LED Conversions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rockstar Junkie, Sep 25, 2008.
  1. Sep 25, 2008 at 11:57 AM
    Rockstar Junkie
    Rockstar Junkie [OP] Well-Known Member
    Springville,UT
    06 4x4 TRD Sport
    Anyone do any LED conversions to any of your light bulbs on the Taco or any car for that matter? Side markers, tails, blinkers, etc, etc, etc.
    Let me know. I am curious on what has been done and available. Looking for a little feedback!
  2. Sep 25, 2008 at 12:39 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I switched over all my dash lights, domelights, brake lights, and reverse lights to LEDS
  3. Sep 25, 2008 at 12:41 PM
    HighDesert
    HighDesert Active Member
    99 4x4
    I tried several interior and exterior over-the-counter replacements purchased on ebay. In general the leds were considerably less bright than the incandescent lamps. My advice, for what it's worth, is if you intend to go with exterior led replacements, look for DOT approval--you will not find many and you may need to do some mods to get these to fit but they will be bright. Internally, I am experimenting with several Nichia U bin 5 mm leds wired in parallel with resistor on a perforated circuit board as a replacement for the dome light and this is indeed fairly bright. In general, use good quality high lumen leds.
  4. Sep 25, 2008 at 12:43 PM
    dually
    dually Low and slow
  5. Sep 25, 2008 at 12:46 PM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    Can you make your dash/guage lights a different color?
    Were your brake lights and reverse lights brighter now. Word is that they are not brighter, just more vivid in color? Any truth. They say that like 25 LED bulbs are brighter than stock. Let me know what you think.
  6. Sep 25, 2008 at 12:54 PM
    HighDesert
    99 4x4
    It's not the number of leds, but the overall lumen rating. For example, a single Cree or Luxeon led can produce more lumens than ten or twenty smaller 5 mm leds. Leds are also extremely directional so side lighting becomes important. Don't mess with substandard stuff. I saw way too many accidents, as a firefighter, due to poor lighting.
  7. Sep 25, 2008 at 1:02 PM
    dually
    dually Low and slow
    Yeh, my interior is blue. My brake lights are about the same. I really like my reverse lights now, they're a really white light.
  8. Sep 25, 2008 at 1:05 PM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    Can you take some pics of the tail and reverse lights?
  9. Sep 25, 2008 at 1:12 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I would be interested in seeing these pics of the reverse lights also.
  10. Sep 25, 2008 at 1:18 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  11. Sep 25, 2008 at 1:26 PM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    Has anyone put them in the front turn signals? That way the DTRL Mod makes them stand out more?
  12. Sep 25, 2008 at 1:43 PM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
  13. Sep 25, 2008 at 1:58 PM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    Dang... thats sweet. Too much work. I know i would mess something up. Anyone done the sway on the front blinkers?
  14. Sep 25, 2008 at 2:01 PM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    Think this bulb would do the trick for the Reverse, Tails, and front blinkers? It has a few LED's on the sides. I would get the correct colors according to the lens color. Let me know!
  15. Sep 25, 2008 at 3:02 PM
    dually
    dually Low and slow
    It took me 30min, honestly. It's so simple. I'll see if i can get some pics of my reverse and tail lights once it gets dark.
  16. Sep 25, 2008 at 3:03 PM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    Sweet Thanks!
  17. Sep 25, 2008 at 3:07 PM
    Shadow-Warrior
    Shadow-Warrior Well-Known Member
    Arkansas
    07 TRD FJ Crusier
    To Many to list here
    I had a guy change out all my LED's in the dash from white to Red. The Dash, AC & Instrument Cluster all to RED LED's, very cool. It's great for keeping your night vision.
  18. Sep 25, 2008 at 3:26 PM
    Okkine
    Alberta
    I thought the dash/instrument lites came in red?
  19. Sep 25, 2008 at 3:44 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    His FJ might be the opposite.
  20. Sep 25, 2008 at 3:56 PM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    Someone out there has to of switched the front blinkers to LED bulbs.....anyone?
