Lexus Credit Card Key Working in Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Victory, Aug 15, 2016.
  1. Feb 6, 2017 at 3:54 PM
    #161
    erok81
    erok81 Well-Known Member
    Imposter
    @gpb sweeeeeet! That's good to know. I think I'll do mine tomorrow then. I was a little nervous reading when I first was going to do it. I figured I would probably end up jacking up my keys somehow and having to tow to the dealer! But it doesn't sound too bad.
    I'll definitely take one of the tokens. I'll PM sometime tonight or tomorrow and we can figure something out.
    Thanks for being the guinea pig!
    gpb likes this.
  2. Feb 6, 2017 at 5:45 PM
    #162
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Happy to help. I figured worst case it'd be a 4 mile tow to the dealer and fork over some $$$. So why not give it a go? :)
  3. Feb 7, 2017 at 8:53 AM
    #163
    NitroExpress
    NitroExpress Active Member
    Texas
    '17 TRD PRO
    I just had my key successful programmed. The locksmith was dubious about this working, but he was willing to give it a try after explaining the cost would be $50 no matter the outcome. He used the 2015 IS250 Lexus and all is well. This is a very expensive way to not carry a key fob, but I detest keys and needed an additional spare.
    Thanks to the OP for all the time and research!
    gpb likes this.
  4. Feb 7, 2017 at 9:41 AM
    #164
    gpb
    Atlanta
    FYI, the blank from the ebay link works fine; took it to a locksmith along with an existing key and they cut it for $20.
    (Atlanta folks, these guys are good: https://sandyspringslocksmith.com/ )
  5. Feb 10, 2017 at 2:49 AM
    #165
    maui86
    maui86 New Member
    Teri-Martin
    Maui, Hi
    2017 MGM Tacoma DCSB TRD Off-Road
    This is freaken amazing! I am a locksmith on Maui and I'm going to order this tomorrow from our supplier. I am able to cut and program the key. It's always good to know alternative keys to use and I thank you OP for figuring this out. I look forward to being able to just carry a phone and wallet now!
    To try clarify some things. If the locksmith you call is using an MVP Pro, it'll likely cost him $10-30 to program the key(1 token). If he messes up, he will have to use another token. That's likely why you may get resistance from those that could, but won't do anything other than factory setups.
    I use the T-Code Pro(non-token setup) so things like this is just a matter of usage of time. Toyotas are weird when it comes to smart keys. If you buy a used key, the truck will know that when trying to program. Some will allow you to add, others will force you to reset the immobilizer. Not sure why this is the case, but that's how ALL Toyota/Lexus smart access systems are. Add takes ~5mins to do, reset is ~16-20mins. If you have to reset, all keys you want to work need to be present otherwise it'll be erased after the system is closed.
    This is exciting and I can't wait to get it done!
    Teri
  6. Feb 10, 2017 at 5:23 AM
    #166
    gpb
    Atlanta
    @erok81 - just making sure you're not waiting on me for one of my extra weboctopus.nl reset passcode tokens.
  7. Feb 10, 2017 at 12:35 PM
    #167
    erok81
    Imposter
    I still want one so save it! I've just been really busy with work. I'll try to get the PM then payment over to you today or tomorrow. Assuming you still have a token?
  8. Feb 10, 2017 at 12:42 PM
    #168
    gpb
    Atlanta
    Yes, I still have four tokens of the five I'd bought (min purchase). This isn't exactly a high demand item. LOL
    I just wanted to ensure you'd hadn't contacted me and it not come through. No hurry, you've certainly got dibs on one. :)
    erok81[QUOTED] likes this.
  9. Feb 12, 2017 at 7:05 AM
    #169
    PeeDeeTaco
    PeeDeeTaco Custom Title
    Effingham, SC
    2017 TRD Off Road 4x4 DCSB Blazing Blue Pearl
    5100 + OME 888 + Headstrong AAL SOS Offroad Concepts Streamline Winch Bumper Smittybilt XRC 9500 winch Method Race Wheels MR308 Roost Falken Wildpeak AT3W Image Dynamics speakers/sub Tacotunes Amp and sub enclosure
    Messaged you I think
    gpb[QUOTED] likes this.
  10. Feb 12, 2017 at 7:17 AM
    #170
    gpb
    Atlanta
    Replied.
  11. Feb 12, 2017 at 2:57 PM
    #171
    erok81
    Imposter
    I'm doing mine! (Used key) This is the most stressful 16 minutes I've had in a while.
    Thankfully I found my spare key. It was wrapped in tin foil in my rtt. :anonymous:
    gpb likes this.
  12. Feb 12, 2017 at 3:06 PM
    #172
    gpb
    Atlanta
    Good luck. Yes, you MUST have every key you want it to recognize. The used key procedure wipes everything. :eek: :thumbsup:
  13. Feb 12, 2017 at 3:30 PM
    #173
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Tough to tell reading this thread.
    Is the process simpler if I buy a new key?
  14. Feb 12, 2017 at 3:31 PM
    #174
    gpb
    Atlanta
    Yes, should be just an add and maybe even find a locksmith that'll do it.
    Not nearly as exciting though. :)
  15. Feb 12, 2017 at 3:31 PM
    #175
    erok81
    Imposter
    Way easier.
    But...I'm giving this one more try. If I doesn't work I'm selling a brand new (but programmed) key.
    Mine won't complete the reset process.
  16. Feb 12, 2017 at 4:12 PM
    #176
    gpb
    Atlanta
    Which TS version and were you telling it you had a 2026/17 Tacoma?
    11.10.034 Worked for me, set it as 2016 Tacoma and seemed fine on the reset.
  17. Feb 12, 2017 at 5:25 PM
    #177
    erok81
    Imposter
    Holy @&$# it finally worked.
    Once you get past the stressful part of erasing your stock keys (and it actually works) it's really easy.
    My problem burning through tokens was using a really old laptop with windows 7. So chrome didn't really work correctly. Once I ended up messing the captca up, no matter what I did it would say invalid token. After loading a fresh chrome page it worked fine.
    I don't know what my error was the first time where it stopped at 2 minutes (thankfully the stock keys still worked). The second go worked fine and now I have a nice flat key in my wallet. :cool:
    If anyone ends up with a used key I now have 4 tokens I can sell for 5 bucks each. :anonymous:
    Big thanks to @gpb for the help, being the guinea pig, and selling me most of his codes. :rofl:
    TA-5650 and gpb like this.
  18. Feb 12, 2017 at 5:32 PM
    #178
    delgross
    delgross Member
    Edward
    2017 TRD Off Road
    Mine keeps asking for a serial number. I thought Toyota allowed us to use this for free?
  19. Feb 12, 2017 at 5:47 PM
    #179
    gpb
    Atlanta
    Techstream? Not that I know of but it's reasonably easy to obtain a key for personal use. Have a look at the update I made to my post #160
  20. Feb 12, 2017 at 5:54 PM
    #180
    gpb
    Atlanta
    Congrats. I've really enjoyed the convenience of my credit card smart key. Grab my wallet & phone and I'm good. Has the added benefit of reducing the chance of leaving my wallet at home. :)
    I used an old T400 laptop onto which I'd installed Window 10, then use Windows 7 virtual machine from Microsoft with IE11 installed. I only use the VM for Techstream. The nice thing with VMs is the ability to snapshot a working install and be able to go back to it later if I should need. (FWIW I'd previously put an SSD in this laptop, so that probably helps it not be as slow as it would be with a HDD)
    See https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/
    http://www.itworld.com/article/2981...opers-download-our-free-virtual-machines.html
