How To Wire Neatly?? For a couple Electric Accessories. Help and Advice Needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyleTRDtaco12, Jun 16, 2015.
  1. Jun 16, 2015 at 1:43 PM
    kyleTRDtaco12
    kyleTRDtaco12 [OP] Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    hello everyone, I am about to be buying some (i guess simple?) electrical accessories for my Tacoma at the end of the week and I am a complete wiring noobie and the thought of messing with electricity is just daunting to me (i know to disconnect the battery before touching anything, thats a given). I am actually going against my better judgement of not ever tampering with my vehicle's wiring but i really would like to have these upgrades. Anyway.. I'm in the market for a pair of Westin offroad driving lights (to go along with a westin off road light bar) and a pair of hella supertone horns. Both accessories come with relays and I would like to know if there's anything i can do, or buy to make things under the hood look neat and clean and practically factory? or is there any practices to employ like the use of slip connectors to make everything so that at any point it could be fully reversed back to stock? Any tips, tricks or products are welcome. thanks a bunch in advance.
  2. Jun 16, 2015 at 1:55 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    kyleTRDtaco12[OP] likes this.
  3. Jun 16, 2015 at 1:58 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
  4. Jun 16, 2015 at 2:06 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    very cool! alright great, some fun reading, thanks guys :) that project box is really nice!
  5. Jun 16, 2015 at 2:06 PM
    ErocksTaco
    ErocksTaco Well-Known Member
    Eric
    Denver
    06 4x4 DCSB Sport Radiant Red
    OME 886 and rear Dakars Light Racing Upper Control Arms All pro U-bolt flip with Timbren Bump Stops CVJ Reman axles with off road boots Adventure Offroad Fab Sliders ARB Front Bumper Interior LEDs Weathertechs 2009+ taillights 2009+ headlights
    I like to use heat shrink at connectors and such... Gives a nice clean appearance and keeps dirt out of connectors
  6. Jun 16, 2015 at 2:09 PM
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    Definitely use heat shrink, whether you use solder or crimp connections (use solder where possible I would suggest). Loom and zip ties are a good easy way to keep the wires routed where you want them. I would also suggest following the path of preexisting wires when routing the new ones, if possible.
  7. Jun 16, 2015 at 2:11 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    if im not mistaken, i believe the driving lights come with a nice weather proof harness. if anyone is experienced with westin products, id like to know if there is a switch i could buy that could go and fit nicely in an existing dummy slot? because it does come with a switch but i believe its a universal switch
  8. Jun 16, 2015 at 2:12 PM
    Sig45
    Mark
    Maine
    I also tossed all the wiring and the relay that came with my hella lights and bought all new. I used heat shrink connectors and tubing for my connections. Here's a pic of some of the wires. May be overkill, but they'll never fail due to moisture.
  9. Jun 16, 2015 at 2:30 PM
    MDB Taco
    GA
    ‘05 TRDOR DC
    Assuming the Westin harness is wired like most other harnesses, the switch just has some spade connectors on the back, so you can swap it out for any switch you want. I use one of the oem rocker switches that a lot of other members use (oem toyota, but not from a tacoma). I'll try to dig up the part number in a little bit. It fit in the bank under my e-locker with very minimal trimming.
  10. Jun 16, 2015 at 2:31 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    alright cool, that would be fantastic if you could find the p/n . thank you!
  11. Jun 16, 2015 at 2:35 PM
    MDB Taco
    GA
    ‘05 TRDOR DC
  12. Jun 16, 2015 at 2:36 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    VERY NICE!! thank you for digging, i do appreciate it :)
