just got my light racing UCA's
Discussion in 'Suspension' started by kieth, Apr 27, 2011.
  1. Apr 27, 2011 at 5:06 PM
    kieth
    kieth [OP] Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    hey so i just got my LR uca's today super pumped to put them in this weekend. I just had a few questions for some of u guys who have installed them. I understand how to postion the ball joint washers with the spc logo facing the tire to achiev the 2 degrees of caster until i get to the shop for the alignment and it should be okay. Im just not sure how i should set the sliding adjustment of the ball joint to the arm for camber adjustment, I just want to be close enough so when i drive 15 miles to the shop to align it , that its not gonna give me major problems, thanx if u guys have any advice thatd be great
  2. Apr 27, 2011 at 7:39 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I've never seen Keith spelled "kieth" before.....
  3. Apr 27, 2011 at 7:41 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I put mine where it is indicated on the instructions
    The neutral setting , adding the 2* of built in caster , is " D " on these instructions .
  4. Apr 27, 2011 at 8:13 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    He is pronouncing it with a Canadian accent....:rolleyes:
  5. Apr 27, 2011 at 8:18 PM
    OZ-T
    Peter North
    British Columbia
    Oy , I didn't notice that before
    :canada:
    OP , pm me if you have any questions , we just installed mine last week
  6. Apr 27, 2011 at 8:34 PM
    brelandt
    Terry
    Dublin, CA
    I will need a set myself one of these days. How much are you guys paying for them?
  7. Apr 27, 2011 at 8:38 PM
    OZ-T
    Peter North
    British Columbia
    I think there may be a group buy going on here , but this is from the Toytec website to give you an idea
    EDIT : the group buy is over
  8. Apr 27, 2011 at 9:06 PM
    brelandt
    Terry
    Dublin, CA
    holy crap! $450!!!!! A lift kit cost less than that, but to correct what the lift does you have to spend $450?!?!?! I'm not going ever be able to afford them, UGH!
  9. Apr 27, 2011 at 9:12 PM
    OZ-T
    Peter North
    British Columbia
    What lift costs less than $450 ?
  10. Apr 27, 2011 at 9:14 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    x2 even aal and coils, shocks front and rear would be well over $450
  11. Apr 27, 2011 at 9:17 PM
    IluvTEA
    IluvTEA Well-Known Member
    South Dakota
    '10 DC LB 4x4 SR5 Super White
    Cooper ST 265/75/16 on Flat Black TRD OR wheels, window tint, blacked-out badges, front mudflap trim, BHLM, Base Black Rear Bumper Swap, Color-matched grille, Custom Relentless Fab plate bumper powdercoated flat wrinkle black and "TACOMA" backlit with Drunknsloth LEDs, Camburg 2.5" coilovers, LR UCAs, Power sliding rear window, Back-up camera anytime, FX-R projectors/Morimoto 3Five Ballasts/D2S bulbs 5000K, Black WeatherTechs, heated TRD seats with Roadwire Graphite Leather, OEM Roof Rack, front mud flap delete, Black Level 8 Guardians, TreadWright 285/75/16 with KG ...
  12. Apr 27, 2011 at 9:17 PM
    IluvTEA
    South Dakota
    spacer lifts are cheap (for a reason)
  13. Apr 27, 2011 at 9:22 PM
    brelandt
    Terry
    Dublin, CA
    I have a AAL for $70, 3" spacers for $100, longer rear shocks where $60. been using the front spacers for 6 years now without one problem. However, I have a prerunner and therefore do not off road it like a 4x4, so for me it works fine.
  14. Apr 27, 2011 at 9:37 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    ya exactly you dont offroad therefore you dont need the capabilities an actual lift kit would provide, it works for some, im not denying that, but IMO spacer lifts are junk either way, whether you offroad or not the quality of the ride they provide sucks
  15. Apr 27, 2011 at 9:52 PM
    brelandt
    Terry
    Dublin, CA
    um, I have had them off and on a couple of times and there isn't much difference in ride. The biggest thing is when I come down off of a speed bump you can hear a noise from the coils coming unloaded but that's about all.
    If I where to have a 4x4 I may look into something else?
    But back to the point. I think if money wasn't an issue than I would just assume get a LT if I was going to go thru all of this, LOL!
    Anyway, to the OP hope it works out.
  16. Apr 28, 2011 at 4:31 PM
    kieth
    06 trd
    i understand how to postion the caster adjustment to the neutral setting i just wasnt sure what would be a good spot for the sliding camber adjustment slot before i got it aligned
  17. Apr 28, 2011 at 4:35 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i installed mine slightly ni from all the way out
  18. Apr 28, 2011 at 4:54 PM
    OZ-T
    Peter North
    British Columbia
    I installed mine with it all the way toward the tire .
