How to: drop, clean, and reinstall the 2nd Gen transmission pan and filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hook78, Jun 23, 2021.
  1. Jun 14, 2025 at 9:31 AM
    #201
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    As an alternative and I get the impression that you also like toys is the scangauge. You can see hundreds of things then :thumbsup: I bought one for the need to know fluid temp when checking the fluid level on the 750 plus i have configured one screen to act as a trip computer with distance , miles to empty, liters remaining etc...
    ddaytaco[QUOTED] likes this.
  2. Jun 14, 2025 at 11:59 AM
    #202
    RockinU
    RockinU Well-Known Member
    Texas
    I just finished the second pan drop filter change in the last 3 weeks. First one was 4.1L from the pan/strainer, the one today was 4.3L.
    Both A750F so not the same, but makes me think 6 from yours is quite a bit.
  3. Jun 14, 2025 at 3:46 PM
    #203
    ddaytaco
    ddaytaco Member
    I would have thought the same, and really would have thought I was going crazy if I didn't see that other post elsewhere with the same issue and the word "madness" in the title. :notsure:
    I just checked it cold - it's exactly in the "cold" range on the stick. But it's going to be very hot this week...I'll drive in some traffic during that and check it hot after. We'll see...
  4. Jun 22, 2025 at 5:03 PM
    #204
    Colinator4321
    Colinator4321 Well-Known Member
    Colin
    2012 Toyota Tacoma TRD Sport DBLC 6M
    Not sure if there has been a definitive answer yet, but my service manual states the drain plug should be 15 ft-lbs PXL_20250622_235134648.jpg PXL_20250622_235026422.jpg
    RockinU likes this.
  5. Jun 22, 2025 at 5:44 PM
    #205
    RockinU
    Texas
    That is the consensus
  6. Jun 22, 2025 at 6:29 PM
    #206
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Everyone seems to agree on 15, but I’d be interested to know if the FSM has been corrected. The Haynes are great, but they’re not necessarily definitive.
  7. Jul 18, 2025 at 12:14 PM
    #207
    Dane
    Dane Well-Known Member
    Dane
    Houston, TX
    07 PreRunner SR5 TRD Off Road
    Drain plug, torque is 15 ft lbs, if you do 21 ft lbs you are most likely strip the bolt. Don't ask how I know that.
    2015WhiteOR likes this.
