How To Remove CV Axle+Replace Front Wheel Bearing 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KenpachiZaraki, Nov 22, 2011.
  1. Oct 12, 2015 at 9:02 PM
    #341
    FKNBUM
    FKNBUM Member
    Anchorage (formerly Alaska)
    Work wagon
    Do I need to lube the axle splines? They were dry from the factory but it seems like they should have something, as BMW MC drive splines do. I put nickel anti-seize on the dust cover and both sides of the disc rock shield. Hopefully there is no problem with this.
  2. Oct 12, 2015 at 11:15 PM
    #342
    KenpachiZaraki
    KenpachiZaraki [OP] Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    You should be ok. I put grease on the splines when i did mine.
  3. Nov 14, 2015 at 3:25 PM
    #343
    FLJB
    FLJB Well-Known Member
    J
    FL
    2020 4X4 Sport MT
    I ordered replacement assembled bearings from member NJ636 at this thread in the 2nd Gen Marketplace: "https://www.tacomaworld.com/threads...-complete-save-custom-built-available.288055/" and highly recommend him if you need replacement bearing assemblies. Speed, quality, fair price, responsiveness, and attention to detail. Have no reservations.
    Spectacular packaging, secure and well wrapped!
    I do light maintenance on my truck, but nothing as involved as this and reading this and the other threads gave me the information and confidence to undertake this job. I wanted to post this for others like me who were thinking about it. It is totally doable and will save $$$ so don't think you can't. Note: I just did the bearings not the CV axle like OP.
    A couple of points from my process, which is to be continued tomorrow as I ran out of daylight and had a couple of misques, pictures will be posted when finished.
    1) I cannot emphasis the importance of PB Blast and Leverage, especially if your truck is more than a few years old and has not had any work in these areas. The bolts are tight and breaking them free requires the right tools and leverage. The brake caliper bolts were my hang up. they would not come loose until I had worked on them for a while. I took the time to apply PB blast to all the areas and have broken them all free so finishing will be easy.
    2) If you have 4X4, lock the hubs and use a breaker bar to wedge it to keep the hubs from spinning when removing the 173 ft/lb bolt. I forgot at first and had already disconnected my battery which cost me time. To help you get the hub nut off I put two lug nuts on and wedged a pry bar in to lock it down. there is a tool at Auto Zone which will help you get the hub off no problem. Part # 27011 2/3 jaw puller 8". rent it it will get the hub off instead of beating it with a hammer.
    3) The removal of the axle hub grease cap was a pain. I tried to use a dead blow hammer with no luck, you need a real hammer and a screw driver like it says in the instructions above. But be careful with the angle and how hard you hit or you will punch a hole and cost yourself $27 to replace it. I took pictures to show how/where it goes and what it looks like when you get it started which I will post later. If it has never been off, it is on there pretty good and you will spend time on it like I did before figuring it out finally.
    proper axel hub grease cap removal screwdriver placement
    the middle hammer is what you need to remove the cap not the left or right hammers...
    4) I was worried about removing and hanging the disc brake calipers as that seemed sketchy to me and I did not know if I would have to bleed the brakes or if it would require anything else I had not seen since it was brakes. However after FINALLY removing the two 17 mm bolts it was not hard at all and the reinstall was nothing special, other than lining up the holes to put the bolts back in ( i used a mirror to see). I test drove it and no problems with the brakes. no leakage, nothing. It is as easy as it appears. Be sure to remove the attachments for the brake lines so as not to stress them like the instructions show and it is good to go.
    5) when you get the tires off, spray everything down with non chlorinated brake cleaner to get all that brake dust off and keep it out of your body.
    6) I identified what causes that maddening pad slap noise every time you hit the brakes after they have worn down a while. I will post a picture and and going to lube it to see if that helps. It appears brake dust binds up the pins and the force of applying the brakes causes them to slap and cause that noise.
    7) remove the front speed sensor by using a screwdriver in the slot to hit the detent and then pull it off. I will post a picture for reference
    I appreciate everyone's helpful comments which made this doable for me! Thank you OP!
    FLJB (edited for pictures found later.
  4. Nov 30, 2015 at 2:46 PM
    #344
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I read this over and over again as I was preparing for my great wheel bearing replacement adventure (first time) and as I grabbed my big-ass hammer and screwdriver, I kept saying to myself "Be careful, don't punch a hole into this thing." So I place the screwdriver carefully into the cap/hub crevice, making sure the angle is correct. Then I give the screwdriver two solid whacks. Apparently, the first whack did nothing but bounce the screwdriver off the initial original placement and it landed on the soft (very soft) part of the grease cap. The second whack punches a nice clean hole into the grease cap.
