HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 18, 2019 at 5:48 PM
    #1241
    ThomasMore66
    Dallas/Fort Worth & Durango
    Hmm. Will my Tacoma notice the difference? Maybe we should talk about what is limiting RPM and address that first. Rods? Valve springs?
  2. Apr 18, 2019 at 5:54 PM
    #1242
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    That's right. We are talking about FIC. http://fuelinjectorclinic.com/
    So far we have 6 people interested. Anyone else?
    rockporttaco and Roostfactor like this.
  3. Apr 18, 2019 at 5:54 PM
    #1243
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Rods, with boost, on these engines. As an auto, you don't really have to worry about over revving. So that helps prevent valve train related consequences.
  4. Apr 18, 2019 at 5:59 PM
    #1244
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    N/A, you can push it to 6200 day in and out, as long as the tuning is good.
    Biscuits, Roostfactor and loginfailed like this.
  5. Apr 18, 2019 at 6:01 PM
    #1245
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Do the stock cams choke it off up there (assuming the stock manifolds aren't choking it off)?
  6. Apr 18, 2019 at 6:02 PM
    #1246
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Might soon be time for me to start looking for a project long block.
  7. Apr 18, 2019 at 6:03 PM
    #1247
    JustDSM
    Justin
    Ogden, UT
    I was on car-part.com today and was a little surprised at the going rate for 1GR-FE's!
  8. Apr 18, 2019 at 6:07 PM
    #1248
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    High or low?
  9. Apr 18, 2019 at 6:07 PM
    #1249
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  10. Apr 18, 2019 at 6:10 PM
    #1250
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Not that bad in the big picture.
    12TRDTacoma likes this.
  11. Apr 18, 2019 at 6:11 PM
    #1251
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Roostfactor likes this.
  12. Apr 18, 2019 at 6:12 PM
    #1252
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  13. Apr 18, 2019 at 6:27 PM
    #1253
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    In
    loginfailed[QUOTED] likes this.
  14. Apr 18, 2019 at 6:31 PM
    #1254
    ThomasMore66
    After seeing the prices of the injectors, new rods seem, maybe, a better use of funds?
    loginfailed likes this.
  15. Apr 18, 2019 at 6:55 PM
    #1255
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Looking through the first few dynos here
    https://www.tacomaworld.com/threads/n-a-power-gains-dynos-w-mods.229882/
    They look to stay fairly flat at that end.With consideration to the complementing supporting mods.
    I cannot remember exactly, but I believe that the OEM valve springs are rated to 6600 or 6700 RPMs.
  16. Apr 18, 2019 at 6:58 PM
    #1256
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  17. Apr 18, 2019 at 6:59 PM
    #1257
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Why not both? :D
  18. Apr 18, 2019 at 7:03 PM
    #1258
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I know I need to catch up here. What's the hp tuner cost? And said injectors?
  19. Apr 18, 2019 at 7:06 PM
    #1259
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    MPVI2 with credits to tune one Tacoma is $750 for pro version or $500 for standard. Pro version adds abilty to log external sensors.
    Injectors, shooting for sub $500. The more who commit ordering a set, the better chance we can get a deal on price.
    Roostfactor and 05Taco4x4 like this.
  20. Apr 18, 2019 at 7:09 PM
    #1260
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Okay, so 500 is much more reasonable. I thought it was 1300-1500...
    I’m in.
