Intake for improved throttle response
Discussion in 'Arizona' started by XPOTRPR, Jun 6, 2011.
  1. Jun 6, 2011 at 5:44 PM
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hey Guys,
    Im looking for an intake to add some throttle response. Im not looking for power, MPG's, etc because i know thats ridiculous to ask for out of a CAI. I just want the sound and throttle response. what are the best intakes or drop in filters. I know the stock one on my 09 v6 4x4 is a Cold Air Intake but what are my options for either replacing the stock intake or using a different drop in filter? Also, did any of you take out the secondary filter or leave it in?
    Thanks guys.
  2. Jun 6, 2011 at 7:28 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    AFE is your best bet from what I've read. K&N ones when over oiled can cause the MAF to read incorrectly as the oil will get on the sensors.
    As for actual throttle response, if you have no supporting mods with it, it won't really do jack. The stock intake is already a CAI. Chris4x4 did a dyno test with the charcoal filter (secondary) in and removed, showed no dyno improvement.
    Myself, I just have a AFE Pro Dry drop in, works well enough for me (more than anything I just like the washable aspect). I do have a URD MAF tuner though, which actually would make a CAI such as the AFE Pro Dry realize some potential from the greater surface area and flow rate. Also, things such as eliminated cats, DT headers, exhaust, ect.... will help throttle response in the long run but just the intake alone won't do much other than make a little noise... honestly it doesn't justify the price tag.
  3. Jun 6, 2011 at 7:38 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    im definitely planning on adding more to it. Basically this is the first of the three (atleast) Intake, MAF sensor, exhaust. Im wondering which one would be the best fo that combo. I was leaning towards the AFE also. thanks for the input tho.
  4. Jun 6, 2011 at 10:34 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    have you ever heard of the deck plate mod?
  5. Jun 7, 2011 at 7:43 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I haven't. Even if its a 1st gen I'm still curious.. (like to keep up to date with this stuff)
    Also.. after an intake, I'm going to get an exhaust (leaning towards Aero Turbine) and then the URD MAF. Between those three things I should see an increase in response right? I had an intake and exhaust on my 06 and could tell the difference.. atleast I thought so.
    So should i replace the intake or keep it and through in a drop in filter?
    Thanks guys.
  6. Jun 7, 2011 at 8:16 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Haha.. I knew it was a matter of time Whippersnapper.. I've read all the threads. I'm not looking for a drag truck. Just coming from my 06 to my 09 I can tell there is a difference with the throttle response. Now I'm not sure if that is due to the intake and exhaust I had on my 06 or not, but just looking for any thoughts on what it could be.
  7. Jun 7, 2011 at 8:17 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Running auto or 6 spd? Also was your 06 a prerunner or 4x4?
  8. Jun 7, 2011 at 8:22 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Both were auto v6 4x4s. I was thinking that too.. that I just told myself it was quicker.. but I swear my 06 was. So i was just seeing what it MIGHT be if anything.
  9. Jun 7, 2011 at 8:50 AM
    97yota4wd
    Eric
    Mesa, AZ
    i knew it was first gen only... it was a test and you passed
  10. Jun 7, 2011 at 8:58 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Moose, where the tires the same size on both trucks?
  11. Jun 7, 2011 at 9:02 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yup.. different tread. Bfg all terrains on the 06 and nitto grapplers on now. I'm really thinking its just the exhaust and maybe an intake. OR... I'm crazy
  12. Jun 7, 2011 at 9:04 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    It can be done on 5-lug 2nd gens also!
  13. Jun 7, 2011 at 9:05 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  14. Jun 7, 2011 at 1:42 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    What's the tire weight diffrence? Also lift/size/ect? That can make a huge impact on such things as well.
  15. Jun 7, 2011 at 1:56 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm sure there is a difference.. but it can't be that much. both were running 32"s. The rest I'm not and can't really remember.
