Lighting FAQ - Please Read Before Posting
Discussion in 'Lighting' started by Viet2100, Mar 30, 2010.
  1. Jul 15, 2010 at 6:35 PM
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    yeah shields are down. i read somewhere when on high beam the shield moves. it doesnt move at all. so could it be that its a single beam hid and they marked it hi/low by accident?
    also i have connectors that dont connect to anything..
  2. Jul 16, 2010 at 12:43 AM
    671taco
    Guam
    twenty-ten rc
    problem solved. went back to where i bought it and the lady had me swap out the 2 harnesses and gave me a single harness as well as the bulbs. gotta wait till dark to test them
  3. Jul 16, 2010 at 7:03 PM
    MBestrgr
    MBestrgr Well-Known Member
    Los Angeles
    2006 Black Crew Cab Tacoma SR5
    Working on it
    Great thread. Is there any instruction on how to install the LEDs in the gauges? Obviously I am going to have to pull some of the dash, but I don't even know where to start. Any help would be great thanks!
  4. Jul 19, 2010 at 12:05 PM
    HPaap72
    HPaap72 Well-Known Member
    NWest - PDX
    01 Tacoma
    KING 2.5 coil overs, deck plate, k/n, gray wire, driver, blue toothed kenwood
    i blew out my front turn signal on my 1st gen tacoma. i was considering replacing my front bumper with some form of grill. if i did so what do i do about turn signals. is it possible to wire the turn signal to the front parking lights maybe up by the headlight?
  5. Jul 19, 2010 at 12:23 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    just swap the wires around. if the lights in the lower bumper are your blinkers then run the wires from those into the lights beside your headlights.
  6. Jul 19, 2010 at 12:24 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    there is a link on the first post that will help
    http://www.tacomaworld.com/forum/lighting/35020-dash-mod-complete.html
  7. Aug 13, 2010 at 12:52 PM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    i'm thinking about installing HIDs in my factory headlights. i'm looking at a 35w single beam kit, what is the chance that they will damage my headlights?
  8. Oct 11, 2010 at 10:53 PM
    taco19
    taco19 Well-Known Member
    Dallon
    nelson bc
    2010 Trd sport sr5
    -Leveling kit - 18 fuel octane wheels on 275 toyo A/T -12" kicker sub with alpine deck - Blacked Badges -Fog Light mod -Gauge Blue cluster mod -Dynomax Catback exhaust
  9. Oct 16, 2010 at 7:32 PM
    awoit
    awoit Well-Known Member
    CA
    08 TRD, SR5
    How about installing LED lights for replacing the running light dual filament bulb? I'm looking for a plug n play simple bulb to fit so that when I turn on my DTRL they are brighter than the more dim one on the dual fill.
  10. Oct 19, 2010 at 7:53 PM
    awoit
    CA
    08 TRD, SR5
  11. Oct 30, 2010 at 9:42 AM
    twistax
    twistax Toyota Freak
    Carlsbad NM
    2017 Tacoma 4x4 Off-Road
    CaliRaised ditch mounts & Side Projecting pods
    "Can the Shifter labels be changed?
    Yes. the bulb is incandescent, but they used the good ol fashioned bulb condom here. So it can easily be replaced with a colored LED. "
    Anybody know what size right off hand?
  12. Oct 30, 2010 at 10:00 AM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    maybe a FAQ should be included here about installing HID's in stock reflectors?
  13. Jan 13, 2011 at 5:39 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    correct me if im wrong... is the 2011 tacoma model the same as the 2010, 2009? As far as headlamps, bulb type/size and what not.
  14. Jan 20, 2011 at 6:04 AM
    AsianAnts
    AnT
    is this forum alive or am i just posting in the wrong spot?
  15. Jan 20, 2011 at 6:09 AM
    #35
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    you're posting in the wrong spot. Go post a new thread in lighting.
  16. Feb 1, 2011 at 9:31 PM
    #36
    Average JOE
    Average JOE Well-Known Member
    San Diego
    PreRunner
    3'lift,Upgraded sound system,Dyanamat interior flowmaster,K&N,
    I "up-graded" to 6000k HID's in my BHLM. I don't like them. The light patern has weard angles and such. Plus I'm having a hard time with one or the other just cutting off. Then when I hit a bump it will turn back on. I'm using the DDM slims
    I'll be "re-up-grading" to HID FXR projectors from The Retro Fit Source. I'm not touching them untill then.
    I got the FXR kit in the mail. Now I'm just waiting untill I have the funds to have YOSH2000 do the converision for me.
    I'll post again with the pro's and con's after the re upgrade.
  17. Feb 2, 2011 at 6:22 AM
    #37
    AsianAnts
    AnT
    Just what we needed! a local member that is willing to install :D!!!!!!
    YOSH2000, i sent you a message.. im interested in your work :D
  18. Apr 19, 2011 at 8:48 AM
    #38
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    So is the front turn signal 3157 or 4157. There doesn't seem to be a 4157 bulb.
    Never mind, it's the same thing
  19. Jul 7, 2011 at 2:16 PM
    #39
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    which wire is the low beam wire on a second gen.
  20. Jul 21, 2011 at 3:15 PM
    #40
    tc399
    tc399 New Member
    Tom
    Hawaii
    08 Tacoma 4x4
    Sorry for being redundant - I just got around to installing the HID hi/LO kit. Where does the 3-prong plug go on an 08 Tacoma? The box and instructions are long gone.
