Light that will fit behind Grillcraft WO moving trans cooler
Discussion in 'Lighting' started by Benny, Sep 21, 2012.
  1. Sep 21, 2012 at 2:19 PM
    Benny
    Benny [OP] Well-Known Member
    2008 DC LB more mods by the month
    I see that many of you have lights mounted behind your Grillcraft or Satoshi grills. What are some good options to mount back there that don't require relocating anything? I want to add a Grillcraft to my 2008 Tacoma and mount 2 lights directly behind it. I am not interested in retrofitting the Hellas and not even sure if those will fit without moving the horn and transmission cooler. Thanks for the help. Hoping to have something worthy of a build page but for now am mostly stock........ :(
  2. Sep 21, 2012 at 3:51 PM
    09DBLCAB09
    09DBLCAB09 Well-Known Member
    Pretty no much matter what you do you will have to relocate your horns. Super simple tho
  3. Sep 21, 2012 at 3:53 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    You'll have to move both. You might be able to get away with it if you got a thin lip satoshi or grillcraft, and did some mock up on a light bar, but that would be more trouble than moving stuff. Moving the horns is easy as hell
  4. Sep 21, 2012 at 4:29 PM
    09DBLCAB09
    I have a 30" LED bar behind my grill and al I had to do was move the horns
  5. Sep 21, 2012 at 4:45 PM
    acdronin
    acdronin Well-Known Member
    Horns is really easy, I didn't relocate the tranny cooler inasmuch as I simple moved it further back to accommodate my lights using longer bolts and washers and such, really wasn't that hard. Order up a BAMF lightbar like mine and you're good to go. Dig through my gallery pics and you'll find my light install pics. If you plant to run only two lights you may not need to move the cooler at all.
  6. Sep 21, 2012 at 4:51 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
  7. Sep 21, 2012 at 4:52 PM
    acdronin
  8. Sep 21, 2012 at 4:53 PM
    Tioloco
    Tioloco Well-Known Member
    Richard
    Oakland Park, FL
    2012 PreRunner Sport
    TracRac G2, Xtrang Trifecta, ImMrYo Mirror Bracket, Konig Countersteer X Bronze, debadged, Custom grill/tailgate badges, Bilstein 5100's front, BAMF light bar, KC Slimlites, Redline hood struts, Smittybilt XRC8, UWMS, in-cab winch controls, Grillcraft MX, Brite Box
    Kc slimlights will fit, but as said, move the horns required
  9. Sep 21, 2012 at 4:56 PM
    acdronin
    I can't remember exactly where I mounted the horns, whether or not I used existing holes or drilled new ones, but I mounted mine on the other side of the radiator frame (meaning on the inside of the engine bay as opposed to the outside).
  10. Sep 21, 2012 at 5:17 PM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    I'm here for you, Chris. Anything else you need? ;)
    All of mine are on the outside, and I have a feeling I'll need to relocate the horns, once again, when I finally install a winch.
  11. Sep 27, 2012 at 8:26 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
