How To Remove CV Axle+Replace Front Wheel Bearing 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KenpachiZaraki, Nov 22, 2011.
  1. Apr 8, 2012 at 12:24 AM
    #61
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    And another link with part numbers and diagrams
    http://www.tacomaworld.com/forum/showthread.php?t=202119
  2. Apr 8, 2012 at 12:19 PM
    #62
    BigBro
    BigBro Husband & Daddy ;)
    Carson
    Atlantic Beach, FL
    2005, PreRunner, SR5, Crew Cab, Radiant Red
    Anytime Fog light mod, Rack Mounted OffRoad Lights, Rear Mounted Bed/Reverse Lights, Painted Hood Cover, Painted Lower Front Bumper, Replaced Rear Bumper from chrome to black.
    Thanks both of yall!! Awesome help!! Also..... Should I goahead and replace the cv-axle while I'm in there? How will I know if this needs to be replaced or not, or can I even know before getting it apart?
    Thanks again!
  3. Apr 8, 2012 at 7:44 PM
    #63
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I wouldn't bother with the cv until it starts clicking.
  4. Apr 13, 2012 at 2:26 AM
    #64
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    sub'd good write up. Noticed my boots are starting to go bad. Looks like "dry rot" around the inner boot, so it might go soon. My truck is 4X4 looks like the op has a pre runner, how much different is my set-up with the 4X4? Is the install the same? Going to replace the entire CV axle, I believe it would be better than just doing the boots. Maybe hang on to the bad one and rebuild it just in case.
  5. Apr 13, 2012 at 2:47 AM
    #65
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    I saw the spindles. Didn't think you could put spindles on a 4x4. Sorry it's early, don't know what I was thinking.
  6. Apr 13, 2012 at 4:07 AM
    #66
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Anyone have a Toyota part # for the cv's? Does it come complete with everything to replace (seals, boots, ect)? Just want to be able to get a new assembly and swap it out. I think I want to put OEM parts back on the truck. I can get deals on toyota parts, I just need the numbers first. I've looked for part numbers but I cannot find anything for the whole assembly. I feel like i took stupid pills this morning instead of vitamins and B-12.
  7. Apr 13, 2012 at 6:34 AM
    #67
    KenpachiZaraki
    KenpachiZaraki [OP] Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    You, probably need some ginkobiloba and riboflavin in your diet. And prerunners are 2wd<4wd. I didn't like it teh 2wd, too much herp :laugh: if you don't get those part numbers, I'll look for them later today
  8. Apr 19, 2012 at 4:22 AM
    #68
    SGTBAMF
    SGTBAMF Member
    Northern IN
    2009 Tacoma Double Cab SR5 Flowmaster 40
    Flowmaster 40 Series 2 Chamber 3" pipe, Fog light mod, Key Buzz mod, Seatbelt mod, Raptor Tube Step Black E-Coated
    Is it possible to cut the out cv boot clamps silde the boot back repack slide boot back and reclamp. My outer small clamp slid down the shaft and I lost some grease. I wondered if I can just slide the boot back repack then replace the clamps?
  9. Apr 19, 2012 at 6:44 AM
    #69
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    Sure can, its not going to hurt anything
  10. Apr 20, 2012 at 9:38 AM
    #70
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
  11. Apr 27, 2012 at 9:24 PM
    #71
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    hey folks. i just replaced both front axels and noticed that the driver side has play when I grab it by the differential side, i can pull it maybe 2" away and toward the diff, but the passenger side is solid. is this normal or did i not pound it enough?
  12. Apr 28, 2012 at 10:24 AM
    #72
    KenpachiZaraki
    Alex •﹏•
    Lubbock
  13. Apr 28, 2012 at 10:51 AM
    #73
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    2" :eek:
  14. Apr 29, 2012 at 7:54 AM
    #74
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I figure out folks may want to know this.
    tested yesterday my theory that wheel bearings in Toyota trucks can be re tightened to get them to sit better. So while doing brake job one of the things I did i had tightened wheel bearings and low and behold truck went from squeamish to super tight. I would say done every 30 000 miles would prolong wheel bearings especially for those driving on larger then factory wheels. :)
  15. Apr 29, 2012 at 9:12 AM
    #75
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    Good info, how bout some torque specs? And what kind of beer was involved? :laugh:
  16. Apr 29, 2012 at 6:19 PM
    #76
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    On a prerunner, it should be the same as when originally torqued, 200 ftlb.
    The 4wd is 173 ftlb. Those would be the bearing preload settings.
    PK
  17. May 28, 2012 at 5:44 PM
    #77
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    Subscribed.
  18. Jun 2, 2012 at 9:59 PM
    #78
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I am trying to diagnose something that has just started within the last few days. My truck has 5100's set at 2.5" with stock springs, LR UCA's, and I have done the needle bearing bushing swap in the front diff. I also have hawk brake pads and had the rotors resurfaced. Now to the dilemma.
    I was driving home from work on thursday. I had been driving for about 45 minutes or so. I come to a stop sign and I hear thing rumbling noise. So I turn the radio off and when I come to the next stop, there it is again. It is coming from the front end, it sounds like when you are going down the highway about 70mph and drive over the rumble strips, that vvvvvvv noise, it only comes in at the last 10mph before a stop. It continued to do it at every stop whether strait, turned, up hill or down hill. Tires are not rubbing, they're stock. I jacked the truck on both sides to spin the wheels. The passenger spun pretty freely with only the sound of a little brake pad drag. The driver side was harder to turn, had the same brake drag sound plus another metal on metal sound. So I shook both wheels, no movement or play in either. So grabbed my fiances son who is going to auto school to see if he could be of help, and test drove it. By this time the truck had cooled down over night. It did not make any noises at stops at all, so I drove it for about 5 minutes to warm things up some. Did everything to get it to make noise again and nothing, until I was coming to a stop just before my house, and it made the noise ever so slightly. So it needs to be heated up to make this noise. Also I noticed that when 4wd is engaged, the truck wants to pull to the right. So just to rule out the brakes, I completely removed the brakes and spun the driver side hub. It had more resistance to spin than the passenger side with the brakes still on, and had a metal on metal noise slightly louder than the brake drag. The hub still did not have any movement. I am wondering if it is a wheel bearing about to go bad, or if it is the outer CV. I turned the wheel hard left and hard right and spun it and the CV didn't pop. Any thoughts?
  19. Jun 5, 2012 at 1:37 PM
    #79
    Hard
    Hard Well-Known Member
    H
    4X4X4
    Did you find out what the problem is? I would say bad wheel bearing, sometimes they can fail in ways that dont cause the "play".
  20. Jun 5, 2012 at 1:51 PM
    #80
    brutalguyracing
    F.U> GUYZ
    broken mods
    didnt i just see this someplace else ^^^^
