How to: drop, clean, and reinstall the 2nd Gen transmission pan and filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hook78, Jun 23, 2021.
  1. Jul 1, 2021 at 3:29 PM
    #41
    TacoManSam
    TacoManSam Well-Known Member
    Sam
    Saint Augustine, FL
    2013 White Tacoma TRD Sport DCLB V6 4x4
    Faux TRD Pro Grille | 3rd Gen TRD-OR suspension | 6' Leer Topper | Running Boards
    Awesome timing! I was JUST thinking about searching for a DYI / walk-through on how to do this and - viola - a brand new thread is posted on how to do this. :D
    I bought my 2013 TRD sport in Nov of 2018 with 120k miles (has almost 160k now) and only hope that the transmission fluid has been changed already, don't really know.
    Great job on the write-up and great pics! :bowdown:
    I'm really looking forward to doing this, along with a complete flush, very soon. :thumbsup:
    Hook78[QUOTED][OP] and VE7OSR like this.
  2. Jul 1, 2021 at 5:47 PM
    #42
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Glad it’s helpful!
    Post a pic of what drains out.
  3. Jul 1, 2021 at 6:18 PM
    #43
    Doghouse61
    Doghouse61 Well-Known Member
    Paul
    Calgary
    Does anyone know of a magnetic drain plug available for A/T in a 3rd gen?
  4. Jul 1, 2021 at 6:30 PM
    #44
    Doghouse61
    Paul
    Calgary
    Or can anyone give me the dimensions of the stock drain plug?
  5. Jul 1, 2021 at 6:36 PM
    #45
    Hook78
    Eastern NC
    2015 DCSB TRD OR
  6. Jul 1, 2021 at 7:09 PM
    #46
    Doghouse61
    Paul
    Calgary
    Thank you Hook, very much appreciated
    Hook78[OP] likes this.
  7. Jul 2, 2021 at 4:47 PM
    #47
    PA38flyer
    PA38flyer Member
    2010 Tacoma
    Big thanks to OP Hook78 for putting this together . . . the best step by step ever! Couple of things I did to make it easier on myself:
    As Hook says, soak the pan bolts the day before. I used 10W whatever oil was on my shelf; brushed it on the top of the case flange where the threads go all the way through and tried to get oil under the head. Bought some extra M6-1.0x12 bolts in case I broke one (didn't though).
    Didn't have a 24mm socket for the fill plug, but had an old 15/16" that was wore out just enough to make a nice snug fit on the plug. (24mm = 0.94488", 15/16" = 0.9375") The plug has a pretty shallow head, so I ground the socket down to where the points begin to get full contact. It bit just fine, no slipping.
    To keep from spilling on the driveway when dropping the pan, I put a trash bag over a (well used) cheap plastic cement mixing tray and positioned it underneath. It was big enough to contain any splashes.
    Didn't feel agile enough to fool around with a pump under the truck, so 4 feet of plastic tube and a funnel worked good. Buck and a half for the tube and pinched a funnel from under the kitchen sink; zip tied it to the intake plenum. Didn't spill a drop.
    Last note, the local NAPA had the ATP 17061 filters for $25; the bolt holes in the gasket are slightly undersize so a couple of bolts inserted keeps the gasket in place.
  8. Jul 2, 2021 at 5:35 PM
    #48
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Awesome post! Good to know the bolt size for the pan. How’d your magnets look?
    Love the technique for filling, I may adopt that on the next one.
  9. Jul 5, 2021 at 8:14 AM
    #49
    PA38flyer
    PA38flyer Member
    2010 Tacoma
    Magnets looked about the same as yours, some accumulation of very fine dark particles.
    In the aviation maintenance world, filters are cut open and the media inside is examined to get a system health assessment. I have not seen any photos of anyone doing this to ours, so here goes.
    2010 DCSB A750E 127K miles, original fluid and filter (or strainer if you like, dictionary definition is the same). Daily drive, occasional 1,000 mile cross country, tow a 4,000 lb boat & trailer 20 miles each way up and down hills 80 times a year. Never off road.
    Left side is the top housing, strainer in the middle, bottom housing on the right.
    This is the inside of the bottom, some glitter sticking to the liquid residue.
    Inside the top.
    And the strainer itself. Not many particles throughout the mesh, the three dark areas at the top of the picture and along the left side are similar to the goop that collects on the magnets. Close up it looks like there may be some aluminum specks in there, but a little piece scraped off jumps to a magnet. The mesh is non-ferrous and has a lot of surface area.
