I plan to convert my 98 Toyota Tacoma prerunner 2wd automatic 4 cyl to a 4x4 Manual V6
Discussion in '1st Gen. Tacomas (1995-2004)' started by Theyseerollin98tacoma, Nov 11, 2017.
  1. Nov 11, 2017 at 9:06 AM
    Theyseerollin98tacoma [OP] New Member
    98 Toyota Tacoma prerunner 2wd 4cyl automatic
    I need know exactly what parts fit an what I need I’ve already planned on getting a 3.4L V6 and a V6 5speed 4wd transmission but I don’t know where to go from there someone help
  2. Nov 11, 2017 at 9:10 AM
    tony2018
    tony2018 Well-Known Member
    parts truck...get the whole thing.
  3. Nov 11, 2017 at 9:17 AM
    Could you be slightly more specific because even if I got one for the parts I’m still left in the dark as to what parts need to be converted an what parts are good as is
  4. Nov 11, 2017 at 9:29 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I would stick with a 98-00 parts truck, ideally a 98 to make everything as simple as possible unless you find a complete truck where all the components you need are in good working order. Before 98 you get weird hard to find ecu's and after 00 you get throttle by wire parts that are hard to find. You're at least going to need the exhaust, wiring harness for the cab and the engine, driveshaft or driveshafts if you want to go 4x4, the front diff, axles, spindles, etc. You need a different truck basically because by the time you buy a donor and swap everything over you will have added a bunch of parts that you should replace at the time and then install them it's going to take way longer and cost probably the same - ask me how I know lol.
    @Speedytech7 @BartMaster1234
    TacomaJunkie8691 likes this.
  5. Nov 11, 2017 at 9:32 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    This is one hell of a project man. You basically need everything. Dash harness, ECU, body harness, manual drivetrain components, etc etc. You will have to do a fair bit of fabricating to the truck for the engine mounts, and the transmission mounts as the automatic and v6 counterparts mount differently than the latter. There's no feasible way to do this without a parts truck it will cost you way much and be too much of a pain to find everything. You are essentially replacing the entire drivetrain and electronics of the truck down to the frame.
    Dalandser likes this.
  6. Nov 11, 2017 at 9:35 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I actually wanted to go down the same path, minus the manual swap part. I'm eventually going to do the v6 swap but I'm saving up for a parts truck. Looking at Copart and DashHub auctions the average salvage title Tacoma sells for roughly $3,000 with shipping and auction fees included.
    I actually took a couple classes at the local community colleges to prepare for something like swapping the engine. It still hasn't scratched the surface of how involved doing something like that would be.
    I mean that's not stopping me from doing it, that's just one hell of a project to do at one time. Not an easy project if you don't have experience with electrical diagnosis, welding/fabricating, and extensive drivetrain knowledge.
    At that point it would be easier and cheaper to just sell the truck and buy the truck you want.
    Dalandser[QUOTED] likes this.
  7. Nov 11, 2017 at 9:41 AM
    BartMaster1234
    Tyler
    Flux Capacitor
  8. Nov 11, 2017 at 9:41 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It's kind of like asking how much a Lamborghini costs. If you have to ask it's not going to happen. I'm doing a straight bolt on engine and trans swap minus some exhaust work that needs welding and there's enough parts that I've replaced already that if I didn't enjoy learning about this stuff then it never would have been worth it or would have happened. If the guy that started this thread is serious about it then by all means, but you've got a lot to learn ;)
    I'm a teacher so I should say do it! I just want you to know the reality of it if you don't have any knowledge of how to do this stuff - it's not that it's necessarily hard, but it does take time, dedication, and skill!
  9. Nov 11, 2017 at 9:58 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    There is a lot parts Tacos out here on the East coast with rusted frame
  10. Nov 11, 2017 at 9:58 AM
    Tbimm
    Tbimm Well-Known Member
    Tom
    Belle Chasse La.
    2000 Tacoma Prerunner
    Bilstein 5100's front and back. OME 880 front coils. General HD rear springs. Fuel 16x8 Enduro rims. Dick Cepek Extreme Country 285/75/16's Some kind of headers. K&N cold air intake.
    Not sure where you live but if you wanted to stay 4cyl I have a line on a manual trans and transfer case. It would be an exact fit for you.
  11. Nov 11, 2017 at 10:08 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    If you have to ask a broad question like that, this project is likely to completely overwhelm you very quickly.
    Is this a fun project to learn or do you rely on this vehicle to get around? Your truck will be in pieces for months and months.
    Sell your current truck, buy the one you want.
    Dalandser and BartMaster1234 like this.
  12. Nov 11, 2017 at 10:16 AM
    36tacundra
    36tacundra Well-Known Member
    Watch out for the transmission cross-member location. The v6 was moved 3 inches or so forward from the 4 cylinder. So moving the cross-member, or making a new cross-member is a possibility.
  13. Nov 11, 2017 at 10:29 AM
    tony2018
    You'll be able to spot them sometimes in someone's yard, on their acre, or on craigslist. Again, you'll want the entire wrecked truck.
  14. Nov 11, 2017 at 2:01 PM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    I would consider to find a rolled/ mildly wreaked truck with what drivetrain you want and swap cab and body parts over. Either way....your in for a big project.
  15. Nov 11, 2017 at 9:23 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Probably be easier to buy a truck and swap yout body to it
  16. Nov 11, 2017 at 9:31 PM
    36tacundra
    I just spent day two installing four wheel drive into a prerunner. All I have left is the trans fluid and the rear driveline. Its a bit of work, but hay if you like working on toyotas, it's aaallllll right.
