How to: Wire a Stock Auto-Dimming Mirror
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jefferson, May 27, 2010.
  1. May 27, 2010 at 6:57 PM
    jefferson
    jefferson [OP] needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    Here I will show you how to wire a stock auto-dimming mirror to your Tacoma.
    What is needed:
    First - with the way I've written this, you'll need to have a Tacoma with any type of overhead console. Whether that be one with a temp/compass or one with the garage door opener. Either way, if you don't have one (single cab owners) you could still use this as a guide.. but it wont be very helpful ;)
    Second - a beer
    Third - your stock Tacoma auto-dimming mirror. The Toyota auto dimming inside rearview mirror is made by Gentex and sold through Mito Corp. Model #50-GENK2A. [​IMG] ($65-80 new) (thank you Pster!)
    I've seen them for sale on TW's Buy/Sell/Trade a million times.. take a gander or view Ebay. Usually can find them around for about $50.
    Fourth - some wire (preferably black and red for ground and switched power, about 6 inches or so), pin connectors for the back of the mirror, and some wire taps:
    You'll only need two. Here is a picture of four. Good times.
    Fifth - some hand tools. I'll explain as we go.
    So lets begin:
    First - lets take off our stock mirror:
    Its a piece of junk - feels like it cost about $0.10 to make. Keep it, throw it away, snort coke off it - whatever. I threw it away.
    How you take it off - just pull up towards the headliner.. it doesn't have any screws or anything. Just use some force. DO NOT pull out towards you or push in. you will break something. Just pull up and it will give.
    As you can see, from under the connector its just a press fitting. You'll be fine.
    Second - work on your new mirror. There are four connectors on the back of the mirror. If you're not wiring a backup camera (this one does not have that ability) then all you'll need are two of the four connectors. The one closest to the adjuster is your positive (power), and the one next to the positive is your negative (ground).
    (dig mspaint)
    Now what we wanna do is get a wire connector and a wire attached to those two poles. Your local Radio Shack has them. I'd suggest taking the mirror to Radio Shack to pick out the connector that works for you. Radio Shack employees know just about as much about electronics as my dog does.
    and attach your correctly colored wires to the connectors:
    Obviously again, red for power and black for ground.
    Third - Lets attach the mirror to the truck. With the stock auto-dimming mirrors you'll need a hex tool. I forgot which one it is, but if you have a set, it's one of the smaller guys.. ;)
    Slide the mirror onto the metal connector on the windshield (duh) and let the wires hang for now.
    Fourth - We need to take our over head console down. If you need detailed instruction how to do so, click on my link here and scroll to half way down the first post.
    Fifth - with the center console down, locate the plug for your Temp/Compass. If you do not have a Temp/Compass and have a garage door opener instead; it does not matter. The plug will be there above your garage door opener. All we need are the wires before the plug.
    Sixth - Thread your red and black wires from your mirror under the headliner next to the windshield under the headliner where the plug is located. (I also cut the sheathing around the wires to give myself more room to use the connectors. I think this is probably necessary)
    We are now ready to use our wire taps and connect our positive (power/red wire from mirror) and our negative (ground/black wire from mirror) to the plug pictured above.
    Seventh - Diagram goes as following:
    Light Green Wire = Switched Power (attach your red wire using a wire tap to this wire)
    Black Stripe/White Wire = Ground (attach your black wire using a wire tap to this wire)
    NOTE: There are TWO green wires. One dark, one light. Make sure you use the light green wire!
    Eighth - put the plug back where you found it (either clipped to the garage door opener or plugged back into the temp/compass) and re-install your overhead console. (don't forget to put back that little Philips head screw!)
    Ninth - Turn on that key! You should get a green light on the mirror if everything is hooked up properly. If not, press the "auto" button and see if it lights up. If that doesn't work, recheck your steps and make sure everything is plugged up properly. (Oh.. and make sure you're reading a temp as well ;) )
    How to check if your mirror is functional:
    1. Put your thumb over the IR sensor on the back of the mirror
    2. Shine a flashlight on the front IR sensor on the front of the mirror
    3. Observe. It should slowly but surely dim out. Be patient.. it takes a moment.
    Please feel free to contact me through PM if you have any questions.
    kmbldr and TacoLou like this.
  2. May 27, 2010 at 7:01 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    good job, thomas!!:thumbsup:
  3. May 27, 2010 at 7:01 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Anytime ;)
  4. May 27, 2010 at 9:26 PM
    Tracy
    Tracy The Silver blurr...
    TRACY
    SoCAL. IE, SGV, LA. :D
    '08 TRD Sport Edition PreRunner
    Chrome tube steps. Because a lady needs a help up when wearing a dress. :)
    ibf, why are you so smart? can you figure out how to auto lock my truck??? :D
    so i don't think i have that same mirror and when can you and i have a mod day so we can also do the bed lamps and everything else. :D
  5. May 27, 2010 at 9:28 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    thanks! Yah, mine isnt a TRD.. so i'm slowly making it a TRD...
    OH i think its in your manual.. and yes we can make your bed lamps work next mod day :)
  6. May 27, 2010 at 9:47 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    yup. took maybe 30 mins tops.
  7. May 27, 2010 at 9:54 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Thanks! Good call!
    Just came back from the store and the mirror worked great! I need the little clip to hide the wires, and then it'll be factory.
  8. May 27, 2010 at 9:56 PM
    JTaco386
    JTaco386 Well-Known Member
    JT
    San Antonio, TX
    13 DCSB TRD Sport 4x4
    Is there a cover that can be used to cover up the wires?
  9. May 27, 2010 at 10:00 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Yes. i have to locate one and i'll update the first page. It clicks into the top of the mirror's connector and then snaps into a dent in the headliner. Next time you get in your tacoma, feel for it; you'll see what i mean.
  10. May 27, 2010 at 10:35 PM
    JTaco386
    JT
    San Antonio, TX
    Thanks! I know what you mean. Great write up! Now I need to find me one of these mirrors a a decent price
  11. May 27, 2010 at 10:38 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    do a search for "auto dim mirror" someone was selling one a while back and wasnt successful. shoot that guy a pm and see what they'd take! :D
  12. May 28, 2010 at 12:20 AM
    ten80
    ten80 Active Member
    Christophe
    AK
    SR5
    cmack, which mirror did you get?
  13. May 28, 2010 at 4:11 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Nicely done! :thumbsup:
  14. May 28, 2010 at 8:03 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
  15. Jun 5, 2010 at 11:17 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    EDIT:
    Made the some of the descriptions clearer..
  16. Sep 1, 2010 at 2:16 PM
    Twirlin
    Twirlin Nature just gets the blow-by
    WI
    '10 TRD Sport Mag Grey
    perfect, I'm gonna use this as a guideline to hardwire my radar detector.
  17. Sep 1, 2010 at 2:17 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Glad i could help! Its good knowing where switched power and ground wires are... Dangerous too (i tend to wire in a buncha crap to my cars all the time..)
  18. Sep 1, 2010 at 2:34 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Awesome, I was waiting years to see this post! Now....doesn't Toyota sell a wire with connectors so you could side step a lot of the wire steps and have a little easier idiot proff connection?
  19. Sep 1, 2010 at 2:40 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    oh sure.. there is a plug that goes in there with two wires coming out. I wanted to show how to do it without the plug just in case (if youre like me) and you dont have everything.. :)
    Canyon lands likes this.
  20. Sep 1, 2010 at 2:44 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I assumed as much Jeff.....many, many thanks! Looking for one now....
    Mojorod and Canyon lands like this.
