How To Remove CV Axle+Replace Front Wheel Bearing 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KenpachiZaraki, Nov 22, 2011.
  1. Sep 3, 2015 at 7:57 AM
    #321
    RallyxTaco
    RallyxTaco Member
    Maryland
    Thanks for this guide. I looked up all the torque specs from the Toyota service manual so here they are if anyone else wants them:
    ABS Sensor 10mm - 10ft lbs
    Brake line bracket 12mm - 21ft lbs
    Brake caliper 14mm - 91ft lbs
    4 17 mm hub assembly bolts - 59ft lbs
    Front axle hub nut - 173ft lbs for 4WD, 203ft lbs on Pre Runner
    Tie rod - 67ftlb
    Upper ball joint/suspension arm - 81ft lb
    Lower suspension arm - 118ft lb
    Sway bar links - 52ftlb
    Wheel - 83ft lbs
    smokn and jovol like this.
  2. Sep 3, 2015 at 12:26 PM
    #322
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Like this? [​IMG]
  3. Sep 3, 2015 at 1:58 PM
    #323
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    That's what I used to pop mine out. I just slammed those suckers back in by hand though.
  4. Sep 3, 2015 at 3:26 PM
    #324
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Gotcha. I think I'm going to order this: If you read the 2nd Review down, a Toyota Master Tech from Buena Park, CA wrote a convincing review.
  5. Sep 3, 2015 at 3:39 PM
    #325
    deeezy
    Dana
    Hawaii
    It works. There's a thin metal dust sheild lip on the cv's where you will be prying. I bent mine a little from prying on it but it's not a critical seal or anything so I just bent it back with some pliers and she was good to go.
    Crom likes this.
  6. Sep 3, 2015 at 10:52 PM
    #326
    kevinmcc
    kevinmcc Member
    Hey guys I am about to replace my front wheel bearing and have some questions.
    1. Is the axle nut reusable?
    2. Do I need a press for or can I use a wood block and hammer to hammer in the spindle into the wheel bearing hub?
    3. What seal is the correct seal for the one that goes between the spindle and the wheel bearing hub assembly
    http://shop.advanceautoparts.com/p/...79603&searchTerm=710477&showTitle=#fragment-3
    or
    http://shop.advanceautoparts.com/p/national-oil-seal-710573/20441889-P?searchTerm=wheel+seal
    Lasty. For the inner seal, is there enough room to take out the cv shaft from the knuckle without removing the sway bar, tie rod, ball joint etc? I want to replace both inner and outter but not if its going to be a pain.
  7. Sep 4, 2015 at 8:46 AM
    #327
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I ordered it. Hope it helps.
  8. Sep 4, 2015 at 9:14 AM
    #328
    deeezy
    Dana
    Hawaii
    It'll definitely work. I tried a couple quick wacks with a slide hammer, which didn't work at first, then just pryed them off. Took a couple minutes with the pry bar.
  9. Sep 4, 2015 at 10:45 AM
    #329
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    So, you're saying that you used the Pry bar in lieu of the Slide Hammer?
    After I got the Pry Bar, all I'll need is a couple more quarts of 75W-90 and a Torque Wrench that goes to at least 173 foot lbs. The one I have stops at 150 o_O
    How long did it take you to do one side?
  10. Sep 4, 2015 at 12:17 PM
    #330
    deeezy
    Dana
    Hawaii
    I didn't replace my hubs. I took my CV's out to swap the front diff. And yes, I used the pry bar instead of the slide hammer. IIRC it took me about 30-45 min per side. I used a corded electric Dewalt 1/2" impact gun to take the axle hub nut off and to reinstall.
    Are you swapping diffs?
  11. Sep 4, 2015 at 1:05 PM
    #331
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Well, not my Diffs but... I'm going to attempt to swap out both CV Axles, Wheel Bearing/Hub Assemblies, and replace my tucks busted Needle Bearing with the ECGS replacement. Kind of a big job for someone who's never replaced any of those parts before haha
    I'm just trying my best to have all the tools, seals, gear oil, etc ready before I attempt to give it a go.
  12. Sep 4, 2015 at 1:15 PM
    #332
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I just remove by using a chisel and a hammer on the notches haha :notsure:
  13. Sep 4, 2015 at 2:34 PM
    #333
    deeezy
    Dana
    Hawaii
    That also works. I remember having to tap one side in like that when re-installing.
  14. Sep 4, 2015 at 4:23 PM
    #334
    deeezy
    Dana
    Hawaii
    I used the pry bar like this and they popped right out:
  15. Sep 4, 2015 at 11:31 PM
    #335
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    1. For a $2-5 part, it's wise to replace - I re-used mine. Dura kit # 295-96058 from RockAuto includes bearing, hub and nut for $74.
    2. Eric the Car Guy used a hammer on a 4Runner - took forever https://www.youtube.com/watch?v=YTS4ke7nViE
    I used a 20-ton press. Follow these tips (I inverted an old bearing race in place of the sleeve):
    https://www.youtube.com/watch?v=BhHbOe5SSZc
    3. The 710573. $11 at Amazon; $9 at RockAuto.
    3b. Don't forget the O-ring, part Toyota # 90301-A0005.
    Lastly: you need to remove sway bar and tie rod ball joint. Main ball joint also, but it is on a subassembly (aka ball joint steering stop) - it comes off easy by removing two bolts. You don't have to remove the CV shaft - it's easy to push outta the way once the knuckle is free from the ball joint steering stop. (Do remove the caliper first.)
    Some tips: Use a wire adapter on a drill to remove all rust, then apply a light coat of grease (axle cap; bearing seals - on metal to metal surfaces; even the rotor where it slides over the hub). Lube rubber to metal surfaces with silicon such as SuperLube #92003; diaelectric grease will do. That inside seal was a PIA to install - I ended up using a 1X3 piece of wood and a C-clamp to press the seal onto the knuckle. Be very careful sliding the CV shaft through so it don't tear the rubber on seal - use silicone here.
    Some good tips here: https://www.tacomaworld.com/threads/another-front-wheel-bearing-replacement-resource.202119/
    Don't follow the Eric the Car Guy video; he did it the hard way.
    This is a good video for replacing the bearing: https://www.youtube.com/watch?v=BVuM8iVO6u8
    Crom likes this.
  16. Sep 11, 2015 at 11:45 PM
    #336
    808KBD
    808KBD New Member
    Kauai, Hawaii
    2005 Tacoma 4x4
    KenpachiZarak, there is no need to remove the hub and get it pressed. Simply remove the two bolts from the lower steering knuckle will give plenty clearance to get it out. Just an easier way about it.
    KenpachiZaraki[OP] likes this.
  17. Sep 25, 2015 at 7:20 AM
    #337
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    Awesome write up, very helpful while researching before doing my wheel bearings and ECGS bushing last weekend!
  18. Sep 29, 2015 at 7:44 AM
    #338
    KenpachiZaraki
    KenpachiZaraki [OP] Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Awesome glad it helped.
  19. Oct 3, 2015 at 10:02 AM
    #339
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Thank you for the shootout Alex :thumbsup:
  20. Oct 3, 2015 at 11:42 AM
    #340
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    You're welcome! Those seals are a great save again btw!
    :infantry::laser::fenforcer:
