is it OK to drive with a different size spare?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fibertop, Feb 13, 2010.
  1. Feb 13, 2010 at 1:44 PM
    fibertop
    fibertop [OP] Well-Known Member
    roger
    Ontario, Wasaga beach
    2010 sport DC
    I have upgraded my wheels but not my spare. The new ones are 32" OD and the the spare is the stock tie on a 17" wheel. Is it OK to use this spare if I got a flat? The outside diameters are different.
  2. Feb 13, 2010 at 1:46 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    its fine in an emergency situation. iv seen a big ol f-250 with probably 35s and then one of the tires was probably a 32, looked funny but if need be it works
  3. Feb 13, 2010 at 1:46 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    It should be fine as long as it's not for a long period of time.
  4. Feb 13, 2010 at 1:59 PM
    stenyeart
    stenyeart Well-Known Member
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    3" Toytec Lift w/ AAL, TRD CAI, Leer 700 Series, Hypertech Speedo Calibrator, Locker Anytime Mod, LR UCA's, OEM Roof Rack, Satoshi grill with Devil Horns Emblem, USA Spec PA-15 Toy Ipod Integration, Redline Tuning Hood Struts and EZ Down Tailgate.
    Emergency situation only - if it is on the rear, the smaller tire will have to spin faster to keep up with the larger tire. I am in the same boat, but if I get a flat in the rear, I would put the spare on the front and put the front tire on the rear. You can put it on and limp somewhere to get it fixed. I just wouldnt drive at freeway speeds.
  5. Feb 13, 2010 at 2:20 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    x2
  6. Feb 13, 2010 at 2:37 PM
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Just do not put it in 4 wheel drive! That could mess it up!
  7. Feb 13, 2010 at 2:51 PM
    Brunes
    Brunes abides.
    Rotorhead
    Find a used tire place and get a spare that is the right rim size for your spare rim and the right OD for your new tires.
    No more concern and it's a cheap fix!!
  8. Feb 13, 2010 at 2:51 PM
    crittergitter
    crittergitter Proud to be Canadian Navy
    Stu
    Shearwater, NS
    '06 Tacoma 4WD Double Cab
    Bugger, skid plate, colour coded cap, bed mat, AFE Air Filter, Rear diff breather mod, Chirp on door lock;unlock, ABS mod, Weathertechs front and rear, 60" Hi-lift jack, LED light mod in rear bed, 12V accessory in bed, n more stuff.
    Four wheel drive will burn up the front differential. I know this from experience. A new front diff for an '06 4WD is $2047 Canadian. Covered under warranty as they said a seal had gone. I suspect the seal went because the diff was so hot. The oil when it was dripping out was hissing on the wet pavement. That price does not include labour or fluid.
  9. Feb 13, 2010 at 3:06 PM
    fibertop
    roger
    2010 sport DC
    any problem fitting the bigger tire up in the spare tire hole? I hear its pretty tight.
  10. Feb 13, 2010 at 3:10 PM
    fibertop
    roger
    2010 sport DC
    thanks for all the advice guys! I might look for a compatable spare tire and wheel.
  11. Feb 13, 2010 at 3:20 PM
    ajohnson
    Andy
    Charlotte, NC
  12. Feb 13, 2010 at 3:21 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    put the spare on the front and the front one on the rear if possible
  13. Feb 13, 2010 at 3:23 PM
    fibertop
    roger
    2010 sport DC
  14. Feb 13, 2010 at 3:29 PM
    ajohnson
    Andy
    Charlotte, NC
    :cheers:
  15. Feb 13, 2010 at 3:55 PM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    DONT put it in 4wheel drive and dont drive far or fast and you will be safe and wont f up your transfer case
  16. Feb 13, 2010 at 4:31 PM
    ofrd4fun
    ofrd4fun Well-Known Member
    Vancouver BC
    05 DC 4x4
    FJ Cruiser wheels, air bags, 5100's @1.75, TC UCA's, bi-xenon HID's
    The largest tire that will fit under the bed in the spare location without modification is 265\70\17.
    Fortunately it matches the four on the truck!!!
  17. Feb 13, 2010 at 4:37 PM
    fibertop
    roger
    2010 sport DC
    mine are 275/65r18. So no fit?
  18. Feb 13, 2010 at 9:55 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I dont think you can run a different size spare on 09+ in the rear. The new LSD will go crazy.
  19. Feb 14, 2010 at 11:35 AM
    ofrd4fun
    Vancouver BC
    05 DC 4x4
    That size is 1/2" larger in diameter than what I have. On my truck there is no room between the hitch and the tire but my hitch is not a factory part. Being only slightly larger you would have to try it and see.
