Houston BS Thread
Discussion in 'Texas' started by wrxRome, Apr 12, 2012.
Thread Status:
Not open for further replies.
  1. Aug 3, 2013 at 10:39 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Which grill are you cutting up? 05-10 or 11?
  2. Aug 3, 2013 at 10:45 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    2010
  3. Aug 3, 2013 at 10:46 AM
    BulletToothTony
    Screw the fiberglass you don't need it.
  4. Aug 3, 2013 at 10:59 AM
    BulletToothTony
  5. Aug 3, 2013 at 11:02 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i worked on her S2000 before...[​IMG]
  6. Aug 3, 2013 at 11:16 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    No number:eek:....her names Mary by the way...
  7. Aug 3, 2013 at 11:56 AM
    Biscuits
  8. Aug 3, 2013 at 12:20 PM
    Biscuits
    Elbows too pointy. Teef too white. 2/10.
  9. Aug 3, 2013 at 12:39 PM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Want a tire that has a lot of road noise!
  10. Aug 3, 2013 at 12:43 PM
    BulletToothTony
    Those mud grapplers suck... I couldn't talk on the phone or listen to my radio at over 70...
  11. Aug 3, 2013 at 12:54 PM
    Biscuits
    Wut.
    Don't think I've ever seen THAT requirement in a tire before.
  12. Aug 3, 2013 at 2:56 PM
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
  13. Aug 3, 2013 at 3:03 PM
    BulletToothTony
  14. Aug 3, 2013 at 3:16 PM
    cj.ainsworth77
    cj.ainsworth77 Well-Known Member
    CJ
    Texas
    02 Reg Cab 2wd
    Wouldn't it be best to buy an entire wrecked truck and swap everything over? Well I'd buy new hubs anyway but besides that I would think you'd be money ahead that way
  15. Aug 3, 2013 at 3:19 PM
    BulletToothTony
    You bypass most of the electronic BS doing it the other way.
  16. Aug 3, 2013 at 3:25 PM
    cj.ainsworth77
    CJ
    Texas
    02 Reg Cab 2wd
    The only electronics to worry about is the vac solenoid that engages the axles right? And the light on the dash of course...
  17. Aug 3, 2013 at 3:29 PM
    BulletToothTony
  18. Aug 3, 2013 at 3:31 PM
    cj.ainsworth77
    CJ
    Texas
    02 Reg Cab 2wd
    Well damn...these things are a lot more electronic than I thought
  19. Aug 3, 2013 at 3:34 PM
    Biscuits
  20. Aug 3, 2013 at 3:38 PM
    BulletToothTony
    I'm trying to find the thread, but the was a guy that bought a used totaled 4x4 and did the swap. He said it was a pita bc he had to pull out a ton or wire harnesses and replace them with the other from the donor truck. He totally gutted his dash and alot under the hood... He said had he not scored the truck so cheap he would've done it the other way...
    Idk if you can score one cheaper then what it costs to buy ther other parts then it might be worth it. I just remember he said it was a total headache to gut both trucks and reinstall it back into one...
Thread Status:
