How To Remove CV Axle+Replace Front Wheel Bearing 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KenpachiZaraki, Nov 22, 2011.
  1. Nov 18, 2013 at 6:55 PM
    #201
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Nice find!! thanks for providing it.
  2. Nov 18, 2013 at 6:58 PM
    #202
    Jakers83
    Jakers83 Well-Known Member
    Jake
    Denver
    2.7 base.
    OME lift. Tires and wanting more
  3. Jan 3, 2014 at 11:49 AM
    #203
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    I found P/N 18491 from NAPA as an alternate to Differential Seal - 710419 (Timken)
  4. Jan 3, 2014 at 11:55 AM
    #204
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Nice!
  5. Jan 19, 2014 at 9:15 PM
    #205
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Both side on mine are leaking i noticed when i changed my oil yesterday.Both sides have slop.Does anyone think that the pass side diff bearing is bad as well? and is it as easy to install as the egcs bushing. or should i just replace it with an egcs bushing?
  6. Feb 11, 2014 at 5:51 PM
    #206
    drmax
    drmax Well-Known Member
    IND
    95 DLX 4WD
    Kenpachi, what was the symptom of your shaft being bad? I have a vibration coming from passenger side front end. It was verified (without taking anythng apart, that it is not my wheel bearing) Was only told there is no wobble and feels tight. I do not get any abnormal sound when turning. What I do get, is a sound like the engine is reving when applying throttle, perhaps going above 40 ish. Also when down shifting. When rolling out to a stop, in gear or not, it rolls to a stop with this vive, as though the tire vibrating. So its when there is possitive pressure being put on the drive train, or when rolling out to a stop. Almost a grinding sound, yet to a squeeling metal sound. Verified not the clutch, tranny or transfer case, or rear diff....by reputable xmission guy. No difference if in 4wd or not. You can run down the road and turn off truck and there is this slight vibe and this same reving type sound, in neutral or not. Verified alignment and tires in balance. If it is the bearing, thn it'd require weight on wheels, for the sound is not there on a lift, with wheels turning. It's like I'll need something to fall apart, in order to find it and not wanting to be stranded in order to find out. Any thoughts? Thx, DM and sorry if I highjacked your thread. Just figured you or someone may know.
    (also manual locks for hubs and no mods ever don to truck)
  7. Mar 2, 2014 at 6:27 AM
    #207
    drmax
    IND
    95 DLX 4WD
    Center bearing was shot and also found rear u-joint slightly binding in spots. Repaired both at home and no more noise/vibe/hum.
    Went with Dorman center bearing and Moog u-joint...both at Advance Auto. Total under $80. DM
  8. Mar 2, 2014 at 8:05 AM
    #208
    KenpachiZaraki
    KenpachiZaraki [OP] Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Internet high five! Glad you got it figured out. My wheel bearing was making a grinding noise ging slow speeds and would become higher pitched as I drove faster. It would also go away if I turned in one direction but not the other. It's just one of those things that goes bad with time, and the lifespan is shortened considerably if nodded offroaded etc. I recommend greasing your u joints every oil change and checking fluids. Basic maintenance will show off with time and your truck will last a whole lot longer. Sorry I wasn't able to answer your question quick enough! TW ftw!
  9. Mar 6, 2014 at 1:24 PM
    #209
    jedi1798
    jedi1798 Member
    Alaska
    '11 Tacoma
    What is "OE" parts? Im getting ready to replace my CV.
  10. Mar 6, 2014 at 1:29 PM
    #210
    SoCal Hillbilly
    SoCal Hillbilly Well-Known Member
    Eric
    San Diego
    2013 DCSB
    "Original Equipment". AKA factory parts
  11. Mar 6, 2014 at 3:01 PM
    #211
    MassTaco2009
    MassTaco2009 New Member
    Shawn
    Massachusetts
    09 crew cab v6 4x4
    Just found this last week. Complete, ready to bolt on replacement wheel hub assemblies. Hope it helps.
    http://www.tacomaworld.com/forum/2n...s-4x4-sale-complete-best-price-ever-save.html
  12. Mar 6, 2014 at 5:15 PM
    #212
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    I still have that same cv joint FWIW. It's not OE, but it's held up to some offroading and 100+ mph on uhhh roads. No problems with AutoZone stuff Here.
  13. Mar 7, 2014 at 8:51 PM
    #213
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
  14. Apr 23, 2014 at 1:59 PM
    #214
    Moshenek
    Moshenek Member
    Michael
    Norfolk
    05 TRD DCSB
    With regard to the hub to bearing assembly interference fit- has anyone ever tried freezing the hub while using an induction heater on the bearing assembly in order to avoid the use of a press? OR does anyone have the OD of the hub shaft? I don't have a press handy and I have trust issues dropping my stuff off. :rolleyes:
    Thanks
  15. Apr 23, 2014 at 2:06 PM
    #215
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    Buy a ready to go one from nj636 and be done
  16. Apr 23, 2014 at 6:52 PM
    #216
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    :cheers: :thumbsup:
    one of your best posts yet :D
  17. Jun 6, 2014 at 10:28 PM
    #217
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    I replaced both of my hubs (nj636's) today. Here are a few tips that I'm pretty sure I didn't see in the prior pages:
    1) You don't have to disconnect the tie rod. If you disconnect the sway bar link, and remove the two bolts connecting the lower ball joint to the spindle, the spindle will pivot out of the way so you can pull out the cv shaft.
    2) OP apparently didn't have dust shields, so he could hit the hub with a hammer and knock it off. I have dust shields. First I used the "piece of metal between the hub bolt and hub" trick, and that loosened the hub easily. Then I resorted to a three jaw puller, which worked well to remove the hub.
    3) I thought I could use a prybar to pop the cv out, but I couldn't get that to work. A slide hammer, which Autozone rents for free, worked pretty well.
  18. Oct 7, 2014 at 8:30 PM
    #218
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    Oil Seal(s) - ??? There are two on the cv axles, one closer to the differential, the other towards the outside or close to the wheel bearing. The same ones i didn't replace I need part numbers for these.
    Can someone assist me on getting the correct seal on rockauto's website? I need the one that is closer to the wheel bearing. Thanks
  19. Oct 8, 2014 at 4:03 AM
    #219
    nj636
    Kev
    Jersey
    National 710573 :cheers:
  20. Oct 8, 2014 at 4:55 AM
    #220
    vincentphilip
    vincentphilip Active Member
    I am Interested with this Kind of Stuff and You Have Done a Great Job by sharing ur knowledge with us.
