How to mount tool box on Tacoma prerunner double cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco15'prerunnerV6, Mar 26, 2016.
  1. Mar 26, 2016 at 1:37 PM
    Taco15'prerunnerV6
    Taco15'prerunnerV6 [OP] Well-Known Member
    Roger
    2015 Toyota Tacoma prerunner
    It's has those side things to get in
    How do you mount tool box without drilling self tapping screws on truck
  2. Mar 26, 2016 at 2:01 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
  3. Mar 26, 2016 at 2:29 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I bought some doodads from Amazon that go in the bed rails and they have bolt threads in them. Run the bolts through the tool box into those blocks and you have a secured attachment that can't be undone from the outside.
    JDawg562 likes this.
  4. Mar 26, 2016 at 2:31 PM
    markc6606
    markc6606 Well-Known Member
    SoFlo
    '13 Off-Road
    Do you have a link for them ?
  5. Mar 26, 2016 at 3:12 PM
    JeffreyB
    Jeff
  6. Mar 26, 2016 at 3:31 PM
    markc6606
    SoFlo
    '13 Off-Road
    Na.. Traditional j hooks
    Do the ones your using grab the channel tightly? I like how you can position them anywhere.
    I'm using real j hooks and have them through the slots in the bottom of the factory rail. The slots are only bout an inch long so adjusting the box front to back is limited without cutting new slots in my box. Thanks for the link, might try a set of them.
  7. Mar 26, 2016 at 3:33 PM
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
  8. Mar 26, 2016 at 4:54 PM
    JeffreyB
    Jeff
    Yup they fit the channel like they were cut for it, you can definitely get enough torque on them.
  9. Mar 27, 2016 at 1:21 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I took two carriage bolts, put the head in the side channels, drilled holes on the side of the tool box, and bolted it up. It's extremely secure. Only downside is drilling holes into your toolbox.......I didn't mind though because it was a $60 craigslist find.
  10. Mar 27, 2016 at 4:38 PM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    lol I used to use jay hooks too. I ended up making some tabs that grip onto the bed rails. They look like that, but I made them from some scrap steel and welded a nut to the bottom of it. I'll try to take a picture of them.
