Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. May 21, 2018 at 3:27 AM
    #2341
    Quadabaum
    Quadabaum Well-Known Member
    2017 Tacoma TRD OR 4x4 DCSB
    265/75R16 Falkens, ADS 2.5" Stage 3 Suspension, Go Fast Camper
    I dont think you will have troubles running it off of the 12v, these fridges dont pull a lot of amps. My dometic pull 7.5amps when running. None of the stock 12V outlets are on when the truck is off though, unless you wire it to be constant 12V. I did 1 trip like this and ended up cranking the truck every 3-4hrs through the night, not good for sleep. They are pretty good at holding temp but I had temp sensitive food in my fridge that I wanted to be sure didnt spoil.
    YOTA 4X4[QUOTED] likes this.
  2. May 21, 2018 at 3:37 AM
    #2342
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    You know that didn’t even occur to me. Maybe I’ll just run the ARB across the back seat and pop a hole in my fire wall and rig it right “for now” you are right I don’t want to have to worry about the fridge being on. Thank you!
    (Anyone know of an easy mod to make the 12V outlet stay on all the time) just in case?
    Just looked. The ARB site indicates that the 63qt fridge draws 0.7 - 2.3 Amps/ Hr
    Quadabaum[QUOTED] likes this.
  3. May 21, 2018 at 5:06 AM
    #2343
    unclewilson
    unclewilson Well-Known Member
    Wilson
    Michigan or Colorado
    Several
    Lots
  4. May 21, 2018 at 5:23 AM
    #2344
    I_eat_tacos
    I_eat_tacos Well-Known Member
    whitetaco16 likes this.
  5. May 21, 2018 at 6:09 AM
    #2345
    whitetaco16
    whitetaco16 Well-Known Member
    James
    Central NC
    2016 TRD OR Access Cab Long Bed
    Dobinson's 2.5, RCI Sliders, Mobtown Recovery Bar and Front Skid, 4.88's and Extremeaire Magnum
    The clamps are adjustable due to the bolt hole to the T-Nut channel being slotted if that makes sense. I have mine positioned so once everything is tightened there is about a 1/4" gap between the top of the clamp and the bottom of the bracket on the GFC frame. Some gap is necessary since the clamping action is compressing the bulb seal. That said, from the top of the bedrail to the bottom of the clamp mine measures approximately 3.75 inches. If they were at the lowest position which would allow the supplied bolts to reach, it would increase the depth to just over 4 inches. Unless your drawers are going to be over 15" you will be fine.
  6. May 21, 2018 at 8:17 AM
    #2346
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    @YOTA 4X4 I'm in a similar boat for the upcoming holiday weekend. I ran a dedicated 12V outlet w/ 12ga wire to the back seat for my fridge, but once it moves to the bed I'm sure there will still be uses for it.
    Instead of going through a firewall grommet I found a floor plug behind the drivers seat and then routed the wire under the door sill panels. Easier area to access and less leak prone than the firewall grommets.
    YOTA 4X4 likes this.
  7. May 21, 2018 at 8:23 AM
    #2347
    YOTA 4X4
    Great idea! I’ll look there and see what i can find. I just built a quick platform to level everything this morning and give me something to secure the fridge down too. I guess you’re right. It won’t hurt to have an outlet there too... you never know. Thanks a million!!!!
  8. May 21, 2018 at 8:40 AM
    #2348
    henryrose
    henryrose Well-Known Member
    2016 SR5 DCLB Black
    +1 for pictures of light switch location!
  9. May 21, 2018 at 9:53 AM
    #2349
    tjhaugh
    tjhaugh Member
    @Yota4x4 and @whitetaco16, thank you! Very helpful. Seeing the clamps in relation to the channels on the bed was the right reference. I'd like drawers a little deeper than the Decked system, I think, but it looks like there is plenty of room. Much appreciated.
  10. May 21, 2018 at 2:11 PM
    #2350
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    https://www.tacomaworld.com/threads/always-on-12v-power-outlet-mod-3rd-gen.432620/
    Once you follow @catware's directions, you can tap the socket and run an outlet into the back of the center console. Likewise you can do an inverter on anytime mod as well.
    https://www.tacomaworld.com/threads/3rd-gen-ac-outlet-in-cab-and-400w-anytime.505598/
    @djembefola
    catware and YOTA 4X4[QUOTED] like this.
  11. May 21, 2018 at 6:59 PM
    #2351
    TacomArizona
    TacomArizona Well-Known Member
    15' ACOR 2wd 4.0
    Trade war on hold, no steel tariff quite yet ?!
    YOTA 4X4 and PB FAB like this.
  12. May 21, 2018 at 9:19 PM
    #2352
    trouttaco
    trouttaco Well-Known Member
    Portland, Oregon
    Does anyone know if it would be possible to leave one cushion out with the top down and also run the fan? I am curious if this would be a good option for keeping good air flow and ventilation for my dog in the back while while im Running errands and whatnot.
    rooster32 likes this.
  13. May 22, 2018 at 5:29 AM
    #2353
    whitetaco16
    James
    Central NC
    True enough but the price on steel buildings has increased by 38% since January 1. Ask me how I know..........
    Willbeck likes this.
  14. May 22, 2018 at 5:43 AM
    #2354
    unclewilson
    Wilson
    Several
    Lots
    "How do you know?" :popcorn:
  15. May 22, 2018 at 9:00 AM
    #2355
    gman36
    gman36 Well-Known Member
    San Diego, CA
    2018 Cement DCSB OR
    I was at overland expo to check out the campers. They looked as good in real life as they do in the glamour shots. I know glamour shots can be deceiving sometimes. The quality is excellent.
    The lighting package has a remote switch to turn them on/off. There is no fixed switch location, so its up to you to place it wherever, or keep it in your pocket. I didn't get to see the lights in action since it was super bright out.
  16. May 22, 2018 at 9:53 AM
    #2356
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    l
    Remote as in wireless?
    gman36[QUOTED] likes this.
  17. May 22, 2018 at 10:07 AM
    #2357
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    No no no no. It's like this:
    But when you're in camp you can stick it in your pocket.....
  18. May 22, 2018 at 11:22 AM
    #2358
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Just popped in to say the same thing. VERY good dust seal. I've never seen anything keep out dust that well haha.
  19. May 22, 2018 at 11:43 AM
    #2359
    Asphaltcowboychip
    Asphaltcowboychip Well-Known Member
    @moisesonsurez
    2017 Tacoma +3.5 LT
    A lil this a lil that.
    How do you find out where you are in the building etc. I sent a check 4/4/18 and only got an email that says they received payment. The couple emails I've sent haven't been responded to? Didn't wanna bug but have vacation scheduled.
  20. May 22, 2018 at 12:30 PM
    #2360
    whitetaco16
    James
    Central NC
    Look at post #2862, the third picture down is from the passenger side showing the lower light. The switch is a dimmer which is mounted on the driver side and if you look closely, you can see the round knob. You will also see some excess wire coiled and tied up in the corner. The switch itself is attached with stick tape. If you want it somewhere else, cut the wire tie and locate it where you want it as long as the wire harness reaches. There is 3-4 feet of extra wire.
    The lights in the tent have the dimmer switch located at the lower/forward end of each fixture. There is a USB plug at each end of each fixture. The harness for all the lighting comes down in the front driver side corner. There is a master on/off switch which shuts power off to all the lights. This is good in case you forget the tent lights and have closed the tent.
    Willbeck and ace7196 like this.
