Ignition is "iffy"
Discussion in '1st Gen. Tacomas (1995-2004)' started by chipfields, Jun 10, 2013.
  1. Jun 10, 2013 at 8:09 AM
    chipfields
    chipfields [OP] Member
    00 SR5 TRD
  2. Jun 10, 2013 at 8:23 AM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    may be a bad starter
  3. Jun 10, 2013 at 8:25 AM
    Mr.Jack
    Mr.Jack Active Member
    Wilmington, NC
    The Black Pearl
    Remote Start, 4 Hella Lights, Brush Guard, Grey Wire
    Does it always click twice?
    Make sure your battery is healthy and the connection is solid.
  4. Jun 10, 2013 at 9:37 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    1. Clean battery terminals and check connections
    2. Get battery tested (free at any auto store) replace if necessary
    3. Replace starter contacts and plunger. Super cheap and easy to do
  5. Jun 10, 2013 at 10:04 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Probably some burn marks on armatuer, the clicking is the solenoid doing its job (its getting juice & passing it along to starter bendix) but theres no field being created to spin the starter, you can try cleaning all connections & ground points, probably won't help, get a wooden dowel or a piece of 2x4 & smack the starter a couple times (its sticking) also, in the end your problem is going to be in the start armatuer i'm betting
  6. Jun 10, 2013 at 10:21 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Starter definitely. I just replaced the starter on mine because it was doing that. i think it really is the starter solenoid but its not much more to replace the entire starter.
  7. Jun 10, 2013 at 10:37 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    If its clicking (solenoid) its working from my experience, but yeah its in the starter
  8. Jun 10, 2013 at 10:38 AM
    Pannell_Trd
    Pannell_Trd Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    for sure sounds like a starter
  9. Jun 10, 2013 at 10:53 AM
    Southern01Taco
    Sean
    Holden, La
    I thought it could get weak and just not have enough power to engage the starter like it should?
  10. Jun 10, 2013 at 11:02 AM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    just have your starter rebuilt it's 1. cheaper 2. Still OEM. 3. better than anything from a parts store.
  11. Jun 10, 2013 at 1:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    The solenoid is a "dumb" device, its either open or closed (like a relay switch, I would think that if theres no clicking it means 1 of 2 things...theres no power getting to it, or theres power getting to it but no "clicking" (sign of operation) hence then the solenoid is bad & not allowing current to starter if silent..
  12. Jun 10, 2013 at 1:46 PM
    Southern01Taco
    Sean
    Holden, La
    That makes sense :thumbsup:
  13. Jun 10, 2013 at 2:45 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Rock auto has denso starters! I'd get one from there
  14. Jun 10, 2013 at 3:03 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Mine did the same thing and it ended up being bad battery connections and a battery that was on its last limb
  15. Jun 11, 2013 at 7:29 AM
    chipfields
    00 SR5 TRD
    Is the starter something the average Joe can replace?
  16. Jun 11, 2013 at 8:16 AM
    Southern01Taco
    Sean
    Holden, La
    Yes. It's very easy. I had mine out and laying on the ground in about 15 mins and I was doing it in the dark. There is 2 bolts holding it on and then one nut that holds the hot wire on. Once you get that loose, the starter pretty much falls out. I can't remember what size the bolts are but I want to guess that it is either a 12mm or a 14mm. I had to use a short socket and rachet on one bolt and then a wrench on the other. Oh and the starter is on the passenger side and the easiest way to get to the bolts is from underneath the truck.
  17. Jun 11, 2013 at 8:19 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Its awkward to get at, not fun, but do-able. Do you have a set of metric wrenches and a metric socket set?
    Be sure to eliminate the easier stuff first, like battery, cables, starter solenoid, etc. It'd be the shits if you went to all the trouble to replace the starter (or rebuild the solenoid) and you still have the problem.
  18. Jun 20, 2013 at 8:25 AM
    chipfields
    00 SR5 TRD
    Dude, you're not going to believe this. I went out there with all my tools, ready to replace the starter. I had not purchased a starter, but was just looking to see what I was up against. Then I thought, what the heck, what could it hurt? I took a 2X4 like you said and banged on the starter about seven times. Got in the truck, turned the ignition, and it fired right up. Unbelievable. Thanks.
  19. Jun 20, 2013 at 8:35 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    That problem won't go away. You'll get away with starting it like that for awhile, and then *poof* that trick won't work any more (it'll happen when it's snowing or freezing rain). You need to rebuild the starter or buy a new one.
    I know this is for the 2.7, but it will be very similar to yours:
    http://www.tacomaworld.com/forum/1s...clicking-starter-2-7-liter-3rz-fe-engine.html
  20. Jun 20, 2013 at 12:27 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    check conections at starter make sure no oil on them or if they are loose. pull the starter and check the connections to the depress sensor on the clutch pedal.
