IBS dual battery kits
Discussion in 'Sierra Expeditions' started by FlyingWil, Jan 27, 2011.
  1. Nov 26, 2012 at 9:30 PM
    Jbcm12
    Jbcm12 Well-Known Member
    Joshua
    Bay Area
    I know the purpose of have the monitor and everything but can you wire a dual battery setup without a kit?
  2. Nov 27, 2012 at 4:25 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    A "kit" is used to make something easier to build or install. The downside is the loss of flexibility. The main purpose of a dual battery set up is to isolate one battery from a second battery while being discharged and to connect them together while charging. Normally this is used to provide auxiliary power from a deep cycle battery without draining a starting battery such that the engine can be restarted. The three most common applications are for emergency vehicles, RVs and boats. Some of the most common techniques to accomplish this are the use a manual switch, relay or isolation diodes. Regardless of which technique is used, it is important to properly size the batteries, wiring, fusing and isolator based on the application's power requirements.
  3. Nov 27, 2012 at 3:07 PM
    FlyingWil
    FlyingWil [OP] Well-Known Member Vendor
    Wil
    Sonoran Desert
    01 DC Expedition Ready
    Shrockworks Front Bumper, LightForce 240's, PIAA 510's,T-Max 9000 competition winch with Outback (longer drum) and modified brake wireless controller and Masterpull line with Viking safety thimble, Rugged Ridge Hawse, Daystar Winch isolator, SAW Racerunner 2.5 coilovers, Safari Snorkel, IBS dual battery system with RBM, Scangauge II, Total Vision self spotting kit and monitor with aux output and remote, Low Tek Gauge pod with Cyberdyne gauges for fridge and battery, Yeasu FT-7800 head unit mounted in ceiling linner and speaker Larson Hood mount, Uniden Pro 520XL CB radio in the ash tray location,'lil Wil Mag mount antenna, Odessey 1200 MJT & Die Hard Plat. dual batteries, Can-Back with extra mounts, Blue Sea 12 st Fuse Box, 100 Amp 100 Amp Relay, Extremeaire & 5 Gal air tank w/ 145 psi switch, Custom bed drawer system, Engel Mt-45 with TwoZone, protective covers, and Engel Slide Eezi-Awn 1600 RTT w/ Ikea LED light mod, and sheet set, CBI offroad Expedition rear bumper, jerry can tir
    Not sure on the exact figures... As for the winch off your main, you always want to run your winch as close to the alternator.
    Sweet
  4. Nov 29, 2012 at 5:46 AM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
  5. Dec 21, 2012 at 11:52 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    S I'm about to to go ahead and go duals :cool:
    I just have a few questions. Since you end up grounding both batteries to the frame can you ground the accessories that are running off the the aux battery to the frame?? Or do I still have to run grounds from my lights directly to the aux battery??
  6. Dec 22, 2012 at 12:06 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Sub'd for reference
  7. Dec 22, 2012 at 6:58 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    By grounding both batteries to the frame you are creating a ground buss that can be used throughout your vehicle as a common ground. Good low resistance grounding connections need to made to reduce voltage drop.
  8. Dec 22, 2012 at 9:19 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    How does that not create a crossed connection?? If the powers are isolated..
    So basically I can just ground my lights to the frame and body or wherever..
  9. Dec 22, 2012 at 10:54 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    The key word in your question was POWER. The + sides are isolated but a ground is just a ground. It can be joined and crossed and wrapped around eachother and it make no differece. Yes u can ground to anywhere on the truck as long as its metal that in some way is connected to the frame. I actually have no ground connections on my battery terminals besides the main battery ground wire, they are all made on a lug bolted to the engine bay. Also if u take a minute and beef up your ground wires all through out the engine bay you will have a much better grounding system. Just remember that wire is rated for a certain amount of amps. When u surpass that amperage rating you have to step up the wire size. Consequently u also have to step up your grounding size.
  10. Dec 22, 2012 at 1:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks man. That's going to make my life so much easier. I thought I had to isolate all he grounds too
  11. Dec 22, 2012 at 2:41 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Not at all ;)
  12. Jan 13, 2013 at 5:28 PM
    GrayTacoma
    GrayTacoma Well-Known Member
    Andy
    Huntingtown, MD
    2011 TRD off road
    PIAA ion yellow fogs stay on all time,aux reverse lights, aux lights, camper with rack, cb, air bags, on board air, aux fuse box, aux batt, CAI, etc.............
    Subb for reference.....
  13. Feb 25, 2013 at 2:52 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Will definitely be buying this in the future. Thanks will for the loot today! Repping you guys in AK!
  14. Apr 26, 2013 at 9:42 AM
    livelifetolive
    livelifetolive Well-Known Member
    SOBERDAVE
    Florida
    2009 4dr Tacoma TRD OR 4x4
    sUbbed For Reference
  15. May 9, 2013 at 10:02 AM
    #35
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    You guys installing these at the upcoming Overland Expedition?? :D
  16. Jun 6, 2013 at 10:12 AM
    #36
    billstickly1
    billstickly1 Well-Known Member
    Any ideas on where to get one installed in Florida?
  17. Jun 7, 2013 at 7:00 AM
    #37
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Try RV, auto electric or car audio shops.
  18. Jul 9, 2013 at 1:37 PM
    #38
    MadMule
    MadMule Active Member
    Emory
    Aurora, CO
    Tacoma TRD
    Toytec/Bilstein-3 "li ft kit with 5160 rear shocks, spidertrax spacers
    any chance there will another group buy, I missed out last time
  19. Dec 20, 2013 at 12:05 PM
    #39
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Would sure like someone to organize another group buy also. New here but will do it if provided some assistance as to how?
  20. Dec 20, 2013 at 3:14 PM
    #40
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    A group buy would be sweet. Not 100% committed to a GB at the moment but maybe around income tax time????
