How To: Spark Plug Change (1 GR-FE)
Discussion in 'Technical Chat' started by chris4x4, Mar 16, 2009.
  1. Apr 19, 2015 at 8:47 PM
    #1541
    clownbear69
    clownbear69 Active Member
    Joseph
    Gallup NM
    2012 Toyota Tacoma TRD
    Not sure if this will be useful to any of you knowing that many of you use OEM but it may be useful to someone (and not sure its in the last 77 pages). So at work I wrote the compatible spark plugs for my taco (2012 V6). I also listed prices and years on warranty. (Side not this list is to be used as a reference not gospel prices and possible part numbers might be different in different regions and stores) information came from the O'Rielly's system All plugs needing gapping said to be at .44 gap
    Autolite Copper Core #5325 $1.99/plug 2 year warranty
    Bosch Fine Wire Platinum (DO NOT GAP) #6731 $2.99/plug 3 year warranty
    Autolite Platinum #AP5325 $3.29/ plug 4year warranty
    Champion Double Platinum #7975 $3.99/plug 5 year
    Autolite Double Platinum (OE Style) #APP5325 $4.49/ plug 5 year
    Bosch Fine Wire Double Platinum (DO NOT GAP) #8122 $4.99 6 year
    NGK V-Power Nickel (LFRC-11 OE Style) #7787 $5.49 1 year
    AC Delco Professional Platinum #41-835 $5.99/plug 100,000 mile
    E3 Diamond Fire (DO NOT GAP) #E3.68 $6.09/plug 5 year
    Autolite Iridium XP #XP5325 $6.99/ plug 7 year
    Bosch Fine Wire Iridium (DO NOT GAP) #9613 $6.99 7 year
    NGK G-Power Platinum #1483 $7.99/plug 1 year
    NGK Iridium IX #6619 $8.29/plug 1 year
    NGK Laser Iridium #4904 $9.99/plug 1 year
    Hope this helps anyone or just was curious on it. There was special order plugs but I declined to tally those up due to lack of price and warranty
    squint0241 likes this.
  2. Apr 20, 2015 at 6:20 AM
    #1542
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    cool, thanks!
  3. Apr 20, 2015 at 12:24 PM
    #1543
    Effenglide
    Effenglide Well-Known Member
    Effen
    Montana
    2015 TRD Sport DCLB
    Here we go again!
    Just called my local dealer and they quoted $8.95 per plug for Denso. Seems pretty steep. Where's the best deal at? Amazon?
  4. Apr 20, 2015 at 12:51 PM
    #1544
    AusRunner
    AusRunner Well-Known Member
    Las Vegas, NV
    2021 TRD Off Road 4X4 DCSB - Cement
    as an afterthought, I read up on the process and saw there there are a lot of strong feelings about whether or not to use anti-seize on the plugs. Some say it's helpful while others say never use it on modern engines as it can cause issues. The walktru said to use it so I did. I was wondering what other's feelings are on the use of anti-seize.
  5. Apr 20, 2015 at 3:40 PM
    #1545
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    $3.80 ea on Amazon and free ship with Prime and $25 order.
    I've seen lower plus shipping so that's why I went with Amazon and just added a OEM oil filter to get free shipping.
  6. Apr 20, 2015 at 4:55 PM
    #1546
    CED17
    CED17 Well-Known Member
    Canada
    2007 TRD Sport
    Based partially on the fact that your threading two dissimilar metals together, and a story told to me by my trade school teacher (millwright) about problems with the plugs basically welding themselves into the aluminium heads or galling on alot of f150s he knew about. I usually use a very small amount of anti sieze being very carefull not to get it near the electrode. however i didnt think about the reduced torque which makes sense wet torque / dry torque :facepalm:. I have had no issues and have been changing my own from the second set on, dealer did the first set. im at 197000 kms
    that being said the ford issues were largely due to not replacing the spark plugs at recommended intervals and leaving them in way to long. the other point to his story was how much of a bitch it was to get a broken spark plug out of an enginge that you need a long extension or special ford wrench just to get a socket on,partial engine dissassembly required. You will probably never have an issue not using anti sieze as long as you change them at recommended intervals, but on the other hand you shouldnt have any issues using anti sieze either if you do it correctly. just my 2 cents
  7. Apr 20, 2015 at 5:19 PM
    #1547
    CED17
    Canada
    2007 TRD Sport
    :thumbsup: agreed, putting a small amount on gives me piece of mind i guess, but probably not necessary as i change them when toyota says i should.
    i didnt know ford made a kit lol, i havent owned one since 1995.
