i have a problem with my compass and temperature.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06WHITETRD, Nov 2, 2008.
  1. Jun 27, 2010 at 7:11 PM
    Piscatore
    Piscatore New Member
    James
    Littleton, Colorado
    07 4WD Sport
    My 07 display went out, so I googled Tacoma Temperature & Compass Display and it led me to this thread! What an awesome site! My 510 chip connections looked fine, but since the display wasn't working anyway, I gently re-soldered all of them and Viola! the display now works like a charm! Thanks so much!!!:)
  2. Jun 27, 2010 at 7:41 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Sam's isn't working in her 06 either. I told her to take it in for warranty but she hasn't yet
  3. Jun 27, 2010 at 8:40 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/18497-overhead-compass-temp-fix.html
    Here's the link. I've used this guide to fix a couple of Tacoma's at the used car dealer I work at. Worked everytime. Just be patient and sometimes you have to try it a couple of times before it will work. It was nice to practice on some trucks that were not mine so I can fix mine when it does break.
    Not trying to be an a$$, but search is a wonderful function. :facepalm:
  4. Jun 28, 2010 at 10:20 PM
    Sniper#830
    Sniper#830 Active Member
    Paso Robles, CA
    2017 Toyota Tacoma / 4x4 / Off Road
    Follow the fix it yourself thread and it will be good as new. Mine went out and I fixed it by following the thread. Research it on here and good luck. It's and easy fix.
  5. Jul 7, 2010 at 4:51 PM
    dglad08
    dglad08 New Member
    Modesto
    TRD access Prerunner
    Tinted windows short antenna exhuast
    I tried resaudering all my 510s and mine still does not work.. I looked at the sensor behind the grille and the mount that hold it in place is broken. could the sensor be possibly broken? or is it not working because its not mounted.?
  6. Jul 7, 2010 at 10:41 PM
    NelsonTacoma
    Tucson, AZ
    Sometimes you have to try soldering it a couple of times before it works, also try pressing down on the 510's when the solder is still a little hot. That's how I had to do it. But it is possible that when you tried repairing it that you fried the circuit board, so you may have to buy a new one (hopefully not).
    The mount for the sensor being broken will not cause the display to go out. It may cause inaccurate readings, but not total failure. If you want to know if the sensor is good, you need a volt meter and ohm out the sensor and make sure it has a reading and is not open.
  7. Nov 18, 2010 at 5:34 PM
    lamont
    lamont New Member
    TRD
    I had mine fixed by Brian @ Brians Speedometer @ 479-652-2258. He charged me $35 for the repair and $5 s&h . Had it done and back in 4 days total . Pretty easy to remove . 1st, open sunglasses compartment , remove the one #2 phillips head screw. gently grab frt w/ both hands and pull down the frt then slid the whole unit forward , Unsnap the larger of the two connectors , w/ torx bit undo the three screws and remove cover , BE carefull on this part , there are four little grey tabs w/ fingernails or small flat screwdriver open them up and out pops the pcboard w/ display. Id then put it all back together so ya dont loose stuff . Ship off the unit . When putting back youll see these two pointed tabs that hopefully still have the clips (i lost one because i didnt know what the hell iwas doin ) If these fall off in removal , just push them back on w/ pointed/sharp side pointing up to the roof,slid the back in 1st and then line of the two tabs to the metal square holes and push them up into said holes ,, throw in that last #2 phillips head and your done .. Trust me , you can do itall with the small plug still attached and the unit just hangin down .. Have fun !!
  8. Jan 1, 2011 at 8:11 AM
    brandon in AZ
    brandon in AZ New Member
    Brandon
    Arizona
    06 Tacoma 4x4
    Exhaust
    Thanks for the help to all in this thread! My compass was exactly like many have experienced and soldering the "510" back onto the board worked PERFECTLY! Thanks again! Now I just have to figure out the shift column light! ahh :confused:
  9. Jan 17, 2011 at 4:44 PM
    Bullet1850
    Bullet1850 New Member
    06 Tacoma 4WD TRD
    Just fixed mine myself, pull it out yourself and check the resistors, 1 screw in the sunglass compartment and pull down from the compass side, it pops right out, 3 screws take out the compass= pop off the cover and look at the resistors, mine had fallen completely off, took it to a electronic repair shop and let them soder it back on, 30 min job cost me $10
  10. Jan 17, 2011 at 4:47 PM
    Bullet1850
    06 Tacoma 4WD TRD
  11. Mar 2, 2011 at 5:34 PM
    dirtyz
    dirtyz New Member
    Maple Valley, WA
    06 Tacoma 4x4 3" Revtek 285 Toyo M/T's
    3" Revtek lift, 16x8 Moto Metal 951's in black, 285/75/16 Toyo M/T tires, Flowmaster 40 series muffler, second set of cats removed
    So I just noticed my compass/temp display went out in my 06 Tacoma with just over 50k miles. I pulled the display and processor board out as instructed for this fix, however the 510 chips look ok. No separation or heat spots found anywhere. Is it best just to solder it anyway? If so where do I solder? The 510 chips are tiny and I can see solder getting everywhere. Any help would be awesome. Is there a fuse out maybe? My overhead lights work still in the same console with compass/temp display as well as my brake lights (I heard they were on the same circuit). Thanks!
