HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 19, 2019 at 11:26 AM
    #1421
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    loginfailed likes this.
  2. Apr 19, 2019 at 11:27 AM
    #1422
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    No problem, it was sourced by the great @loginfailed. I suspect he'd have the N/A listing or know where to find t very quick like.
    Aside from that, I have calibrations for most years of trucks after 2011. I can see what they were.
  3. Apr 19, 2019 at 11:48 AM
    #1423
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    $50 is a bargain for the amount of time @JustDSM spent with me. Equally a bargain for the smooth and strong running tune. I only have Scan Guage numbers to compare and not enough time logged for a concrete estimate, but I already expect to be making the money spent on tuning in fuel savings within the first year, not to mention having a truck that runs better and is more fun to drive. Win/Win.
    kgamsg, nd4spdbh, Roostfactor and 3 others like this.
  4. Apr 19, 2019 at 12:43 PM
    #1424
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The N/A calibration IDs are in that document in the "Target ID" column.
    https://www.tacomaworld.com/threads/hp-tuners-for-2005-2015.600793/page-23#post-20311084
  5. Apr 19, 2019 at 12:45 PM
    #1425
    JustDSM
    Justin
    Ogden, UT
    loginfailed[QUOTED] likes this.
  6. Apr 19, 2019 at 1:04 PM
    #1426
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Well, you gave me something to do to feel useful, haha.
    JustDSM[QUOTED] likes this.
  7. Apr 19, 2019 at 1:20 PM
    #1427
    ThomasMore66
    Dallas/Fort Worth & Durango
    Writing my second @Roostfactor inspired file! This is so cool.
  8. Apr 19, 2019 at 1:20 PM
    #1428
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  9. Apr 19, 2019 at 1:28 PM
    #1429
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Amazon has one less in stock... :anonymous:
  10. Apr 19, 2019 at 1:36 PM
    #1430
    ThomasMore66
    Add me to the list. @Roostfactor shamed me.
  11. Apr 19, 2019 at 1:43 PM
    #1431
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I fully concur!!! $50 for a refined tune is unbelievable!
  12. Apr 19, 2019 at 1:44 PM
    #1432
    Lthompson
    Lthompson Well-Known Member
    What size injectors and such? What do we need to actually make use of them? Do I need them? Do I want them?
  13. Apr 19, 2019 at 1:45 PM
    #1433
    Roostfactor
    TX panhandle
    Did the "Teamviewer" thing with @ThomasMore66 a little while ago. Looking forward to his remarks. All we changed is:
    Throttle map
    Speed limiter
    tire size
    and a couple other things
  14. Apr 19, 2019 at 1:46 PM
    #1434
    JustDSM
    Justin
    Ogden, UT
    That'll get his mouth watering!
  15. Apr 19, 2019 at 1:48 PM
    #1435
    Roostfactor
    TX panhandle
    Absolutely!
    5thGearPinned likes this.
  16. Apr 19, 2019 at 2:23 PM
    #1436
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    @loginfailed
    @Roostfactor
    @JustDSM
    @TRON
    @GT7
    @jojotoo
    @JacksonTacoma
    @zippsub9
    @White lightning boosted
    @Wild Heart
    @DocME
    @5thGearPinned
    @617mike9c1
    @Murphinator
    @ThomasMore66
    He is good at that, ain’t he?!
    As of now, I’ve only asked for quotes for 525cc, 640cc, 775cc and 1000cc. If anyone needs a different size, I’m sure they can accommodate us if it is a size they offer.
    Biscuits and Roostfactor like this.
  17. Apr 19, 2019 at 2:27 PM
    #1437
    ThomasMore66
    Definitely snappier! Way too much traffic at the moment to explore my new changes. However, it’s so easy to make changes. If you’re on the fence do it!
  18. Apr 19, 2019 at 2:36 PM
    #1438
    Lthompson
    I just don’t know that I would ever need more than the 455s supplied with the kit per say, unless they are maxed out pretty quick. But as said I’m not looking to get over 8 or 9 lbs with It. Smallest pulley I’d run would be 2.7.
    JuanitoBonito and Norton like this.
  19. Apr 19, 2019 at 2:42 PM
    #1439
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    Me I’m in
  20. Apr 19, 2019 at 2:44 PM
    #1440
    ThomasMore66
    We all said that once.
    Roostfactor and 5thGearPinned like this.
