How have you water proofed the titanic sized gaps on front of bed...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vo0Do0, Dec 12, 2019.
  1. Dec 12, 2019 at 6:07 PM
    Vo0Do0
    Vo0Do0 [OP] Well-Known Member
    2020 VooDoo Blue Tacoma TRD Off-Road
    I am getting ready to install the Diamondback bed cover and am perplexed on what to do to seal the huge gaps on both sides of the bed at the front.
    I did try to search for this topic but was unable to find a post about it.
  2. Dec 12, 2019 at 6:10 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    While I think you can make these covers water shedding I don’t think you can really waterproof them. I’m sure some good gasket materials are available.
  3. Dec 12, 2019 at 6:11 PM
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    The ones under the bed side rails? Buy a sheet of closed cell foam and cut two large blocks from it, adhere it up under the rail in those front corners should be fairly golden after that. For the two gaps between the front rail and side rail just use the provided foam squares that came with your cover (or make them yourself). Just my suggestions.
  4. Dec 12, 2019 at 6:15 PM
    Vo0Do0
    Thank you, did not know they would come with some but that would be good if they do.
  5. Dec 12, 2019 at 6:18 PM
    THE_KiRRAx
    Tampa, Florida
    Some covers do, some don't. Most provide that little square you just take the front rail off and apply it to the ends, then reinstall. That seals up the most obvious gaps at the front. The gaps under the bed side rails are huge though, can literally poke a finger out from bed in those corners.
    Vo0Do0[QUOTED][OP] likes this.
  6. Dec 13, 2019 at 4:24 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
  7. Dec 13, 2019 at 5:25 AM
    Rparker017
    Rparker017 Well-Known Member
    2018 Tacoma TRD Pro
    ShiftSense Pro
  8. Dec 13, 2019 at 5:41 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    are you talking about the drain holes near the front corners on the floor? Those holes are there to drain any water that accumulates in the truck bed.
    I'm just trying to visualize where you are asking about. I don't have a 3rd gen.
  9. Dec 13, 2019 at 6:19 AM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    Look up under the rails toward the cab. In the 3rd gen there is a gap between the bed, and the rail that could allow water through. It certainly allows aid and light to pass.
    I do not think the 1st gens have this issue since they are a metal bed and metal rail. It may or may not exist in 2nd gens, I have not owned a 2nd nor have I laid in the bed of one looking for the gap.
    Vo0Do0[OP] and koditten[QUOTED] like this.
  10. Dec 13, 2019 at 6:22 AM
    NGA Taco
    NGA Taco New Member
    2019 Silver TRD OR 4x4
    I've had a Diamond Back for about 6 months, it's awesome! I did not seal those gaps when I first installed it and it did leak there. I used masking tape and taped around the gaps (to keep the caulk job clean) and then used clear silicone to fill the gaps. It worked and I now have no leaks. Another tip is to close everything up and look for daylight.
    radarluv likes this.
  11. Dec 13, 2019 at 6:22 AM
    koditten
    Kirk
    Central Michigan
    Thank you. I wasn't aware, as I said, I don t have a 3rd gen but will eventually. I'll have to look for some pics.
  12. Dec 13, 2019 at 6:24 AM
    savin yours
    savin yours Well-Known Member
    Bryan
    SE Tx
    2018 TRD Off Road
    I’ve had my DB for over a year. I’ve driven through rain storms and several automatic and hand washes. The amount of water that leaks in the bed is almost not enough to talk about. With the factory rubber bed mat, it stays under the mat and runs out the tailgate. Again, not an issue for me. Also, I transport some high end guns in mine(deer lease trips).
    koditten likes this.
  13. Dec 13, 2019 at 6:28 AM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Vo0Do0[OP] likes this.
  14. Dec 13, 2019 at 8:07 AM
    pdxtaco02
    pdxtaco02 Well-Known Member
    Luke
    Portland, Oregon
    2016 TRD Sport QS MT
    I have mine all sealed up from a canopy I installed.
    I just took the canopy off, so I'll take some pictures when I get home from work.
    Basically just a combination of foam fit in the gap and sealant
  15. Dec 13, 2019 at 8:36 AM
    SogBecks
    SogBecks Well-Known Member
    2018 TRD Off-Road DCSB
    OVTuned + 2" Lift + 17x9 KMC XD133 Wheels + 275/70 Firestone X/T + TRD Intake + Gibson Exhaust + N2 Designs Remote Start + MESO'd + HS AAL + Alpine Halo 9
  16. Dec 13, 2019 at 8:41 AM
    bluzharp
    bluzharp Well-Known Member
    Central AR
    19 OR DC LB Cement (the slowest color)
    Pro Suspension, Roadmaster overloads, Diamondback
    I used the Toyota plugs made for the factory tonneau. Pricey for what they are, but effective. Minor trimming is required on the bed rail covers.
  17. Dec 13, 2019 at 8:49 AM
    Joe671
    Joe671 YouTube Mechanic
    Joe
    Washington State
    2019 Tacoma TRD Off Road
    i have the cheap Tyger trifold soft tonneau cover from Amazon. Definitely see the gap up front. As much as it rains here in Washington state my bed stays fairly dry.
    edit- of course i don't have anything in the bed that i absolutely need dry.
  18. Dec 13, 2019 at 9:14 AM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    https://www.amazon.com/GREAT-STUFF-Stone-Insulating-Sealant/dp/B001AQ0FVC
    Sticks better than caulk, silicone, moldable glue, etc. I sprayed it in there and let it expand. Once expanded took a knife and shaped it. Then taped around it and sprayed it with a couple coats of plasti-dip so it looks clean. Diamondback is watertight now (I live in Oregon and truck is parked outside).
    wahoobie likes this.
  19. Dec 13, 2019 at 6:57 PM
    RichVT
    Rich
    Northern Vermont
    I knew it existed so I just had to find it again. When you go into the advanced search make sure to check the "most relevant" box instead of the default "most recent". That helps bring the older threads to the top of your search results.
    5Saints and Vo0Do0[OP] like this.
  20. Dec 13, 2019 at 7:41 PM
    Vo0Do0
