lift option questions
Discussion in 'Suspension' started by Techy, Jan 7, 2013.
  1. Jan 7, 2013 at 2:06 PM
    Techy
    Techy [OP] Well-Known Member
    Montrose, CO
    06 trd off road dbl cab
    Alright I think I found what I am going to do. Bilstein 5100's all the way around. Set to 1.75 in front then spacer to bring the front up to 2.5". In the rear a 1.5" progressive aal from wheeler.
    So the questions...
    1. Should I do the front like described or skip the spacers and just set bilsteins to 2.5"? I hear they ride better at 1.75, hence the spacer idea to get to the desired 2.5".
    2. Will I need any other work like uca's with this setup? Trying to avoid that.
    3. Any other problems you guys foresee? Any other advice?
    Thanks for helping out a noob. I get so many great ideas and learn so much from all of you. I love getting on here.
  2. Jan 7, 2013 at 5:17 PM
    Techy
    Montrose, CO
    One other question, will this mess with my VSC? I have an 06 dc and there is no off switch for the vsc,, and I am not sure if a lift would mess with it.
  3. Jan 7, 2013 at 6:44 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Preloading ur offroad coils will provide a stiffer ride.....can u afford an OME setup?
    2.5 is right in the middle iirc for needing new UCAs.....some do, few don't I think.
    I know downsouth motorsports offers the complete OME line, and offer an ICON 1.5" progressive aal that's identical to the wheelers and rides like butter without the overload for sure....maybe someone here knows how it rides with the overload in.....tire pressures may help with ride differences also.
    I had a toytec/deaver 1.5" aal (single) and the back end hopped all over on bumps compared to the smoother articulation of the icon progressive.
    Again, check with Sonny at dsm.....free shipping, great prices, and the full line of OME.....u may have to CALL for the complete line cuz not all is listed on the website.
  4. Jan 7, 2013 at 7:14 PM
    Techy
    Montrose, CO
    How much would it be to use OME coils?
    And any estimates on how much uca's are if needed?
  5. Jan 7, 2013 at 7:18 PM
    Banff2007Tacoma
    Banff2007Tacoma Well-Known Member
    Dave
    Alberta
    2007 Tacoma Black Sand Pearl TRD Offroad.
    GPS Navigation System, Old Man Emu complete lift with Dakar springs. Light Racing UCA's. BFG AT tires, KMC Enduro rims, Allpro E-locker guard. ARB Portable Air Compressor CKMP12. Backflip Tonneau Cover. Wet Okole seat covers.
    You can get Light Racing UCA's from Fat Bob's Garage at a real good price. I believe for $379.
    I think they are worth it but you can always try without them and add them later. Good luck.
  6. Jan 7, 2013 at 7:26 PM
    BakerTaco
    BakerTaco Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    I got my whole OME setup for about $650
  7. Jan 8, 2013 at 8:42 AM
    Techy
    Montrose, CO
    Light racing better than those chaos arms?
  8. Jan 9, 2013 at 5:37 PM
    Techy
    Montrose, CO
    Any more info. I will take all I can get
  9. Jan 9, 2013 at 6:38 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Hellllll no. Total Chaos is twice the price though
  10. Jan 9, 2013 at 7:42 PM
    Banff2007Tacoma
    Dave
    Alberta
  11. Jan 10, 2013 at 6:13 PM
    Techy
    Montrose, CO
    anyone have any thoughts on spacers with 1.75" to get 2.5" vs strait 2.5"?
  12. Jan 11, 2013 at 5:10 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    spacers limit your travel and stress your suspension. If its strictly a street driver, I'd say knock yourself out.
  13. Jan 11, 2013 at 9:30 PM
    Techy
    Montrose, CO
    Dont I limit my travel by setting the 5100's at 2.5 though? Or does it only ride rougher?
  14. Jan 11, 2013 at 9:48 PM
    Taco Libre
    Taco Libre Well-Known Member
    JohnnyHildo
    Saskatoon, SK
    2008 Black 4x4 Access-Cab TRD OffRoad
    Rear TSB, 5100s @ 0, Toytec 3" lift, Total Chaos UCAs
    for the most part i've heard maxing out the 2.5 collar on the 5100's makes them rougher riding. for this reason you'll commonly find guys using springs like ARB's or Eibachs to supply the extra lift while they just use the 5100's for improved valving.
    spacers are generally frowned upon here yet many still rock them. my opinion, you bought a nice truck so you may as well try and retain the ride quality as much as possible.
  15. Jan 14, 2013 at 6:55 AM
    Techy
    Montrose, CO
    Are the eibachs, 885 I think for dc trucks, as good of a coil as the ones that come on a trd offroad truck?
  16. Jan 14, 2013 at 7:06 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    885s are OME, not eibach. define what you mean by "as good of a coil".
