How to have a dry bed with a topper?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BowtechDan, Jun 17, 2020.
  1. Jun 17, 2020 at 8:15 PM
    BowtechDan
    BowtechDan [OP] Well-Known Member
    Madison, AL
    2020 TRD Sport DC SB
    I love my Gen 3, but how does anyone have a dry bed while driving in the rain with a topper? The topper doesn't leak, but the beds front corners do, and water works it's way from the rear at the tailgate.
    The front corner is a couple holes. And when you can shut the tail gate and see the driveway through the rear corners, shits gonna leak. And water seems to work its way from (I'm assuming) under the bed rail caps.
    For the tailgate, has anyone ran a weatherstrip around the corners to fill the 1/2" or more gap?
  2. Jun 17, 2020 at 8:17 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Bulb seals.
    Silicone.
    Learning in the end they’re not water tight.
    bax likes this.
  3. Jun 17, 2020 at 8:20 PM
    BowtechDan
    Madison, AL
    Where do you get bulb seals? I've thought about canvassing a junkyard and see if something from a car door could be modified or something.
  4. Jun 17, 2020 at 8:21 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    When I had my cap installed, they used a part labelled "Tacoma gasket". I've never had an issue with water.
  5. Jun 17, 2020 at 8:21 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  6. Jun 17, 2020 at 8:21 PM
    Flowie
    Flowie Well-Known Member
    2017 TRD OR
    None yet
    If we can have 100 gallon glass rectangles in our living rooms that hold water...then you can figger out a way to keep in out.
    Butyl tape and Through the Roof sealant might help.
    tonered likes this.
  7. Jun 17, 2020 at 8:23 PM
    T4RFTMFW
  8. Jun 17, 2020 at 8:23 PM
    BowtechDan
    Madison, AL
    Did it fill the holes in the rear corners? I can see plenty of daylight there. Maybe splash guards help?
  9. Jun 17, 2020 at 8:26 PM
    Lt. Dangle
    Ohio
    Yeah I have no light in mine. I imagine the products the guys have linked are essentially what was done to mine. If you can lift your cap, it seems pretty straight forward to seal, I beat most installers skimp on the details causing issues down the road.
  10. Jun 17, 2020 at 8:26 PM
    apreston1
    apreston1 Well-Known Member
    Liberty Hill, Texas
    I have a 2015 and have experienced VERY minor leaks and I stick to the mantra “ don’t let perfect be the enemy of good enough”
  11. Jun 17, 2020 at 8:27 PM
    BowtechDan
    Madison, AL
    It's not the cap installation......it's the gap where the tailgate hinges are located.
  12. Jun 17, 2020 at 8:31 PM
    Lt. Dangle
    Ohio
    Oh ok, sorry. Most people leak at the front corners. I must've misread your post, sorry.
    reread your post, you have both issues lol, sorry.
  13. Jun 17, 2020 at 8:31 PM
    BowtechDan
    Madison, AL
    Sorry, I have a 20 year aviation maintenance background. Half-ass is not an option.:)
    T4RFTMFW likes this.
  14. Jun 17, 2020 at 8:33 PM
    BowtechDan
    Madison, AL
    No you're right. I have some seepage there too and will try some additional weatherstripping too.
  15. Jun 17, 2020 at 8:34 PM
    Lt. Dangle
    Ohio
    Anthony up above listed everything you should need to get it straightened out. All of your gaps.
  16. Jun 17, 2020 at 8:37 PM
    BowtechDan
    Madison, AL
  17. Jun 17, 2020 at 8:39 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    you could "whole ass" it
    Lt. Dangle likes this.
  18. Jun 17, 2020 at 8:39 PM
    SpeySquatch
    2016 TRD OR DCSB
    Mine is completely bone dry after 3 years and living in Oregon. Seam seal all the seams where the straps are mounted with seam sealer. Get foam and silicone to seal the bed ends
  19. Jun 17, 2020 at 8:44 PM
    anthony250f
    Anthony
    San Diego, CA
    I siliconed under the bed rails, all of the cubbies, behind the bed track rails, ESI ultra seal, front rail seal, tailgate seal, and removed the bed cubbies and sealed them off with aluminum. Pretty much leak free now.
    tonered and BowtechDan[OP] like this.
  20. Jun 18, 2020 at 4:29 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
