Knock sensor code P0325 & P0330
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomatrd22, Sep 20, 2016.
  1. Nov 16, 2017 at 5:23 PM
    #41
    1997tacomav6
    Denver
    My sensors went bad, working sometimes and sometime not and I did NOT get a code and that's why it took me 3 months to figure it out. One day would run fantastic and another day like a dog
    Luv my yota likes this.
  2. Nov 16, 2017 at 5:54 PM
    #42
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    That's what I'm thinking! I heard that ECU's up to 2000 were not communicating as well as 01-04 ECU the 01-04 work better with throwing codes-they are more sensitive. I don't want to pull the intake again but knock is bad, I don't hear knock, but I don't trust that harness. I've been in and out of there in 2 hrs taking my time. About the auto trans!! I dropped the pan, drain&fills looked clear/red but when the pan came down it was dirty! The trans filter I tried flushing, but it just kept pushing out clutch material after a whole can o' brake clean. I bought a factory filter and flushed the trans myself with 25 quarts, I know that's overkill but it's my baby. Now my truck is passing slower V-8's again. This thread convinced me that the knocks sensors and harness should be preventative maint, but the trans was most of it and I will be doing sensors/harness next using the EBay one's! Thanks to all of you're knowledge guys the old gal can stay alive.
    #42
    tacomatrd22[OP] likes this.
  3. Nov 17, 2017 at 10:23 PM
    #43
    tacomatrd22
    tacomatrd22 [OP] TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Didn't know about 2000's and below didn't have as good communications as the 01-04's. I'm actually really surprised that your truck isn't slipping after doing a flush. How many miles did your truck have when you did this? But I'm glad this helped out and I'll try and remember what you guys have said.
    #43
  4. Nov 17, 2017 at 11:25 PM
    #44
    Luv my yota
    00 turd lift 33's
    The trans was in stock in a crate at Toyota brand new I put it in 35k ago but it's surprising how much crap sits in that tranny filter. That trans has been getting drain and fills every oil change because I thought the filter was not too necessary yet, but I know now every year I'll be dropping the pan and swapping filters for new ones! I hope it doesn't start slipping but so far so good. Still gonna change my knock sensors and harness even if it don't need it. It was slow before like a 22re with an auto, now it goes.
  5. Nov 19, 2017 at 9:17 PM
    #45
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    You shouldn't be worrying about your transmission slipping at all if it's brand new and especially for you changing out the oil and dropping the pan every year to change the filter. I might do what that so I don't have to worry about it anymore.
  6. Nov 20, 2017 at 12:24 AM
    #46
    Luv my yota
    00 turd lift 33's
    I agree, preventative medicine is best. We can almost get away with being cheapskates if we want with these trucks, but if we we go too far some yotas fubar, it's happened to me. Nowadays I'm taking real good care of it because it's been pretty damn reliable! I think Toyota had a good one with our 1st gens.
  7. Nov 21, 2017 at 7:49 PM
    #47
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    The 2nd gens ain't to bad as well. A couple that always comes in for an oil change puts Quaker state still runs great with over 350K miles. Even though I wouldn't be putting that oil in my truck.
  8. Nov 21, 2017 at 11:56 PM
    #48
    Luv my yota
    00 turd lift 33's
    I wouldn't use that stuff either, but it goes to show if you keep it up, there won't be monsters in the closet later.
  9. Sep 17, 2019 at 8:07 AM
    #49
    Pabobfin
    Pabobfin Member
    Bob
    2014 Tacoma 4 door short bed
    none
    Got the code PO333 and decided to make the 60 mile trip to Brewer Maine and let Toyota deal with it. I only want it fixed because it might damage stuff AND I love Cruise Control.... grrr.
    Hope it won't be arm and leg amputation time.
    Bob
  10. Sep 17, 2019 at 2:02 PM
    #50
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    If you have a multimeter you can test the sensor before replacing wiring or sensor
  11. Sep 20, 2019 at 11:03 AM
    #51
    Pabobfin
    Pabobfin Member
    Bob
    none
    OK, so Downeast Toyota spent a couple hours diagnosing, and tells me that "rodent damage" was evident on the boroscopic exam, as well as tons of sunflower seeds stashed about the place wherever the damage is. I don't know the locations and details. Estimage to FIX
    Drum roll
    $2100
    And the job will take 12 hours, so that has to mean two days. So will need a car rental or a hotel for the night. Parts backordered too just to make extra driving.
    Will work out the logistics and I just ordered DECON to put in garage and away from dog and cat.
    FIRST EVER repair needed on my Tacoma(s) this is my 4th, and got 10 years to 13 years out of first three.
  12. Sep 20, 2019 at 2:54 PM
    #52
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    As someone who does my own work this seems just absurb! But if you're happy- we're happy!
  13. Sep 20, 2019 at 4:58 PM
    #53
    Pabobfin
    Pabobfin Member
    Bob
    none
    I’m glad that you can do your own work. I practice medicine and keeping current on treating humans is difficult enough for me. I leave auto repairs to those who have studied it and know what they are doing. Best wishes
    vasinvictor[QUOTED] likes this.
  14. Sep 21, 2019 at 7:19 AM
    #54
    Pabobfin
    Pabobfin Member
    Bob
    none
    Curious also: While the problem persists, (waiting parts) I noticed that RPM at 70MPH is about 3000, and it usually goes down to about 1800 on straight and level road, is this problem also associated with Trac Off, Check Engine, No Cruise Control? It acts as if it is in 4th gear (Automatic Tranny) not Drive.
  15. Feb 1, 2021 at 11:00 AM
    #55
    kskin
    kskin Member
    k
    1999 Tacoma 4x4 V6
    SR5
    Any chance you still have the torque spec for the intake manifold? I just replaced my sensors but can’t find this info anywhere
  16. Feb 1, 2021 at 11:05 AM
    #56
    ThunderCookies
    ThunderCookies This is the Wait
    Jon
    North Carolina
    06 Wolfpack Edition
    5100s at 2.5 setting up front 5100s with 2" AAL around back TC Uniball UCAs 285/70/17 Fierce Attitude M/T SCS Ray 10s 17” 14" Magnaflow w/3.5" Stainless Tip SOS aluminum armor front bumper SOS high clearance rear bumper Stealth grill light bar and pods 4" Westin Nerf Bars Weathertech in-channel visors Window tint Bed Mat Proven Ground Locking Roll-Up Tonneau Cover All-weather rubber floor mats Custom Wolfpack TRD Decal TOYOTA Vintage Tailgate Decal 4 Wheel Drive vintage decal Tailgate Anti-Theft Mod Bed Mat Anti-Theft Mod Sliding back glass Anti-Theft Mod Future Mods: Bedside bottle opener Bedside storage lock/key mod Bed pod lights
  17. Oct 18, 2022 at 2:56 PM
    #57
    kodayoda
    kodayoda New Member
    k
    2000 tacoma 3.4l v6
    All of the FSMs that I downloaded from here for the first gen Tacoma have incomplete/corrupt pages. Does anyone have the torque specs for assembling the intake manifold?
  18. Oct 22, 2022 at 7:45 PM
    #58
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    13 ft-lb on all 3 pieces
