Is $700 too much for OEM cv axle+install?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by L J, Feb 11, 2014.
  1. Feb 11, 2014 at 1:35 PM
    L J
    L J [OP] Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    This is what the dealership quoted me. Do you think I could get it installed at a repair shop for less? I can get an OEM cv axle for $326 before shipping from camelback toyota. It's cold as shit here right now and I don't have a heated garage to work in but if it's really as easy as some have said I might try doing it myself. Are the aftermarket axles any good cause they are much cheaper? I know that's a lot of questions but I'm trying to get a handle on my options. Thanks.
  2. Feb 11, 2014 at 1:38 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Yes, way to much
  3. Feb 11, 2014 at 1:43 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Yeah. Much too much. Specially since the install is damn near plug and play.
    Do it yourself for free.
  4. Feb 11, 2014 at 1:44 PM
    high voltage taco
    high voltage taco Well-Known Member
    Monticello, Ky
    05 TRD 6 speed 4x4
    so far, URD throwout bearing kit(sleeve), weathertechs, 285/70/17's on Ion 17x9 and OME 885s and Dakars and nitro sports. BHLM
    heck yeah way to much. Get you a $20 35mm socket, an axle from auto parts store with lifetime warranty, and a crowbar to pop the old one out and save about 550 bucks.
  5. Feb 11, 2014 at 1:49 PM
    MidnightRebel07
    MidnightRebel07 If you're gonna be a bear, Be a Grizzly !
    Jerry
    Northside of Pittsburgh, Pa.
    2013 Tacoma BAJA T/X dcsb
    Ironman Foam Cell Pro suspension, Anso black headlight housings, l.e.d. headlights, black taillights, Demello steel front bumper with highlight 7" l.e.d. round lights, Diode Dynamics Amber SS3 Pro lights, Hooke Road steel rear bumper with Nighlight reverse lights, Hooke Road roof rack, Ultima Aluminum toolbox, Weathertech floor mats, EGR in channel ventshades, Snorkel, K&N air filter and cabin air filter, 265/75/16 Cooper ST Maxx, Firestone ride rite airbags, Bentrodders bed reinforcements, too many other things to remember.
    Way too much for that job. Replacing CV axle shafts is pretty easy and straight forward, just need hand tools and the socket for the axle nut. If you've replaced the brake pads and rotors on your truck before then you're capable of replacing the CV axle shaft. JMO.
    A trick I started doing a long time ago when working on my rig in the cold is to have the tools that you'll need sit on the floor (under the heating vent in the truck) with the heat on for a while to warm them up, won't last forever but it sure helps.
  6. Feb 11, 2014 at 1:49 PM
    L J
    Illinois
    Have you done this yourself? I want to hear from someone whose done it and it really was that easy.
  7. Feb 11, 2014 at 1:49 PM
    96Taco
    96Taco Well-Known Member
    Alberta
    2014 DBL CAB Tacoma
    The amount of money saved in DIY car repairs is as much as a shitty 2nd job.
  8. Feb 11, 2014 at 1:52 PM
    L J
    Illinois
    Same question to you. Have you done this and it's as easy as unbolting some stuff and putting it back together? I've got the tools but I don't have anyone to help.
  9. Feb 11, 2014 at 1:54 PM
    L J
    Illinois
    I've rebuilt engines on dirt bikes and have always done brake related work on cars.
  10. Feb 11, 2014 at 1:55 PM
    foxhead
    foxhead Well-Known Member
    Andrew
    Colorado Springs, CO
    2016 DC Tundra
    Lol perfect way to put it
  11. Feb 11, 2014 at 1:58 PM
    tacoma4
    tacoma4 Well-Known Member
    Where are you in Illinois? You could probably find someone on here nearby to help out. Tons of people have done it here including myself. I just removed and replaced to put in a new front diff bearing. I think there's even a DIY on how to take it off in YouTube, search for fj cruiser axle replacement. But it's a pretty easy and straightforward job.
  12. Feb 11, 2014 at 1:58 PM
    brochacho
    brochacho Well-Known Member
    Vancouver, WA
    2016 4Runner SR5
  13. Feb 11, 2014 at 2:03 PM
    tacoma4
    Btw, Why are you replacing the axle? If its just a broken boot you can get an own kit from Toyota for a lot less than the axle. Also search the front diff vibration thread for how to pull the cv from the diff with steel cable. Much easier than a pry bar.