    Not as much accumulation as I expected, but I'm no expert. This truck ran just fine at twice Toyota's recommended fluid change. I don't think I will ever try to clean and re-use these, no way to assure you've got it all. For me, $25 is cheap insurance.
  10. Jul 5, 2021 at 8:47 AM
    #50
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Now that I can see the design of the strainer, cleaning it is somewhat futile. I thought the mesh material was only where the fluid ports through, not a continuous layer across the whole unit. Nothing wrong with cleaning what you can see, but only a small portion of the mesh is accessible. Can’t hurt though.
    Might be better off letting a magnet gently slide around in there on both sides and then retrieve it...
  11. Jul 6, 2021 at 4:16 AM
    #51
    RadicalTaco
    RadicalTaco Well-Known Member
    Great info. Time to put this one on the schedule.
  12. Jul 6, 2021 at 10:41 AM
    #52
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
    Hook78 thanks for the great write up and I am planning this once I get all my parts in.
    A question for the high mileage guys on their very first tranny service. I have read through the other threads where guys have not done any service with 143K-200K miles. Has there been any repercussions after performing the drop, clean & flush? I am at 157K. Thanks!
  13. Jul 18, 2021 at 12:51 AM
    #53
    Icygod24
    Icygod24 Member
    Wondering the same thing dude! Definitley over 220k and im thinking about doing the whole process. don't know how it was treated before I got her.
  14. Jul 21, 2021 at 5:13 AM
    #54
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    My $0.02 with no first hand experience on a high mileage unit is that it wont matter. As long as you do it right and get the correct level of fluid youll be fine. In fact some even say that a D&F is the best way to go, cause you've still got roughly 2/3 of the old fluid in the and 1/3 new. Then you do another one with each oil change until eventually its mostly new fluid in there.
  15. Jul 21, 2021 at 5:32 AM
    #55
    SR-71A
    Zack
    Southern Maine
    Shoutout to @Hook78 for putting this together. Lots of other threads cover the info needed but this is clean and concise in one place, makes for a good reference.
    I did mine this past weekend. Just rolled over 90k on the clock, so figured it was time. No major hickups and the old fluid that came out still looked / smelled good. But I feel better about it now haha. Plus was good to get the sludge off of the four magnets and give the pan a cleaning.
    If you live in the salt belt, definitely make sure you have new crush washers on hand. USPS didnt get mine delivered in time so I had to reuse the old rusty ones. No leaks, so I guess technically its ok but Ill be changing those out in 5000 miles when I do a D&F for sure. Also not a bad idea to have a scraper on hand to get any oxidation and dirt buildup off the surface of the trans housing before the new gasket goes on.
    As others said be prepared to make a huge mess when you take the old filter off. As you can see mine was pretty grimy. Not too bad on the inside though. As a side note, the Toyota OEM gasket is a much nicer and slightly thicker material than the one that came in the filter kit from Napa.
  16. Jul 21, 2021 at 5:53 AM
    #56
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Nice work!
    Did you see post #49, one member cut the strainer up, and now that I’ve seen how it’s constructed I think it’s pretty difficult to thoroughly clean. I might be inclined to replace it on the next go-round.
  17. Jul 21, 2021 at 7:08 AM
    #57
    SR-71A
    Zack
    Southern Maine
    I did see that. Based on what I could see in my old strainer, it wasnt needed. But I had the new Napa one on hand so I installed it anyway. Only like $30 IIRC.
    I did use a new OEM gasket instead of the Napa one though.
  18. Aug 11, 2021 at 5:01 PM
    #58
    kwanjangnihm
    Jeff
    Central Florida
    Hook78 thanks once again for the write up sir!
    160K and no tranny service, although not one issue with transmission, shifted great and I do have the OEM cooler.
    I dropped, drained and installed new strainer, gasket, etc. 4.7qts out, 5.0in. AT TEMP Mode - less than a drizzle.
    Today I drained 3qts out and put 3.5qts in - drove 10 miles and will check level in the morning.
    Tranny performing great! Last photo 160K color on left, right is after 5 new quarts. IMG_6212.jpg IMG_6213.jpg IMG_6214.jpg IMG_6215.jpg IMG_6255.jpg IMG_6256.jpg
    TnShooter likes this.
  19. Aug 11, 2021 at 5:25 PM
    #59
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    That’s some dark fluid but not as bad as I’d think for your mileage. Glad it worked out for you and thanks for sharing the photos!
  20. Aug 11, 2021 at 6:12 PM
    #60
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    A fellow amateur gunsmith I see ;)
