HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Sep 30, 2019 at 11:53 AM
    #4601
    nihil
    nihil Well-Known Member
    Is there documentation available on the process? I'm no stranger to writing firmware for embedded devices or writing other software, but these newer generation ECUs are new territory for me, I usually play with older stuff. Maybe a few pointers from someone who has done these already? :) I'm not looking to make money or take business from anyone, my day job keeps me plenty busy.
  2. Sep 30, 2019 at 12:35 PM
    #4602
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I 100% commend you for wanting to venture down this path! I'd love to see someone like yourself develop some open source stuff.
    Unfortunately, I'm not your guy for the communication protocols. I'd love to follow your progress if you're able to get the info you need. So please keep us posted.
  3. Sep 30, 2019 at 12:58 PM
    #4603
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello, I found the ECM's part # for my '15 TRD O/R DCSB 4WD, it is P89661-04J80. I also found a used ECM with the same part # on partsmarket.com. It costs $185. If I order this ECM as a back-up (or maybe get both ECM's tuned) & I need to use it will it simply be plug-n-play?
  4. Sep 30, 2019 at 1:01 PM
    #4604
    JustDSM
    Justin
    Ogden, UT
    Check www.car-part.com too (but they're probably pulling data from the same place..)
    Anyhow, If you get the same ECU, with Techstream/VIN Update Wizard you can set the VIN in your new junkyard ECU to match your truck and you can tune both ECU's and each ECU will be plug-n-play (with the exception of the immobilizer sync process which involves a paperclip and 30min of your time) allowing you to swap back and forth.
    Norton and TAC1[QUOTED] like this.
  5. Sep 30, 2019 at 1:21 PM
    #4605
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Cool. I have read about the paperclip thing as well. Pretty creative.
    JustDSM[QUOTED] likes this.
  6. Sep 30, 2019 at 1:25 PM
    #4606
    JustDSM
    Justin
    Ogden, UT
    Norton likes this.
  7. Sep 30, 2019 at 1:34 PM
    #4607
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
  8. Sep 30, 2019 at 1:42 PM
    #4608
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Immobilizer sync is pretty easy, just need to jump two pins on the OBD connection and leave the truck on for no shorter than 30min while its jumped. Post 330 USED to have the information, but either things got deleted before it, or the post itself got deleted.
    12TRDTacoma likes this.
  9. Sep 30, 2019 at 2:05 PM
    #4609
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Thank you!
    Thank you again!
  10. Sep 30, 2019 at 2:42 PM
    #4610
    nd4spdbh
    SoCal
    AHAAAAA, it WAS post 330... just not post 330 in this thread.... derp.
    12TRDTacoma, JustDSM and jojotoo like this.
  11. Sep 30, 2019 at 6:13 PM
    #4611
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    @Coot83 you can find and ask all your tuning questions here. This is where all the gurus hang out. And for a small few @JustDSM will help build a custom tune for you, and @nd4spdbh can help dial in the auto transmission tuning side of things.
    Sorry you two, he’s probably gonna have lots of questions. Though hopefully I’ve already answered some for him.
    Coot83 likes this.
  12. Sep 30, 2019 at 7:46 PM
    #4612
    Matt_DCSB
    Matt_DCSB Well-Known Member
    NM
    I'm super late to this party but I'm about to purchase a HP Tuner for an LS engine swap into a C10 so I may as well do the Taco also. Are there tunes posted somewhere or is everybody winging it? I'm sure its been covered but the thread is 231 pages long and I should be getting ready for bed.
  13. Sep 30, 2019 at 7:55 PM
    #4613
    JustDSM
    Justin
    Ogden, UT
    I have tunes available for $50. Includes the base file and support thereafter to further refine or tweak for future upgrades. @nd4spdbh does the trans stuff which is public.
  14. Sep 30, 2019 at 8:03 PM
    #4614
    Matt_DCSB
    NM
    Awesome! So I send you $50 and you send me a file for when I get the tuner? Thats easy enough.
    What does your tune provide? I'm just hoping to adjust the throttle input and do away with emissions stuff if I can. Which I can probably figure out on my own. I have a 2012 and have already been through the air injection fiasco. Better mpg would be a plus.
    Thanks for responding so quickly.
    12TRDTacoma and JustDSM like this.
  15. Sep 30, 2019 at 8:15 PM
    #4615
    JustDSM
    Justin
    Ogden, UT
    I'll send you a PM with the details. The tune will come with revised throttle mapping, ACIS, VVTi, Ignition and Fuel mapping changes. I can also throw in ND4's superb v11 transmission tuning if you're auto or reduce/remove rev-hang if you're a manual trans guy. Most users see between 1-3mpg improvements.
    The tune file and future support are included in that price. I'll send you a PM with some info on the other stuff :)
  16. Sep 30, 2019 at 8:41 PM
    #4616
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    This is why you’re the man!!!
    Need to stop working on my truck so I can enjoy it some more.
  17. Sep 30, 2019 at 8:42 PM
    #4617
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    OOOOOOHHH! That sounds great!
  18. Oct 1, 2019 at 4:41 AM
    #4618
    Matt_DCSB
    NM
    Hell yes, you talked me into it. I'm in.
    Man that is awesome. I'll be in touch once I get the tuner in hand.
  19. Oct 1, 2019 at 5:04 AM
    #4619
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    It's a bargain! You'll be stoked.
  20. Oct 1, 2019 at 7:38 AM
    #4620
    nd4spdbh
    SoCal
    Haha, no biggie! The more people out there with this stuff the more feedback / data / support we get!
