Is there a way to change the default Cruise Control?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by huskcummerbund, Dec 5, 2021.
  1. Dec 12, 2021 at 7:47 AM
    #41
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    X2
  2. Dec 12, 2021 at 8:28 AM
    #42
    huskcummerbund
    huskcummerbund [OP] Well-Known Member
    2020 TRD-OR MT
    Pretty sure I already turned that off too.
  3. Dec 12, 2021 at 8:29 AM
    #43
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Brake assist can’t be turned off.
    bluelinetaco likes this.
  4. Dec 12, 2021 at 8:43 AM
    #44
    bluelinetaco
    bluelinetaco Well-Known Member
    North Cali - Yay Area! (707)
    2019 TRD Pro VooDoo Blue
    COOL Stuff I can't afford . . . But I bought anyway!
    not sure turning th brake assist off is possible. But I’ve been wrong before and could be wrong now.
    personally, I don’t see the problem with the brake assist, it’s helped a few time trying to get through downtown San Francisco with People who love to randomly stop.
    the assist does not “brake for you” it helps you. If your not on the brakes hard enough, it will apply more braking power to get you to where it needs to be. If you get on the brakes harder as it’s helping it backs off and allow you to be in full control.
    again, the only time the truck will do the braking for you is In the event it cannot slow the truck under normal deceleration in radar cruise. The only time the truck brakes in collision avoidance is if you do not apply the brakes within a set amount of time the system detects one.
    all of this info is in the manual, knowing how these systems work helps you do drive with them, not against them.
    I had a ‘17 OR. When I got the my ‘19 pro, I very happy with the safety sense systems. And if you do a good amount of commuting and highway driving, they can actually make things a bit more pleasant.
    Radar cruise cannot be activated under 30mph (if I recall)same for lane departure. But, the radar cruise will bring the truck to a full stop in traffic. But then again, you shouldn’t be using cruise in Med to heavy traffic anyway.
    but, alas, to each their own. If you don’t like it, you don’t like it. However, i revert back to, “why buy it if you’re not going to use it?”
  5. Dec 12, 2021 at 11:05 AM
    #45
    huskcummerbund
    2020 TRD-OR MT
    I'm not a 12v guru, so I'm figuring this out as I go, but now that I've slept I think you may be on to something. If I just stick a 5v triggered relay in between the two wires I should be able to do exactly what I'm looking for. As long as I can find the wires under the dash.
  6. Dec 12, 2021 at 11:06 AM
    #46
    huskcummerbund
    2020 TRD-OR MT
    I turned off a lot of shit in this truck. It's hard to keep track.
    brian2sun[QUOTED] likes this.
  7. Dec 12, 2021 at 11:13 AM
    #47
    huskcummerbund
    2020 TRD-OR MT
    So, I'm weird. I drive 1.5hrs each way in Boston traffic and I specifically required a stick shift truck. I won't use a cruise control that has access to the brakes, which is the first thing it did when I first tried radar assisted cruise. It's been avoided ever since in favor of Cruise Classic. I set the cruise to the speed I want to go when I know I can use cruise at the speed I want to go. I will say that I have actually grown fond of the physical cruise controls, they are actually easier to use than on my last car.
    As for "why buy it", I bought the whole truck, not the cruise control. I required a stick shift pickup, and the only other option was the Gladiator... and fuck the Gladiator.
    bluelinetaco[QUOTED] likes this.
  8. Dec 12, 2021 at 11:16 AM
    #48
    huskcummerbund
    2020 TRD-OR MT
    That is also the reason why I do not trust AEB and LKA, and disable those too if it is possible.
  9. Dec 12, 2021 at 11:17 AM
    #49
    huskcummerbund
    2020 TRD-OR MT
    When I first tried it, I still had at least 10 car lengths in front of me. Plenty of time for engine braking. It hit the brakes and got shut off immediately.
  10. Dec 12, 2021 at 11:18 AM
    #50
    huskcummerbund
    2020 TRD-OR MT
    I had no intention of doing that. I was just illustrating my thought process that determined this was a terrible idea before it was suggested.
  11. Dec 12, 2021 at 11:24 AM
    #51
    huskcummerbund
    2020 TRD-OR MT
  12. Dec 12, 2021 at 11:51 AM
    #52
    Cereal_killer
    Cereal_killer Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
    So pretty much you just want to bitch then? It’s mean you’re at the right place, TW is a shithole now days…
    the answer to your question is no, no there’s not a way to disable it or set standard CC to be default. You’ve got you’re answer but you just keep dragging it out. It’s not Friday anymore let this thread die.
    We’ve given you workable options, if you don’t want to perform any of them that’s fine but quit being so hostile my guy.
    nictarine likes this.
  13. Dec 12, 2021 at 11:57 AM
    #53
    brian2sun
    California
    Ahh, the good ol’ days, way back to last June when you joined this site and it wasn’t a shithole.
  14. Dec 12, 2021 at 12:07 PM
    #54
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    I get a few phantom “BRAKE” alerts from the collision avoidance system a year. Seems to match up when there is sun glare or high beams hitting the front camera.
  15. Dec 12, 2021 at 12:09 PM
    #55
    huskcummerbund
    2020 TRD-OR MT
    If your idea of a workable option is to point the sensor at the sky, you probably shouldn't be offering any advice in the first place.
  16. Dec 12, 2021 at 2:01 PM
    #56
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    What scenarios does it slam the brakes on? I've only had mine a couple months but I haven't had anything like that happen with mine and I use it daily.
    You mentioned it did it a "half block" away. Are you using it in town? Would you use regular cruise in town?
  17. Dec 12, 2021 at 2:05 PM
    #57
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    you drive in dense traffic 1.5 hrs/day and you want to constantly be applying the brakes/accel and disable the thing that takes workload off of the driver?
    OmahTako and bluelinetaco like this.
  18. Dec 12, 2021 at 2:11 PM
    #58
    huskcummerbund
    2020 TRD-OR MT
    To whom are you replying?
  19. Dec 12, 2021 at 2:15 PM
    #59
    huskcummerbund
    2020 TRD-OR MT
    Well, since I drive stick that feature isn't that useful in stop-and-go traffic, what with the stalling and all. In dense traffic I don't use cruise at all.
  20. Dec 12, 2021 at 2:20 PM
    #60
    GrundleJuice
    Michigan
    2016 TRD Bro
    Ahh, yeah with a stick cruise is not as universal.
    There are many settings that can be changed in the Toyota TechStream software, like power window, turn signal, climate control behavior, etc. I have only used the older version that supports earlier MYs but it might be worth investigating. The may be a TW member that would know.
