Icon coilover rebuild/seal kit
Discussion in 'Buy / Sell / Trade' started by rzimm001, Nov 7, 2010.
  1. Nov 7, 2010 at 11:56 PM
    rzimm001
    rzimm001 [OP] Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Are your Donahoe(All) or Icon coilovers(serial #s lower than 1400) blown? Are they due for a rebuild?
    If you're willing to rebuild your own shocks I have four sets of Icon coilover rebuild kits. That's enough rebuild kits to do four shocks without the remote reservoir. Icon sells them for thirty-five bucks a shock and Seventy-five if you want them to install them. Do it yourself and save some coin. I'm only looking to get $20 a kit. Pictured items below the standard seal kit are extra. Prices are posted. Located in Murrieta, CA.
    Std. Seal Kit: $20
    Rod bearing and spiro-locks: $12 each bearing and $1 each spiro-lock
    Wear band: $4 each
    Coil adjuster set screw: $1 each
    Valve Shims: I have .925x.015 / 1.050x.015 / 1.275x.015 / 1.30x.015 / 1.30x.020 / 1.425x.015 / 1.55x.015 / 1.55x.020 $1 a shim
  2. Nov 8, 2010 at 9:10 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Pics...:anonymous:
  3. Nov 8, 2010 at 10:09 AM
    rzimm001
    Bobby
    Wildomar
    It's just a bunch of O-rings :p
    I'll get the pics up tonight for you.. ;)
  4. Nov 8, 2010 at 10:14 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    do you need extra parts for the resi ones? also, is this for the 2.5 fronts, or 2.0 rears?
  5. Nov 8, 2010 at 10:36 AM
    rzimm001
    Bobby
    Wildomar
    These are for any 2.5" Icons, front coilovers included. They will not work for 2.0 rears. The remote reservoir coilovers require two extra o-rings for the reservoir end caps. I have what you need but it will leave me short for the other seal kits. I doubt the reservoir end caps o-rings are an extreme wear item. You would just replace the high wear items inside your remote resi icons with the kit I am selling. A kit includes two h-wipers for the shaft, an o-ring for the seal head, and an o-ring for the floating piston.
  6. Nov 8, 2010 at 1:16 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    thanks for the info. i don't actually need them now. i'm hoping to revalve the fronts in a year or so, so when i do that i figure i might as well do the seals too while i have them apart. i'll keep an eye on this thread in case they don't sell by then.
    bump
  7. Nov 8, 2010 at 1:32 PM
    rzimm001
    Bobby
    Wildomar
    I have shims as well. I'll check them with the Caliper and post what I have. I think they're 15s and 10s. I also have the stock valving chart on PDF. For your eyes only of course. You can PM me about that.
  8. Nov 8, 2010 at 2:46 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  9. Nov 8, 2010 at 9:25 PM
    rzimm001
    Bobby
    Wildomar
    TTT... Updated with pics
  10. May 4, 2011 at 8:48 AM
    jjbeenken
    jjbeenken Well-Known Member
    Arkansas
    2022 DC TRD Sport(always under construction)
    Hertz - Arc Audio - Precision Power - Image Dynamics - Helix -AP UCA's - Dakar Springs - Icon Vehicle Dynamics
    PM sent
  11. May 27, 2011 at 8:51 PM
    jjbeenken
    Arkansas
  12. May 28, 2011 at 1:05 AM
    rzimm001
    Bobby
    Wildomar
    You're very welcome. Nice job on the install. I'm sure the wear band will be fine. As for the bearing, if you they don't begin to rattle I wouldn't worry about it. A buddy of mine had some uniballs that were beyond shot and he just milked them until they rattled horribly. Only then did he replace them. No harm done.
  13. May 28, 2011 at 8:19 AM
    jjbeenken
    Arkansas
    I was in patient and in a hurry when I ordered and didn't have the shocks apart yet. I got the piston bands and the dividing piston wear bands from Icon. I had one bearing and ordered 2 from you, then I thought I better just replace them all.
  14. Jun 9, 2013 at 7:54 AM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Any chance you still have these? It's a long shot, but I figured I'd ask.
  15. Jun 9, 2013 at 10:55 AM
    rzimm001
    Bobby
    Wildomar
    I'm afraid not. I have some stuff left, but not the seals themselves. If you need some of the other hardware listed let me know and I will tell you what I do have left.
  16. Feb 15, 2017 at 5:56 AM
    Sirmeeps
    Sirmeeps Well-Known Member
    Topsail Island Nc
    2000 Tacoma
    Tdi swap,LT
    So I'm bringing this one back from the dead, does anyone know any info on. Rebuilding some 2.5 dr coilovers, and 2.0 rear icons? Can I get new bushings for the rear shocks? How much do shafts usually cost...? Thanks guys
  17. Feb 15, 2017 at 6:47 AM
    jjbeenken
    Arkansas
