How to: Deleting ADD system
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PSU Taco85, Apr 14, 2016.
  1. Apr 26, 2017 at 11:40 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    No, Its simply making it to where the front center driveshaft doesnt spin when in 2hi. Transfer case is still selectable between 2hi 4hi n 4lo.
    Shit..... didnt realize this was from LAST april. I havnt seen a proper 2nd gen manual hub setup though.
  2. Apr 26, 2017 at 11:43 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Don't think there is one yet, but the Toyota transfer case design is pretty much unchanged. The front output shaft bearings are always bathed in oil due to their location at the bottom of the case. The only bearings that require the use of it's internal pump are the input and rear output bearings. You could run your taco like this and it'll last just as long as the rear output, maybe even longer because it is actually submerged in oil.
  3. Apr 26, 2017 at 11:54 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Nice work man!
  4. Apr 26, 2017 at 11:55 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    If you have manual hubs and they are unlocked, then nothing should be spinning. That would be different than what is being done here, which would be similar to being in 2wd but leaving the hubs locked all the time.
  5. Apr 26, 2017 at 11:57 AM
    jowybyo
    Joe
    Baltimore, MD
    A member on here was done it by taking 1st gen manual hubs and creating a custom CV axle that has a 2nd gen inner joint and a 1st gen outer joint (required a custom shaft). It's a pretty cool setup.
    Cjc3 and 12TRDTacoma like this.
  6. Apr 26, 2017 at 11:59 AM
    Speedytech7
    I was talking about leaving them locked in while driving in 2WD, which I do a lot in the winter when I think I may need 4wd at some point during the trip. Believe me I understand how my own truck works
  7. Apr 26, 2017 at 12:00 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Pardon my ignorance here, because I'm not familiar with the 4x4 system. I believed the point of this mod was to remove the actuator which engages the 4x4 system so it retains 4x4 all the time?
  8. Apr 26, 2017 at 12:00 PM
    jowybyo
    Joe
    Baltimore, MD
    Yea. I don't see a problem with this. I drove about 20k miles with my front diff active when the actuator was broken.
  9. Apr 26, 2017 at 12:01 PM
    Speedytech7
    The transfer case and the front differential tube both have actuators. The system has multiple points of engagement. This only cuts out the last one on the front differential. This one doesn't engage the power to the front driveshaft it just engages the passenger CV to the front differential, thus making it live.
  10. Apr 26, 2017 at 12:02 PM
    jowybyo
    Joe
    Baltimore, MD
    No, it's just to remove the actuator from the front diff so that the front diff is always ready (live) for the t-case to be engaged in 4x4. You still have selectable 4x4, but the components in the front axle will also be turning.
  11. Apr 26, 2017 at 12:06 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh, see, I didn't know there were two actuators. Fantastic answer. Thanks for the small education course. :thumbsup: :)
    I'll have to bookmark this thread for when I have issues with mine.
  12. Apr 26, 2017 at 2:15 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    About as much as I worry about my rear diff turning all the time. :)
  13. Apr 26, 2017 at 2:15 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I have all the parts in my garage to do this swap to compliment my FJ case.
    Only thing that would concern me are the needle bearings. But, since I have ARB's, I no longer have needle bearings.
    I called ECGS twice. Two tech guys told me that with bushings, you're basically replicating the live axle on the FJ.
    "Swap it and forget it" the first guy told me. That's what I'm going to do.
  14. Apr 26, 2017 at 2:17 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Anybody else think OP is over-exaggerating how "unreliable" the ADD actuator is? I hardly ever hear about them failing.
  15. Apr 26, 2017 at 2:28 PM
    #35
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  16. Apr 26, 2017 at 2:32 PM
    #36
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    Short answer: The actuators are prone to water intrusion when submerged. The internals rust pretty easily. There are also other reasons they fail though.
  17. Apr 26, 2017 at 2:43 PM
    #37
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    I am hoping to install my manual hub setup this weekend.
  18. Apr 26, 2017 at 3:54 PM
    #38
    jowybyo
    Joe
    Baltimore, MD
    Where did you get a manual hub setup for a 2nd gen?
  19. Apr 26, 2017 at 3:55 PM
    #39
    jowybyo
    Joe
    Baltimore, MD
    No. I've had two fail on me. Both times water got in it when I was only in a few puddles up to the hubs.
  20. Apr 26, 2017 at 4:55 PM
    #40
    paranoid56
    San Diego
    14 double cab taco
    let me find it, but there is a guy selling the kit. kinda expensive but i have always been a fan of less shit turning when driving lol
