Ignition problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by TAMU, Jan 5, 2008.
  1. Jan 5, 2008 at 6:50 PM
    TAMU
    TAMU [OP] Member
    Texas
    2001 Stock White SR5, cracked windshield, and a deer dent
    My wife's truck will not start. Engine turns over fine, all the ECM and ignition fuses and relays are good. Fuel system seems to be working. I assume my 4cyl engine has some cam position sensors for igntion timing signals to the ECM. Where are they? Any way to quick test if that is my problem or if i have ECM problems. HELP!
  2. Jan 5, 2008 at 6:58 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Not to sound elementary but when you're cranking the engine do you smell fuel ? Maybe pull a spark plug wire and be certain you have fire.
  3. Jan 5, 2008 at 7:09 PM
    TAMU
    TAMU [OP] Member
    Texas
    yes, I smell fuel, and no there is no fire. That is why I started to look at the ignition module or it's sensors. I got air and fuel, now I need igntion. I would assume the ignition will not turn on until it knows position. Correct?
  4. Jan 5, 2008 at 7:17 PM
    concrete jedi
    Rochester N.Y
    Correct, when you don't have fire, something is not allowing it to no it's position (sensor) or the unit has gone bad.
  5. Jan 7, 2008 at 4:44 AM
    colttsi
    colttsi Well-Known Member
    What kind of car???
  6. Jan 7, 2008 at 6:26 AM
    TAMU
    TAMU [OP] Member
    Texas
    the 2001 toyota SR5,
  7. Jan 7, 2008 at 9:32 AM
    colttsi
    Is your fuel pump working? Do you hear it? Check the fuse for your fuel pump.
    Your Cam sensor should have 12v, ground and signal wire, so check with a voltmeter if your 12v and your ground are ok. To check the signal given by a cam sensor, you need a scope so unless you have a very good voltmeter (Fluke, etc...) you can't read the cam signal.
    It is a situation that can have many causes so it is extremely hard to diagnose.
    To make sure you have gaz coming to your engine, disconnect your entry line and crank the engine, if gas is coming out you're ok.
    Sorry, I can't help you more than that.
  8. Jan 7, 2008 at 4:03 PM
    TAMU
    TAMU [OP] Member
    Texas
    Thanks for the help although I had checked the fuel at the entry line and all that works when I turn the engine over. I have a fluke but I can't find the cam sensor, which was my original question. Where is it? I assume this is a hall effect sensor and will go 12v signal low when the signal passes the sensor. By the way, where is the ECM?
  9. Jan 8, 2008 at 7:30 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    i believe ecm in in behind the glove box or down under stereo...been awhile since i had one that was stock gutted.. did you check if you have 12v going into the coils? if it doesnt get any there then it wont get any to plugs...I had a postition sensor go out on mine once... but it still ran... just back fired and such .....also that was on v6 but I think the sensor is right infront of oil filter location...has weather tight connector with 3 wires maybe if memory is correct
  10. Feb 2, 2008 at 9:20 PM
    RaiderSix
    RaiderSix Well-Known Member
