How to put springs on struts?
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Mar 23, 2011.
  1. Mar 23, 2011 at 8:49 PM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    so ive had these 881 springs and ome struts forever now because I havent had the time. But every time I start I hit the same first question: how do I install the springs on the struts? Ive tried googling it and searching the forum but havent found enough info. I know that some autozones sell the tool needed but harbor freight sells a better, safer one for 9 bucks. Even if I had the tool I wouldnt know what to do with it. Ive always worked on bikes and atvs. Cars not so much
  2. Mar 23, 2011 at 9:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  3. Mar 23, 2011 at 9:33 PM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    9 dollars!! you kidding me? wow, i definitely wouldn't trust a $9 spring compressor, regardless of where it came from. And I have nothing against harbor freight...just wouldn't take the risk on something like this.
    You can rent the spring compressor from autozone...just return it and you get your deposit back. It's actually called "strut compressor", not to be confused with a "coil spring compressor". The coil spring compressor will not work. The strut compressor works because it attaches to the outside of the spring.
    I'd definitely read that thread that Digiratus just put up for you. Read it a few times. It's not hard to do...but can be dangerous if you don't know what you're doing.
    There's even pictures in that thread (and other threads) of where people have the springs compressed, etc w/ the tools you'll need and everything. Should be pretty self explanatory.
    Hope that helps.
  4. Mar 24, 2011 at 5:08 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Dont even think about using the compressors like shown below on your coils. It will not work. I tried them. They don't open up wide enough.
  5. Mar 24, 2011 at 5:14 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    You can rent the spring compressors for a deposit, way better than the harbor freight compressors, the set I had from Harbor Freight, bent and the hook broke, luckily, it was after I started taking it off because of the bending. Used the Compressors from the auto parts store, no problem.
  6. Mar 24, 2011 at 5:27 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    How about taking the struts and springs to a shop and get them to do it. This way you don't have to buy tools that you might hardly ever use. Just another option. People do it at my work all the time.
  7. Mar 25, 2011 at 9:53 AM
    x2468
    I thought about that but they quoted me.at 45 bucks and im a cheap mofo
    Is the tool from autozone the same as the SST in the pdf from digiratus' link
  8. Mar 25, 2011 at 10:04 AM
    x2468
    and if not, does anyone have pics detailing how to use it? The autozone or advance auto rental tool that is
  9. Mar 25, 2011 at 10:07 AM
    Taco76087
    Robert
    Weatherford,Texas
  10. Mar 25, 2011 at 10:13 AM
    Jeremy92
    Jeremy92 Tennessee Member
    Jeremy
    Smyrna, TN
    08 AC SR5 Prerunner Impulse Red
    Billies on all the way around, w/ Eibach Coils, w/ rear TSB. Brush Guard. Tail Light Guards.Window Rain Deflectors. 35% tint on side windows. Satoshi Grill(thanks TacoAlaMode). Fog Light Mod (thanks lifesaflaw123). 17x9 XD addicts wrapped in Kumho SAT Kl 61's 265/70/17.More to come!!!
    The autozone one is a P.O.S. do not waste you time trying with it, take it to a shop and let them do it. this past weekend a couple of buddys from on here were trying to compress my eibach spring with an autozone compressor and we were bending the spring and the compressor. When those springs are compressed they are no joke if something slips and the spring shoots out, i dont want to know what would have happened if something would have sliped. Go somewhere and get a shop to do it for you.
  11. Mar 25, 2011 at 12:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, compressing the coils will definitely tighten up your nutsack. :eek:
  12. Mar 25, 2011 at 12:09 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I'm surprised. I have a clamshell spring compressor that I've used for the coils on my Ford without issue, and those things really needed to be cranked down. What size was the compressor you used?
    The only issue I could see is fitting the tool in between the coils on the Tacomas as the wind appears to be pretty tight. I'll know more after I swap out coils on my Fox setup whenever I get around to it.