  8. Apr 20, 2015 at 7:25 PM
    #1548
    Effenglide
    Effen
    Montana
    2015 TRD Sport DCLB
    Here we go again!
    Are all the Denso plugs u-groove?
  9. Apr 20, 2015 at 8:36 PM
    #1549
    scrubby510
    scrubby510 Well-Known Member
    Nor Cal
    S/C '12 DCSB OFF-ROAD & ‘24 DCSB OFF-ROAD
    TRD s/c, DT shorties, 6" Pro Comp Stage 2, 5034 Rockwells on 35s, skid plate, tint, Morimoto D2S retrofitted headlights, 6k HID, Switchback DTRL, Walbro 255 lph fuel pump, URD 2.85 pulley, URD MK3 catback exhaust, debadged, ND4's anytime foglight mod, 6" Alcans… ‘24 OR work in progress.
    sub'd for future reference. This is a great write up. Thank You!
  10. Apr 22, 2015 at 2:48 PM
    #1550
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    Great write up. Clear and concise. Just changed mine. I will add that a breaker bar (the one in the photo was Kobalt brand from Lowes) was essential for the leverage and the pivoting head particularly an the drivers side where space was tight. I could make half revolutions and rotatable it around, which made quick work removing and replacing the plugs.
    For the middle plug on the drivers side, be sure to move all the hoses out the way by disconnecting. It may seem like you don't have to but that is where you are most likely to strip the threads when screwing the plug in, due to the slight sideways pressure the middle hose puts on your tool.
    The most rearward plug on the passenger side had some corrosion on the nut part of the plug, as seen in photo. Anyone know why, and is this something I need looked at?
  11. Apr 22, 2015 at 2:51 PM
    #1551
    novataco
    NOLA
    06 Sport V6 auto
    Tools with the breaker bar
  12. Apr 22, 2015 at 3:58 PM
    #1552
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    I like those...going to order them. Thanks
  13. Apr 22, 2015 at 4:03 PM
    #1553
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    x2
  14. Apr 22, 2015 at 5:50 PM
    #1554
    calico
    calico Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
  15. Apr 22, 2015 at 7:48 PM
    #1555
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
  16. Apr 22, 2015 at 11:03 PM
    #1556
    novataco
    NOLA
    06 Sport V6 auto
    Thanks. That was what I was deducing because the rust was on the part of the plug you see, not downward by the gap, where everything seemed consistent with the other plugs. I wiped off any dust from the corrosion off of the coil, and will re-check in a couple weeks. I assume the seal is a part you can buy separate from the coil, if necessary.
  17. Apr 23, 2015 at 6:40 AM
    #1557
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I use a deep 16 socket, and extension, and use a thin strip of gorilla tape
    over the lip of the socket and this hold the plug in the socket via friction.
    then twirl it by hand to start thread and keep using fingers until gasket touches
    then get the torque wrench and crank it the rest of the way until 'BEEP'
  18. Apr 23, 2015 at 7:21 AM
    #1558
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    'beep' you fancy sir.
  19. Apr 23, 2015 at 9:52 AM
    #1559
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    just replaced my first set on the Taco, it has 82K miles so i wasn't sure if they had been replaced or not as i'm the 2nd owner.
    i was pleased to see there were all Denso's so that tells me they are not original. In fact, they really didn't look too bad. I'd guess maybe only 30-40k miles worth.
    This was a very easy job, I'm a novice a wrench turner and took me only 60 minutes. My only mini hang up was get the harness to snap back on the the coil closest to the bumper (driver side). That's a tight squeeze!
  20. Apr 23, 2015 at 1:31 PM
    #1560
    Tacotrd311
    Tacotrd311 Well-Known Member
    Completed this today, thanks for the write up! Very easy to follow.
