LED for cup holder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Barry J, Oct 18, 2009.
  1. Oct 18, 2009 at 5:20 PM
    Barry J
    Barry J [OP] Well-Known Member
    Massachusetts
    I wanted to light up my cup holder area, my wife has a Nissan Rogue and she has a dim amber light near the sunglass holder that shines down on the console.
    I thought about putting an led strip underneath the lip on the center dash, just above the climate control. Could I just buy a strip of three orange lights 3m double tape it to that area and wire it to my fuse box some how???
    Any comments or suggestions
    Thanks
    Barry
  2. Oct 18, 2009 at 5:29 PM
    GT_Taco
    GT_Taco Newbie here
    Marietta, GA
    2016 4Runner 4x4 Limited Metallic Gray
    5K LED interior lighting
    You know this is actually a factory option on the 09 Tacos.. (I have it in mine). You can pull the console out and actually drill a hole in the side of the cup holder area (or multiple holes). Insert a single LED per hole controlled by a switch.. tie the switch into the fuse box...
  3. Oct 18, 2009 at 5:30 PM
    Tat2dTaco
    Tat2dTaco He who breaks things.
    Ricker
    San Antonio, TX
    05 SWB Prerunner
    Camburg Spindles All-Pro Expo Leafs Bilstein 5100s and 7100s DTF Pre-Runner Bumper Tons of other crap
  4. Oct 18, 2009 at 5:34 PM
    Barry J
    Massachusetts
    I wanted to put mine in that overhang over the climate control, anybody done it that way yet??
  5. Oct 19, 2009 at 4:23 PM
    Barry J
    Massachusetts
    ok, no one has done it..how about anybody know how I go about doing it???
    Thanks
    Barry
  6. Oct 19, 2009 at 5:33 PM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    Keep us in the loop on how you do it....:)
    Yuma Taco,
  7. Oct 19, 2009 at 5:52 PM
    Taco Ron
    Taco Ron Male Member
    You could use something like this:
    http://www.oznium.com/thin-led-strip
    Oz has tons of lighting products that will fit just about any application you can throw at them. Best customer service around too.
  8. Nov 5, 2009 at 5:52 PM
    Barry J
    Massachusetts
    If I were to buy a light strip from oznium.com, does it come with instructions on how to wire it up so that it comes on when the lights come on??? How could I wire that??? Splice it in somewhere???
  9. Nov 5, 2009 at 6:35 PM
    BSP4x4
    BSP4x4 Guest
  10. Nov 6, 2009 at 3:21 PM
    Barry J
    Massachusetts
    nice link, but how is it wired into the stock wiring or into the fuse box, If I'm just starting from scratch, with a led strip, where does that get wired to???
    I don't already have LEDs in the door.
    Thanks
  11. Nov 6, 2009 at 3:43 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I wouldn't put too many lights in there, you'll get too much and it will glare inside your cab at night. The write-up I did, which was posted above is sufficient, the radio shack LED's aren't very bright so overall its perfect, but if you want a little more light, you could use 4 altogether. My setup is wired into the dimmer system so it works with the dimmer switch.
  12. Nov 6, 2009 at 7:52 PM
    BSP4x4
    BSP4x4 Guest
    click on the link and there is another link on that page called "original install thread"
    That shows how i did it!
  13. Nov 6, 2009 at 7:56 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  14. Nov 6, 2009 at 7:57 PM
    BSP4x4
    BSP4x4 Guest
    I have close to 17 leds on the interior. Blue 5mm from oznium.com...they are no where near too bright, and can be turned off any time with a switch :)
