mst7107
    mst7107 Member
    Anchorage, AK
    1995.5 Tacoma 3.4L 4x4
    16" SCS SR8's 33" Toyo Open Country M/T Leer XL100 camper shell Arkon tablet mount/tablet running torque pro OME Lift
    Awesome write up! Just bought one on Amazon yesterday for $145. I'm thinking about also getting a set of Bushwacker fender flares but has anyone had any issues with the fitment of the extended flares in addition to the snorkel? I've heard from one person that they were able to make it fit with some minor trimming of the flare but that was the only person I've heard every try it and they didn't have pictures of the end result.
    Here is a picture from the Bushwacker website of the flares I'm looking to get.
    Thank in advance!