  12. Mar 3, 2011 at 6:34 AM
    victheyankee
    victheyankee Well-Known Member
    arizona
    upgraded sound system eclipse and alpine and mb wheels.
    It looks like there is nothing wrong but just go over the edges with some sauder and let it cool. Test before you put everything back together. It will work. My temp guage did not look damaged at all. After i went over all four sides it started working again.
  13. Mar 3, 2011 at 7:26 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    a friend of mine builds circuit board prototypes. he showed me some of his work, and some of them have resistors the size of big salt grains. effen tiny!!
    he looked at my 510 resistor and said it was HUGE. i messed mine up trying to DIY it while drunk. he tested it and got the 51 ohms..but had to flip it over to get a better contact.
    he went thru the board mumbling about "tracing" this and that, and bridgeing things. he said he improved it..lord knows what the eff he did.
    he had a spool of braided copper that he used to pull the old solder off, and cleaned the contacts with some solution.
    he said that toyota thru that thing together. it is all better now. he did all the work under a microscope. it was cool to watch.
  14. Mar 3, 2011 at 2:32 PM
    dirtyz
    dirtyz New Member
    Maple Valley, WA
    Thanks everyone for the great write-up of this easy fix. For $15 dollars for a cheap solder gun and solder and 15 minutes (uninstall, solder, reinstall) I was able to solder both ends of the 510's. Works like a champ now! I don't know why anyone would not just do this themselves and save time and money.
  15. Mar 3, 2011 at 2:44 PM
    #35
    N8iV Warrior
    N8iV Warrior Well-Known Member
    Johnny
    Indian Reservation Not by Choice
    07 Silver Dble Cab Trd Sport 6" fabtech lift
    6" Fabtech lift, 34" tires , AFE Cold air intake, Cobra wxst75 cb, Rocky Mountain Radar, L.e.d Headlights, L.e.d maplights,dome light, license plate lights, Tinted frnt windows 35% to match rear windows. ARB bumper with XD-9000 Warn Winch, Pro-Tech HeadAche rack with Pro-Tech Toolbox, Icon Front Coilovers for 6" Fabtech lift, Blacked out Taillights PIAA plasma ION 520 Lights, AFE CAI Pro Dry S Filter, 22" Led light bar, Yakima Mega Warrior basket
    :DThere is a link in the forums to fix this very,very easy i had the exact problem took longer to dissassemble it than it did to fix it just follow the steps in this forum.. about 2 minutes and simple.:D:)
  16. Sep 21, 2011 at 12:31 PM
    #36
    Timbob1961
    Timbob1961 New Member
    Tim
    Florence, AL
    Tacoma
    I've got an 06 Tacoma and the direction indicator states that the truck is headed SW, and it doesn't matter which direction the truck is pointing. Where is the sensor that needs changing in this truck?
  17. Sep 21, 2011 at 12:33 PM
    #37
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    these fail on all models and years. ive had three buddies whom have all fail around 70k
  18. Sep 26, 2011 at 1:15 PM
    #38
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    You guys are great I love saving $900. I am needing to change my brakes if anyone could send me a link to a thread on that its an 06 tacoma:mudding:
  19. Sep 26, 2011 at 3:07 PM
    #39
    Ryguy6291
    Ryguy6291 Stormtrooper
    Henderson, Nevada
    06 Tacoma Prerunner SR5 Sport 4D Long Bedr
    3" Leveling Kit 10k HID's Westin Light Bar 3 KC 100W Hi Lites Kenwood DPX503 3 Rockford Fosgate P1 10" Subwoofers T-Rex Eyelids Blacked Out Lights Blacked Out Emblems LED Tailgate Light Strip .50 Cal Ammo Cans MOD Mag Lite MOD LED Bed Lights
    YEAH ME TOO
  20. May 14, 2012 at 7:03 PM
    #40
    SteveWeston
    SteveWeston Member
    Bullhead City AZ
    2006 Tacoma crew cab SB
    Stock
    ok, so you guys say that a solder joint might be broken,.
    how do i get into and remove the circuit board?
    The display went dead yesterday and today it was back on for about 20 minutes then went dead again.
    Thanks
    notsew_evets@frontiernet.net
