How to seal bed storage boxes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZachUA, May 1, 2017.
  1. May 1, 2017 at 5:31 AM
    ZachUA
    ZachUA [OP] Well-Known Member
    I just picked up a '17 Tacoma and noticed the little bed storage boxes on the sides have small openings on the bottom that open into the underside of the truck. Has anyone sealed this up?
  2. May 1, 2017 at 5:35 AM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    If you seal the drain holes you should probably also seal the doors.
  3. May 1, 2017 at 5:45 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    EB Group likes this.
  4. May 1, 2017 at 8:51 AM
    micwillia
    micwillia Nonstop Tinkerer
    Cental Masshole
    Turd gen Inferno Taco TuRD OR DCSB 6MT, '96 Mustang V6 Vert 5MT
    Cubby Covers, TRD Pro Exhaust, BAK RevolverX2, Pro Skid, Speaker Upgrade, OBA/W, CB, 255/85R16
    I've been working on something to do this currently. I'm designing some covers that will help prevent water spray from getting in either the small holes in the back and the slots up front.
  5. May 1, 2017 at 9:02 AM
    TacoLpastor
    TacoLpastor Well-Known Member
    NC
    2016 DCLB OR 4X4
    Tuffy has drop in boxes that are larger and sealed.
    BillsSR5 likes this.
  6. May 1, 2017 at 9:12 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Spec please, been looking for this- thanks!
  7. May 1, 2017 at 9:20 AM
    jarvie
    jarvie Well-Known Member
    On the Road... Mostly Utah
    2016 Black Tacoma
    A.R.E. CAP + Custom Storage System
    I took off the doors and taped up the holes. there's some other holes in the bed I think i found most of them.
    I wasn't worried about draining water since I have an A.R.E. shell. and a storage system so I wasn't gonna be opening and closing those compartments anyway.
    AKGSD, copsnok, PlankRider6 and 2 others like this.
  8. May 1, 2017 at 9:27 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    copsnok likes this.
  9. May 1, 2017 at 9:33 AM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Tn Jeff likes this.
  10. May 1, 2017 at 9:48 AM
    micwillia
    Cental Masshole
    These are what I have but, the holes/slots in the box still need to be covered. Hopefully I'll be able to give a nice cheap option for the extras soon.
    tomwil[QUOTED] likes this.
  11. May 1, 2017 at 9:55 AM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    In the meantime, I just used silicone caulk.
    Looking forward in what you come up with, that should be a more elegant solution.
  12. May 1, 2017 at 10:22 AM
    micwillia
    Cental Masshole
    That will definitely do the trick for now; did you only use that on the small holes and not the slots?
    I'm not sure if elegant will be the right word but, maybe cleaner
  13. May 1, 2017 at 10:36 AM
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
    this has been a concern of mine also. I'll take some measurements tonight. Maybe I can come up with some 3d printed parts in ABS that can be glued in place to seal the holes. Essentially make little pockets for the tabs to drop into and lock in, rather than openings.
  14. May 1, 2017 at 11:41 AM
    micwillia
    Cental Masshole
    Haha I'm a step ahead of you, just need a revision or 2 to get the angles right and they'll be done. There are some funky angles to work with under there.
    cafereef[QUOTED] likes this.
  15. May 1, 2017 at 11:46 AM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
  16. May 1, 2017 at 11:48 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    I put my stuff in gallon zip lock bags then throw it in the cubby.
    shakerhood and boynoyce like this.
  17. May 1, 2017 at 12:01 PM
    protaxidermist
    protaxidermist Well-Known Member
    North Carolina
    Flex seal some metal screan wire.
    Shape the metal screan to fit then cover it with Flex seal or good spray on under coat let dry.
    Spray Flex seal on to area to be covered and use it like glue.
    Spray on more as needed.
    strivingmind likes this.
  18. May 9, 2017 at 7:48 PM
    micwillia
    Cental Masshole
  19. Oct 24, 2018 at 4:01 PM
    strivingmind
    strivingmind New Member
    Scott
    2018 Tacoma
    micwillia....
    Will these seal kits you are offering fit in a 2018 Tacoma?
    I am needing a set for both sides of the truck.
    Thanks for your help.
  20. Oct 24, 2018 at 4:32 PM
    micwillia
    Cental Masshole
    TAC1 likes this.
