LED headlights!
Discussion in '1st Gen. Tacomas (1995-2004)' started by sgt1577, Feb 10, 2016.
  1. Feb 10, 2016 at 7:37 AM
    sgt1577
    sgt1577 [OP] Well-Known Member
    2004 Tacoma 4X4
    image.jpg Just installed these! Can't wait to try them after work!
    chrslefty likes this.
  2. Feb 10, 2016 at 8:52 AM
    TacomaNerd
    TacomaNerd Member
    Las Vegas, NV
    Tacoma 3RZ-FE 2.7 L
    Are those the OPT7 LED Headlight Bulbs?
  3. Feb 10, 2016 at 9:17 AM
    sgt1577
    2004 Tacoma 4X4
    Yes they are! Easy install and seem to be very bright! Was going to take a "before" pic but I had one headlight burned out already
  4. Feb 10, 2016 at 1:02 PM
    TacomaNerd
    TacomaNerd Member
    Las Vegas, NV
    Tacoma 3RZ-FE 2.7 L
  5. Feb 10, 2016 at 1:25 PM
    sgt1577
    2004 Tacoma 4X4
    That's them! Be careful when you order them as there are several versions that all look the same. Amazon asks for your vehicle info to make sure you get the right ones!
    FYI I did end up with the no hi-beam indicator light problem
  6. Feb 15, 2016 at 2:07 PM
    rynod337
    rynod337 Active Member
    Charlotte, NC
    2004 SR5 Tacoma Double Cab
    do you have any before and after pics? if not are you happy with the results?
  7. Feb 15, 2016 at 2:43 PM
    sgt1577
    2004 Tacoma 4X4
    No before pics as I had one burned out. They're ok... Nice bright/white light. Nice pattern and no dark spots. A little bummed at the no hi-beam indicator light error. I'll be ordering a resistor.
  8. Feb 15, 2016 at 4:32 PM
    TacomaNerd
    TacomaNerd Member
    Las Vegas, NV
    Tacoma 3RZ-FE 2.7 L
    Looks Great!
    I'm pretty new to this, what does the no hi-beam indicator light error mean?
    Can you use both the high & low beams?
    Is it that the high beam light on your gauge is always on?
  9. Feb 15, 2016 at 4:40 PM
    sgt1577
    2004 Tacoma 4X4
    Close! The hi-beam indicator on the dash does not come on. Otherwise they work as they should!!! :D
  10. Feb 15, 2016 at 4:52 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
  11. Apr 20, 2016 at 9:33 PM
    Jar_Topham
    Jar_Topham Member
    Jar
    Tacomas 2005
    The light looks great, love leds so much.
