In Cab Inverter questions and plan.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jackrules, Jan 12, 2012.
  1. Jan 12, 2012 at 12:03 AM
    jackrules
    jackrules [OP] Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    Hi guys
    So part of my birthday list is a blue sea aux fuse block and a black and decker 500 watt inverter. http://www.homedepot.com/h_d1/N-5yc1vZ12l0/R-202564876/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
    My plan is to mount the investor behind the rear seats. Run a USB extension cable to the dashboard where I'll pop it out where one of the blank switches is so that I can easily power my iPhone through it. I'm not sure where I'll put the power outlets yet. The phone charger will be what I mostly use it for. I figured a car charger would be like 25 bucks and the investor is 40, so it's a good value. I plan to fuse it through my new blue sea fuse block ( which is limited at 32 amps. This means the max I'll be able to run on my investor is 360 watts, but I don't see many cases where the 360 watts will be much of a difference from 500... I've got 400 watts in the bed which will power my 3gallon air compressor or my dremel or most things....
    Anyways.. heres my questions
    What gauge wire should I use to run 32 amps from the investor to the fuse block safely.
    Is behind the seats a good spot?
    Whats the easiest way to run the wire from behind the seats to under the hood? I wouldn't mind drilling a small hole somewhere if it will be well hidden and would mean I don't have to hide this wire all the way up to the firewall and then deal with getting it through the fire wall...?
    My best friend is, in addition to other things, getting me ARB valve stem caps for my wheels. What can I say.. I like the details.. and if I can't have an ARB bumper, next best thing!
  2. Jan 12, 2012 at 12:31 AM
    Joeymgd78
    Joeymgd78 Well-Known Member
    Joey
    at the moment Afghanistan
    2008 Tacoma SR5 TRD Offroad 4.0 V6 Double Cab
  3. Jan 12, 2012 at 1:03 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    for wire, match whatever wire the inverter comes with (to hook up to the battery). i'm guessing 8 AWG
    behind the seats is ok, but you'll have to run a ton of wire from the batter to the inverter, then the inverter to wherever you want to install the outlets and the USB port. I personally have mine underneath the driver seat. I have weathertec mats, so rain and snow never has been a problem with getting to it.
    the easiest way to wire them? follow what this guy did for his CB
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/134082-my-cb-installation-detail.html
  4. Jan 12, 2012 at 5:12 PM
    jackrules
    Jack
    San Diego
    I've thought about putting the investor under the drivers seat. I may do that.. I would like to be able to see the battery indicator lights on it.
    do you have an inverter? if so, what kind?
    and how do i get access behind the blanks on the center part of the dashboard above where the cup holders are?
  5. Jan 12, 2012 at 5:17 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    i have a cosco 1000w inverter under my drivers seat. I relocated the two outlets and the on/off switch to my center console by lengthening the wiring. Now I can plug anything I want from the front seat.
  6. Jan 12, 2012 at 5:24 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Yours didn't come with the stock 400w inverter?
  7. Jan 12, 2012 at 5:26 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    i have the stock 400w, but its not in the cab, and its not 1000w
  8. Jan 13, 2012 at 11:19 PM
    jackrules
    Jack
    San Diego
    i want one in the cab too
    only 40 bucks, why not?
  9. Jan 14, 2012 at 6:47 AM
    ecoterragaia
    ecoterragaia Well-Known Member
    Mid-Atlantic
    '06 RC, 4X4, 5 speed
    I just installed a 750W inverter under the driver's seat two weeks ago. I ran 4 gauge flexible welding wire ($2.34/ft from True Value hardware) from the positive side of the battery to an inline 60 amp fuse, then through the inside of the existing rubber grommet in the firewall to a 500 amp battery switch I mounted in the center console (switch is optional). From there the wire goes under carpet to the inverter under the seat, which is grounded on the bolt for the center seat belt anchor (I don't use that seat belt). I put the battery switch in because 1) the inverter draws current when it's left on and there's nothing plugged in, 2) the wires for the on/off switch on the inverter are very difficult to get to, 3) I wanted the inverter to be portable.
    I've been having a really hard time finding 110v outlets that I can install in the dash, so for now I just have an extension cord stuffed under the seat that I pull out when needed. The whole setup has been working without any problems.
  10. Jan 14, 2012 at 7:08 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
  11. Jan 14, 2012 at 7:12 AM
    ecoterragaia
    Mid-Atlantic
  12. Jan 14, 2012 at 7:19 AM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    No Problem, glad to help.
  13. Jan 14, 2012 at 8:02 AM
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
    See, THIS ^^^ is why I really like TW!!!
    I searched the web for hours the other night looking for exactly that piece.
    THANK YOU!!
  14. Jan 14, 2012 at 8:20 PM
    jackrules
    Jack
    San Diego
    Will that 110 plug with the link posted above fit into any of the blanks? I haven't checked, but I feel like the blanks aren't an inch wide.
  15. Jan 14, 2012 at 8:43 PM
    SHAKE JONES
    SHAKE JONES Active Member
    Wyatt
    Western NC
    12 DCSB OR
    Listed in order of installation: OEM door sill protectors, 20% tint, Fog Light Mod, 1000w Inverter under driver seat, seat covers, vent shades, Plasti Dip front emblem and chrome grill surround
    It wouldnt fit without some cutting.
    Also, your inverter needs to be as close to the power source (battery) as possible to cut down on the resistance and get the most power from your inverter as possible. Longer runs on the DC side will cause more resistance and possibly enough heat to melt some stuff especially if you use a thin wire. The AC side of the inverter shouldn't have any issues with resistance or over heating so it would be better to mount the inverter close and run wires to your outlets.
  16. Jan 14, 2012 at 9:09 PM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Agreed, also ventilation is your friend, and underseat location is bound to be hot in addition to longer initial leads creating heat as well.
  17. Jan 16, 2012 at 9:14 AM
    nadera17
    nadera17 Well-Known Member
    Nader
    Virginia Beach
    I4 SR5
    http://www.tacomaworld.com/forum/audio-video/101933-my-audio-deadening-project.html, Drone Mobile alarm by Compustar, ARE camper shell for the dogs
    "and how do i get access behind the blanks on the center part of the dashboard above where the cup holders are?"
    access to those blanks isn't difficult. Pull out the cup holders, there are screws on either side and the pull the whole thing out. Check out some of the audio posts for pictures and details or PM me.
  18. Jan 16, 2012 at 9:16 AM
    nadera17
    Nader
    Virginia Beach
    I4 SR5
    Anyone have experience with resistance problems or over heating problems? We've talked about them as possibilities, how about in reality?
  19. Jan 16, 2012 at 9:28 AM
    nadera17
    Nader
    Virginia Beach
    I4 SR5
