Installing Tailgate Power Lock PL 8521
Discussion in 'New Members' started by TANKAN101, Feb 26, 2012.
  1. Feb 26, 2012 at 9:51 PM
    TANKAN101
    TANKAN101 [OP] New Member
    Tacoma
    Just got it ... No mod yet
    I am new and I just bought my first Tacoma. I have Tacoma 2011,the manual does not say anything except TACOMA. The Tailgate does not lock when the vehicle is locked. I purchased Power & Lock PL 8521 -- supposed to come with back up camera but didn't. I was looking for a beter instruction on how to install it on the net when I stumbled into Tacoma World. I was very impressed. I spent a lot of time reading postings and I became intimidated by all the knowledge and skill of the writers.
    I am sure that this has been discussed before but I just can't find it, if not can some one who has done it teach me how to do this or if it has been discussed, direct me to the proper posting. The manual that the PL 8521 came with was not very helpful and I am green with tools.
    buckhuntin-tacoma likes this.
  2. Feb 26, 2012 at 10:08 PM
    medic2230
    Murph
    Bama! Roll Tide
  3. Feb 26, 2012 at 10:25 PM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Okay, don't know how far along you are in the install, so will take it from the top. Before starting, lets make sure we're talking about the same thing - the electronic version which locks or unlocks by the truck's remote key fob. At that price, it obviously doesn't include a camera, but instead attaches to a tailgate handle with or without an existing camera.
    The instructions included are correct for installing the locking mechanism. It attaches to the existing handle using a single bolt (one of the existing bolts for the tailgate handle) to hold the locking mechanism in place. Afterwards, you'll need to run the wires over the vehicle frame (secured by the wire ties) to the passenger seat area. Keep wires away from hot exhaust pipe and/or moving parts. I took extra time to move both sets of wiring in the tailgate (backup camera & lock) into the same split plastic sleeve for a cleaner looking install (visible between tailgate and vehicle), but this is optional.
    Next, look for a large rubber grummet under vehicle near the passenger seat (about six to eight inches from edge of vehicle, just behind front bracket for seat). Spread that rubber grummet open with a screwdriver and feed the wires with plastic sleeve through to the vehicle interior (nice to have help here pulling from inside as you feed from under the vehicle).
    Pop off plastic covers (doorsilll panel pulls up, foot side panel has knob and pulls towards back). Towards the front of that now visible cluster of wires beside the glovebox, look for two wires (one blue/pink and the other blue/black) feeding into a large white connector (the pink is actually an ugly shade of red approaching pink). Those are the two wires you want to connect the wires from the lock to. I used my own tap connectors instead of those included with the kit (the included ones truly suck).
    Test everything. If the tailgate locks when you unlock the vehicle (and vice versa), reverse the two wires in the tailgate. Finally, put the covers back on and go for a joyride knowing your tailgate is now reasonably secure.
    If you search this forum for "Pop & Lock" or "tailgate lock," you'll see several threads with images, along with followup comments from others describing the electronic version and it's wiring.
  4. Feb 29, 2012 at 3:24 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
  5. Mar 5, 2012 at 4:56 PM
    TANKAN101
    Tacoma
    I have finally completed my up grade #1; installing Power Tailgate Lock by pop & lock on Tacoma 2011. It turned out not to be as dificult as I had envisioned.Thanks to all those who wrote up on it. It took me more time to research it than it took to install it.
    I was surprised and pleased when it worked the first time. I was sure that I tied the line to the wrong wire but it worked like a charm. Once again thanks guys.
  6. Mar 5, 2012 at 6:22 PM
    stewartx
    Huntsville AL
    Good for you. Of course, now that you've had the positive experience of a successful install, other installations will surely follow soon. If you're not carefull, that addiction will put you in the poorhouse.
    tbird95 likes this.
  7. Jul 18, 2012 at 6:27 PM
    chewingonabone
    chewingonabone Well-Known Member
    Josh
    Charlotte, NC
    09 Tacoma SR5
    Retrax One tonneau, bull bar, step bar, PL8521
    I must be an idiot...I'm having such a hard time installing the PL8521 in my '09 access cab.
    I have everything set up, I'm down to the wiring. The instruction manual doesn't even have wiring directions for the 2009, only the 05-08, and the 10-12.
    I'm trying to splice the green wire from the pl8521 into the blue/red wire on the passenger side. I want to test the wiring before I clamp down on the splice. So I press the the wires together while double pressing the unlock button on the key, and nothing happens with the tailgate lock...
    I've been working on it for three hours...I'm pretty mad.
    Any help???
  8. Jul 18, 2012 at 8:54 PM
    stewartx
    Huntsville AL
  9. Jul 18, 2012 at 9:46 PM
    tacoma4x4girl
    tacoma4x4girl Well-Known Member
    Welcome! :wave:
    Taco critter likes this.
  10. Jul 18, 2012 at 10:26 PM
    stewartx
    Huntsville AL
    Well, welcome and hello to you too, Jessica. I assume that was meant for Josh or Tankan101, not me (despite it following my comment). ;)
  11. Jul 19, 2012 at 4:04 PM
    chewingonabone
    Josh
    Charlotte, NC
    09 Tacoma SR5
  12. Jan 30, 2019 at 5:54 PM
    tbird95
    tbird95 Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
    Oops
  13. Jan 30, 2019 at 6:00 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    Taco critter and medic2230 like this.
  14. Jan 31, 2019 at 5:44 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