  14. Feb 11, 2014 at 2:05 PM
    high voltage taco
    Monticello, Ky
    05 TRD 6 speed 4x4
    yeah just a couple weeks ago. replaced left front wheel bearing, drivers diff bearing and added .25" spacer for drivers side lean all at once. Popping out the cv is the worst part and I used a crowbar to do mine and it worked ok. You can definetly do it yourself with hand tools. If you were closer I'd help ya.
  15. Feb 11, 2014 at 2:05 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I *have* done it. Four axles total (both sides, two times.)
    Personally, I found it to be a pain in the ass. Everything's more or less straightforward except for the actual popping in and out of the axle itself. Popping those CV axles out and in - there's a knack to it. It's just the right mix of subtle feel and brute force. So it went a lot faster the second time than the first.
    Don't take your time estimate for your first time from someone who's done a bunch of them.
    From what I hear - it was easier on the 1st gen's than it is on the 2nd gens.
    You only need to do one side? Cool - only half as much work then. :)
    Allow the full saturday with an option on sunday if things go pear shaped. Then if it goes easily - you've got time free on your hands. But you won't end up stranded without a truck.
    Here's my blood-sweat-and-tears story.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/186567-need-help-removing-driver-side-cv-axle.html
  16. Feb 11, 2014 at 2:26 PM
    L J
    Illinois
    Your story does not fill me with confidence. I'm sure I can get it apart but it's the putting it back together without screwing it up that's got me worried.
  17. Feb 11, 2014 at 2:30 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    I did it. Took longer than it really needed to but it wasn't hard.
    Someone had torqued the shit out of my 35 mm nut and we broke a few tools trying to get it off. And getting the CV to pop out and then back in took a little time. There is a trick to it for sure.
    But no, not hard.
  18. Feb 11, 2014 at 2:48 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Add up how much you're actually gonna save on the DIY job.
    Here are costs you haven't added in yet:
    You forgot the $50 shipping on that CV axle. They're heavy and the toyota dealer just uses UPS.
    $20 for that 35mm impact socket.
    $20 for the allen sockets you'll need to drain your diff oil
    $25 in diff gear oil (unless you replace with the really cheap stuff)
    $50 for those sears prybars.
    Plus the parts cost above, I think we just spent you up to $500.
    That assumes you've got the usual selection of tools: 1/2" sockets, torque wrench, floor jack, jackstands, impact wrench, etc...
    NOW is it still worth your while?
    Conversely, the more you do these jobs - the easier it is and the faster and more efficiently you work - and the deeper your toolbench is so that you're less likely to need to have to buy a tool to complete a job.
    I wanted to develop the expertise. It was worth it to me to do the job so that I knew I can replace a CV if I ever bust one out on an obstacle somewhere.
  19. Feb 11, 2014 at 3:13 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    An after market axle should be between 60 and 100 dollars. I installed them on my 4runner and they are fine unless you are super hard on the truck. Non dealer Install should be between 100 and 200 dollars.
  20. Feb 11, 2014 at 4:22 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    this is how I did it and saved a TON of time versus the link provided earlier in post #12
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/269828-ecgs-bushing-cv-boot-replacement-how.html
    there is more info in there than you need so i'll run it down for ya real quick.
    put truck in 4x4, apply e-brake
    loosen wheel lugs
    jack truck up, and support from frame
    remove wheel
    remove dust-cap thing (gently)
    pull cotter, remove BIG axle nut
    beat the end of the axle shaft until you see it pop in the hub a ways. use soft hammer
    remove 2 bolts holding lca to the spindle. they are on the bottom. lower ball joint bracket I think is scientific name
    now you can swing the hub and uca up while you beat the axle the rest of the way through. set the axle on lca and rest the spindle/hub/rotor/uca in a way that it wont stretch the brake line or abs wires. easy to figure out
    pop the axle with a crow-bar or the like and have a pan under the front diff to catch a little oil that should come out.
    install in reverse. I popped the axle back in with a chisel on the indents of the axle stub, so as not to stress boots or cv joints.
    its easy-peasy I promise. just be careful prying out the axle. the silver part that you see is part of the axle, not the diff. you will be able to confirm with a little wiggle