    Like so...
    So, cheap-ass that I am (didn't want to pay $27 bucks to replace it.) I cleaned the area around the hole down to bare metal and soldered the damn thing.
    I even painted it a nice hear resistant gloss black...
    When I reinstalled it, I added anti-seize along the rim contact point. Next time, I hope that it will come off easier.
    Thanks FLJB! It it weren't for your advance warning, I could've torn an even bigger hole :)
    Crom likes this.
  5. Nov 30, 2015 at 7:38 PM
    #345
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    It's a dust cap, so no big worries
  6. Dec 1, 2015 at 5:36 PM
    #346
    FLJB
    J
    FL
    2020 4X4 Sport MT
    Right on. That works. I was going to just seal mine up with some JB weld, but I bought one from the dealer since mine hole was a bit larger than yours... Glad I could help and pay it forward!
    Crom likes this.
  7. Dec 1, 2015 at 6:22 PM
    #347
    Subway4X4
    Lloyd
    NY/NJ
    Best way to clean off the rust/baked on brake dust on the caliper pins: Chuck it into your drill, hold the pin against a wad of sandpaper and let it spin away. Every last bit of rust will magically get sandpapered off, leaving you with nice, smooth pins. Believe it or not, these four pins were crusty with rust and dust.
    Crom and FLJB[QUOTED] like this.
  8. Feb 3, 2016 at 5:33 AM
    #348
    Madtown Taco
    Madtown Taco Well-Known Member
    Madison, Wisconsin
    05 TRD Sport SR5 DC LB 4x4
    Gun Metal FJ Cruiser TRD Wheels, Black Head Lights, I-pod Patch Cable for Stock Head Unit, In-Cab 115V outlets, Aries Bull Bar, 12V outlets in Bed, Snug Top Super Sport Topper, Hard-Wired Valentine 1 Radar Detector, Disabled Automatic Air Conditioning for Windshield Vent Setting, Additional D-Rings in Bed, 12-Volt Pop-N-Lock Solenoid in Tailgate Handle, TRD Front Seat Covers, WeatherTech Floor Mats
    Once the bearing and hub is removed, what kind/type of grease should be used on the axle spline before inserting it into the new bearing and hub assembly? Thanks.
  9. Feb 3, 2016 at 10:12 AM
    #349
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I can't remember what I used when I replaced the bearings. Either silicone spray or wheel bearing grease. One is certainly tempted to put something to ease removal next time. If you put grease or anti-seize, use a a very thin amount as some will get pushed into the hub cavity and you want to avoid any risk of the grease coming in contact with rubber/nitrile seals, unless you use a silicon based grease such as Silaramic or SuperLube products (92003, 41160, etc).
  10. Feb 3, 2016 at 10:16 AM
    #350
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    What's better than having the thread.......the man himself.
    I'll just go to tour house and do it there
    :bananadance:
    KenpachiZaraki[OP] likes this.
  11. Feb 3, 2016 at 10:20 AM
    #351
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    nice post! I'll have to do this to my 2000 at some point...this gives me an idea of what Im up against...
  12. Feb 3, 2016 at 6:03 PM
    #352
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    LOL, yea its fun having someone else over who loves tacomas as much as I do. Plus, you get free food! I know I used to be a poor college student.
    FYI, I'll be doing another write up on the Rear wheel bearings and replacing them. I took a whole lot of pictures, I just have to put them in order and write the thread part. Just need the time to do it. Yes you can do the rear bearings yourself. You just need the proper tools.
  13. Feb 3, 2016 at 6:04 PM
    #353
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    I just used regular hi temp wheel bearing grease, nothing special. Unless you have something special...then use that.
  14. Feb 8, 2016 at 5:54 AM
    #354
    Madtown Taco
    Madison, Wisconsin
    So, over the weekend I replaced both front wheel bearings and hub assemblies, both inner and outer bearing hub seals, plus went ahead and installed a pair of raybestos re manufactured calipers, as I had a bad piston on the passenger side. I also installed new oem toyota rotors and pads. I bled each new caliper several times with a Motive brand power bleeder. After burning through two bottles of oem Toyota brake fluid, it's safe to say they are bubble-free.
    To my dismay, my test drive at the end of the work broke my heart. My truck still makes a crappy grinding noise, easiest to hear around 30 mph when going straight, gets a little louder if you turn slightly to the right. The vibration can be felt through the gas pedal when your foot is resting on it going down the road.
