Icon VS King
Discussion in 'Suspension' started by Annolino122, Oct 6, 2013.
  1. Oct 6, 2013 at 9:08 PM
    Annolino122
    Annolino122 [OP] Well-Known Member
    Evansville
    2014 Tacoma TRD off road
    So i'm trying to figure out what mid-travel suspension is going to be best for my uses.
    Both kits would be:
    2.5 res coil overs in the front
    Tubular UCA replacement
    Sway bar relocation
    Rear leaf pack replacement
    2.5 res shocks
    I was wondering which setup is better, the King's or Icon's.
    I will be doing mostly small town driving. When I off road its usually grated trails or worn trails, back roads basically.
    I will also be rock crawling and doing some slower more precise trails.
    I know I've been told both kits are overkill for what i want to do, but they're the kits of choice so i can have the ability to do what i want if i want to.
    so again, which would be suggested kit and what do you guys think is a better product?
  2. Oct 6, 2013 at 9:57 PM
    Annolino122
    Evansville
    That's pretty sweet.... I understand the conceptual part of being able to changed the firmness of the shock, but what's the true application.
    Softer for woops and jumps, and firmer for crawling? or how does it work?
  3. Oct 6, 2013 at 10:33 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
  4. Oct 6, 2013 at 10:34 PM
    Redfox1
    Conner
    This thread has a bunch of info. I imagine it'd be helpful
  5. Oct 6, 2013 at 10:42 PM
    deog
    deog Well-Known Member
    snicklefritz
    Las Vegas. As far west as you can go.
    work in progress
    gucci interior and chandelier.
    You can't go wrong with Icon, fox or king.
  6. Oct 6, 2013 at 10:44 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Pick a color. Both are good.
    lamjam likes this.
  7. Oct 7, 2013 at 9:26 AM
    Annolino122
    Evansville
    That definitely helped a lot. Kinda forgot that a king set up is going to have that LT squeak haha but it just confirmed my icons are what I want
  8. Oct 18, 2013 at 8:48 AM
    DevL
    DevL Well-Known Member
    Please explain.
    IMO for what you describe King is what you want. LT noise is mostly heim joints and bypass valves. Neither is a concern for your application. I don't see a use for digressive valving in your application.
  9. Oct 18, 2013 at 9:04 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Digressive valving is used for the DD aspect. It's not even noticable to most as it's on the rebound and not compression side.
    Icon is my vote but honestly pick a color/best deal.
    crhsharks12 likes this.
  10. Oct 19, 2013 at 8:50 AM
    Annolino122
    Evansville
    Well that's the thing, with everything thing I'm going to get it will be $200 difference for the kings. I'm just trying to figure out which is best for my application. And from the sounds icon are tacoma specific and have those vlave controls which would be nice for different types of off roading
  11. Oct 19, 2013 at 9:01 AM
    SpecialK
    SpecialK Member
    So Cal
    '12 DCLB 4X4 Sport
    Icon UCA's, Ext Travel coil-overs, rear reservoir shocks
    Just put Icon's extended travel coilovers, uca's and reservoir shocks on the rear (no leaf spring mods as I tow a travel trailer and so far have been advised to stay with the stock leaf packs) and I couldn't be happier with the ride - both on road and off.
  12. Oct 19, 2013 at 10:54 AM
    Colt562
    Colt562 Well-Known Member
    Brett
    SoCal
    13' TRD Sport 4x4
    Icon Stage 3 Lift Kit...Dakars
    I went with Icons and couldnt be happier. got their ext travel coilovers set at 2.5", Resi's in the rear with Dakars (one overload spring taken out). Couldnt be happier with the ride quality.
  13. Oct 20, 2013 at 12:13 PM
    Annolino122
    Evansville
    That's what I like to hear
    Thanks guys
  14. Oct 24, 2013 at 1:19 PM
    DevL
    Are you saying that the digressive valving only works on the rebound and not compression? I do not believe that to be true.
  15. Oct 24, 2013 at 10:16 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Icon's digressive valving is on rebound not compression.........http://www.tacomaworld.com/forum/suspension/254389-icon-cdc-coilovers-2.html
    "As far as the piston design..... off road race shocks use a Linear / Linear design and ICON uses a Linear / Digressive design in our V.S. Series line of shocks"
    "One good feature about being digressive on the rebound side is the low speed control which comes into play during street driving much of the time."
  16. Oct 27, 2013 at 9:02 PM
    CaliBluTaco
    CaliBluTaco Well-Known Member
    Nathanael
    Ohio USA
    07 Tacoma TRD Off Road
    Brute Force Fab Hybrid Front Bumper, Brute Force Fab HC Rear Bumper, All Pro Kickout Sliders, Pelfreybilt IFS Skid and Mid Skid, Relentless Fab Tailgate Reinforcement, ICON Ext.Travel Coilovers w/ 14"x 650# Eibach coils and custom valving, LR UCA's, OME Heavy Duty Rear Leaf Pack w/ All Pro U-Bolt Flip, Icon 2.0 Aluminum Series Extended Travel rear shocks & Wheelers Super Bumpstops. 285/70R17 Hankook Dynapro MT RT03 Tires on 17x8 Pro Comp 7089's, ENGO E12000s Winch w/ Synthetic Rope, Locker Anytime Mod, Rear Diff Breather Mod, and more...
    I just installed Icon's Ext.Travel coilover with 700# coils and Light Low Speed Valving for a softer ride. All i can say is WOW. What a difference in ride and handling coming from Bilsteins set at 2.5" I do alot of wheel'n on trails and rock crawling, not too much high speed desert wheel'n. But both Icon and King make awsome products. Can't go wrong with either one :D
  17. Oct 27, 2013 at 10:22 PM
    Annolino122
    Evansville
    The more i hear and read, the more that Icon gives the best on road ride around, doesn't allow for too much body roll, and off roads performs just as well as King… so Icons it is
  18. Dec 5, 2020 at 12:15 AM
    crhsharks12
    crhsharks12 Well-Known Member
    Denver, CO
    ‘06 Tacoma 4WD TRD Sport DCSB 4.0L V6
    RR 2.5 King shocks front/rear, Camburg UCA's, Icon AAL Springs Softopper & BA Bumper
    So OP, 7 years later what’s the update? Lol just curious
  19. Jan 27, 2022 at 8:50 PM
    Kman1996
    Kman1996 Well-Known Member
    Kyle
    SoCal
    2017 TRD OR DCSB 4x4
  20. Jan 28, 2022 at 9:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
