Lift showed up ~ now I need tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shanran71, Sep 17, 2010.
  1. Sep 17, 2010 at 8:32 AM
    Shanran71
    Shanran71 [OP] Well-Known Member
    Shannon
    Springfield Mo
    08 4x4 Silver Off Road DC
    ARB front, All Pro rear, Hella's, Trail Gear sliders - welded on, 3" Sway-A-Way front & rear suspension, front mud flaps -gone.
    My OEM 2.5" full lift just arrived and I am stoked. I am installing it on a 2000 extra cab SR5. I have the stock steel 15" wheels (which I have spray-bombed flat black) that I plan on using.
    My question is what is the max tire size I should run on the stock steel wheels? I am hoping to run 32" or 33" tires, but the width is my issue.
    Any help on suggestions of sizes and recommended tires would be great.
  2. Sep 17, 2010 at 9:13 AM
    StatutoryAPE
    StatutoryAPE Well-Known Member
    Joey
    Phoenix,AZ
    2000 Prerunner xtracab
    TRD Headers,CAI, dynomax super turbo, blacked out headlights, Smoked LED tails, Billy 5100 w/OME 881's and 5125's in rear, rear tube bumper, tint 35% front 3 windows & 5% in rear 3. fiberwerx 4.5's
    i just got some 32x11.5 and the smallest width rim you can use on them is an 8 inch. if your wheels are stock they are probably 7 inch width, thats what my stock alloys were. i had 31x10.5 on my stock wheels, but thats the factory size tire im told.
  3. Sep 17, 2010 at 10:01 AM
    AlexanderD
    AlexanderD Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    stock tire is 31x9.50 i believe.
    you can get 33x9.50 r15's and they should fit just fin on those rims. you will likely have some rubbing though
  4. Sep 17, 2010 at 10:06 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    I would not go any taller than 32" tire, with a 2.5" suspension lift. The recomended rim width is different for each tire. I have seen 33" and 32" x11.5" R15 tires that could fit a 7"-10" wide rim. I do not know if the tire will hit the spindle where it mounts to the uca when you are running 11.5" wide tires when your are using your stock rims.
  5. Sep 17, 2010 at 11:08 AM
    AlexanderD
    Alex
    whitby Ontario
    thats kinda sad.
    i really wanted to put 33's om mine.
    i suppose i can live with my lowly 31 10.50's
  6. Sep 17, 2010 at 11:27 AM
    mauibuilt41
    mauibuilt41 Active Member
    Maui
    02 PreRunner Dbll Cab
    Go with the 32x11.50's. I believe the Double cab thread in the first gen section has pix of a few trucks with the stock 15x7 alloys and 32x11.50's. Try look it up or do a search for that tire size.
  7. Sep 17, 2010 at 9:11 PM
    Shanran71
    Shannon
    Springfield Mo
    Thanks for the input.
    I am considering some 33 10.50 BFG (narrow to avoid any spindle issue). My brother runs similar size 'pizza cutters' Cooper ST on his 2001 (3'lift) with no issues.
  8. Sep 17, 2010 at 9:23 PM
    mj918
    mj918 Well-Known Member
    Meg
    Wyoming
    2012 TRD Off Road Sliver
    3" Toytec Ulitmate Lift 285/70 Wrangler Duracturs 17" American Racing wheels TRD SUPERCHARGER!!! :) TRD Catback to come . . .
    I just got a 3" lift for my 08 and have 285/70/17 BFG All Terrians, with some trimming, I dont have rubbing issues at all!
  9. Sep 18, 2010 at 8:25 AM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    i just got a 3" lift and i was lookin to get 33x10.50 BFGs as well but idk i take my truck all over and im just not sure if they will tuck up into wheel wells
    anybody got any good pics? or advice? i really want 33s but if not i need to stick to 31s:(
  10. Sep 18, 2010 at 8:31 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    your also a 2nd gen
  11. Sep 18, 2010 at 8:39 AM
    ibengineer
    ibengineer Well-Known Member
    California
    00 Tacoma TRD 4x4
    Dirt Logic 2.5" Coilovers, Camburg UCA's, Icon 3 Leaf add-a-pack, billy 5100's in the rear, Custom front Plate bumper, XRC 8500 lb winch, lots of little mods
    I have 2000 4x4 sr5 with 3" lift and bfg 33x10.5 on stock wheels. check out my build page:
    http://www.tacomaworld.com/forum/1st-gen-builds/113530-ibengineers-build.html
    Its a pizza cutter look , but thats better imo. You get better gas mileage and torque (due to less rubber) and still get the clearance associated with larger tires. I did the pinch weld mod to gain a little extra clearance, but thats a 5 min job.
  12. Sep 18, 2010 at 8:54 AM
    TanSR5x4
    William
    Houston TX
    00 Tacoma SR5 4x4
    wow i just realized that
    holy crap that is a gorgeous truck:drool:
    but what about when it starts flexing and at full turn and whatnot? i wouldnt mind a bit of rubbing at like full turn but im just scarred its gonna tear shit up or something
  13. Sep 18, 2010 at 9:12 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    3" lift with 265/70/16 it doesnt look too bad
  14. Sep 18, 2010 at 9:13 AM
    kinkrider101
    santa barbara
    wheels and tires
    oh wait i just realized your a first gen!
  15. Sep 18, 2010 at 6:35 PM
    ibengineer
    California
    00 Tacoma TRD 4x4
    deleted post*
  16. Sep 20, 2010 at 7:33 AM
    mj918
    Meg
    Wyoming
    Yes, this is true.