    Anyone have any ideas on what to go after next? I'm leaning towards replacing both front CV axles with a new pair from Dallas Toyota, but parts and seals alone are going to run about $800 I think. All I want is to be able to drive down the road and not feel like my truck is grinding itself to bits.
    For what it's worth, my BF Goodrich tires showed some "weird" wear, according to a toyota tech, but still have some tread left on them. I'd like to go another year on those if I could. The noise sounds more like metal on metal than uneven tire wear to me though. I've heard tires with uneven wear can mimic a bad wheel bearing.
    Suggestions?
    Thanks.
  15. Feb 9, 2016 at 2:35 AM
    #355
    CoBackCountry
    CoBackCountry Well-Known Member
    J
    Colorado
    Do yourself a favor and purchase Toyota OEM reman axles from CVJ Axle in Denver, Co. You can have them built with OEM boots or high angle silicone boots, plus they will do the boot slide mod for you when they build them if you specify you want it done. You can get both cv axles with a core charge for about half what Toyota wants.
    http://www.cvjreman.com/
    Nimble9 likes this.
  16. Feb 9, 2016 at 8:06 PM
    #356
    Chuy
    Lakeside, CA
    Silver Taco
    Instead of replacing parts, you need to figure out what is causing the noise. Seek a professional if you can't pinpoint it.
  17. Feb 9, 2016 at 8:35 PM
    #357
    Madtown Taco
    Madison, Wisconsin
    I'm leaning towards letting the dealer have another look at it now that all the parts have been replaced. Just gave them $400 last week for a coolant flush and fill, new plugs, and some diagnosis on the noise. They came back with a $3200 quote for new tires, alignment, caliper, and wheel bearings. I told them to hold off and would tackle what I could on that list at home. I agree, throwing parts at it is not the best fix. I'm just to a point where cv axles are about the only thing left that spins and hasn't been replaced when the truck is in motion and could possibly be the culprit. It always sux to spend money just to get things back to the way they are supposed to be. When you drop big money on something, it's normally for something new and shiny that blows your mind.
    It's nice knowing there are some good re manufactured axles out there though. I was not thrilled at the cost of $450 OEM axles, yet somewhat suspicious of a $60 axle from the big box parts stores. Seems like a good happy-medium if they end up being the issue. We'll see how it turns out tomorrow I guess, hopefully they can get me back in there. Thanks for the replies and advice.
  18. Feb 9, 2016 at 8:50 PM
    #358
    Chuy
    Lakeside, CA
    Silver Taco
    Sorry to hear about your anguish. Hope you sort it out.
  19. Feb 19, 2016 at 8:24 AM
    #359
    Madtown Taco
    Madison, Wisconsin
    So before throwing any more parts on the truck, I decided to take it back in to the dealership to have them take another look at it. I got the truck back from the dealership today. I went ahead and got 4 new tires and an alignment done on it. The alignment results showed some angles way out of whack. I can't remember the last time I had one done. Probably 2+ years. Neglecting this most likely caused all the feathering to the BF Goodrich TA KOs that were on there. $1000 tires down the drain. Yah.
    Anyways, I'm a little scarred from throwing $1000 tires back on there, so I went with some cheaper Cooper Discoverer TA/3s. Size 265/75/R16. They are not quite as aggressive as the BF Goodrich ones, but in the end, with new tires and an alignment, the truck feels and drives a lot better. There is a lot less road noise then the BF tires, which after making an honest assessment of my use of the truck, although they look awesome, I don't need that aggressive of a tire for most of my usage. These are considered "light truck" tires. At this point in my life, with a 1/2 hour commute each way for work, I'll take a smooth quiet ride and look a little more tame versus looking sweet and hating driving my truck around for any length of time.
    I just hope the new tires aren't masking any remaining issues with the front end. So far, so good though. I can live with it as it rides now. I will most likely hold off on replacing the CV axles for the time being, as I don't think there is anything wrong with them and the dealership techs agree.
    So in the last 2 weeks:
    New front calipers
    New rotors
    New Pads
    New front wheel bearings and hubs
    4 new tires
    Alignment
    Hopefully that's it for a few years now........
  20. Jun 27, 2016 at 9:39 AM
    #360
    tan-ishman
    tan-ishman Well-Known Member
    San Diego,CA
    2005 DCSB
    a bunch of new/used parts....and some skids.
    Great Write up! Printed out for my haynes because those pictures are crap!
