I am such an idiot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LTC Taco, Feb 4, 2012.
  1. Feb 4, 2012 at 12:01 PM
    LTC Taco
    LTC Taco [OP] Member
    I was trying to take off a blindspot mirror the size of Texas the previous owner had on the truck. Half-way through removing the near weld-like adhesive tape the lower edge of the mirror cracked.
    How hard is it to take off the mirror to replace it?
  2. Feb 4, 2012 at 12:04 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
  3. Feb 4, 2012 at 12:04 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    1st gen or 2nd gen?
  4. Feb 4, 2012 at 12:11 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Next tine its called goof off work's to take off almost anything... Jim
  5. Feb 4, 2012 at 12:22 PM
    LTC Taco
    the previous owner put one on the passenger side too. I may need to adapt to it and just leave it alone.
  6. Feb 4, 2012 at 12:28 PM
    jandrews
    '09 FourDubDee TRD OR
    Replacing the entire mirror assembly is no big deal, but it's a relatively expensive part. If you're looking to replace just the mirror itself in the assembly, that's a different story...
  7. Feb 4, 2012 at 12:29 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Put on 2012s with signals
  8. Feb 4, 2012 at 12:45 PM
    LTC Taco
    that is what I want to do. I can live with the lower edge being cracked for a while but eventually I will replace the mirror.
  9. Feb 4, 2012 at 12:49 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    You might try heating it up to loosen the adhesive...
  10. Feb 4, 2012 at 1:09 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  11. Feb 4, 2012 at 2:55 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    Next time dont pry - use fishing line and cut through it, then take the leftover adhesive and remove it with goof-off or whatever similar adhesive remover.
  12. Feb 4, 2012 at 2:57 PM
    LTC Taco
    very good idea
  13. Feb 4, 2012 at 3:02 PM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
