Lock, Stock, and 2Wheel Low (3rd Gen DIY Mod)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigWhiteTRD, Mar 1, 2018.
  1. Apr 4, 2022 at 12:18 PM
    #201
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    can I just use a little splicey splice for that or do I need to take out the ground wire entirely and run a split line into there?
    BigWhiteTRD[OP] likes this.
  2. Apr 4, 2022 at 2:45 PM
    #202
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    You can cut the ground wire and attach the ill- wire to the switch side of the harness. It is not a splice. The wire going to the relay will no longer be needed.
  3. Apr 4, 2022 at 5:07 PM
    #203
    Stormpeacock
    Rich
    Atlanta, GA
    19 Cement Offroad
  4. Oct 18, 2024 at 11:30 AM
    #204
    Jtaco78
    Jtaco78 Active Member
    Jeremy
    Silver 2021 TRD offroad
    I bought my 2021 used and it had this mob installed by previous owner. Everytime i try to use it i get an error message. I've tried the steps in a few differnt orders but still get an error
    Pablo8 likes this.
  5. Oct 18, 2024 at 11:41 AM
    #205
    lapoltba
    CT - 06076
    If you have a 2Lo specific visor card, please reference that. The method for getting into 2Lo is identical to 4lo with the exception of pressing your 2lo switch first. When you press the switch you should hear an audible click from the relay.
  6. Oct 18, 2024 at 4:34 PM
    #206
    BigWhiteTRD
    BigWhiteTRD [OP] Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    In addition to above guidance, firstly can you get 4lo to work correctly? (Without touching 2lo mod at all)
  7. Oct 28, 2024 at 7:27 PM
    #207
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I wanted to chime in here with a recent discovery. I’ve bought numerous 2Lo harnesses, some for normal use and some for experimentation with deleting the ADD and solving the problems that occur with manual transfer case. It’s a great kit for sure, especially for guys with manuals needing to back a trailer. I realize this is not the thread for the kit itself, but since it’s the development thread, I figured I’d chime in here.
    I did have one thing I didn’t like about the kit, which was the failure message you get if you go out of order on the switch & knob, when returning to 2H. In other words, turning the knob back to 2WD before unclicking the 2L switch.
    I did some testing and learned that if you snip the relay ground and splice it to pin 13 of connector F13, you will have no more failures if you go out of order. What this does, is it controls the ground side of the relay with the 4WD request signal from the knob. This request signal is available in both 4H and 4L, and goes away when the knob is turned back to 2WD.
    Essentially, this means that if you enable the 2L switch, then no matter what position you turn the knob to, you’ll always be in 2WD, and can keep switching back and forth between all 3 transfer case modes with no problem at all.
    If you want 4WD, then you’d simply operate the knob as normal, with the 2L switch not pressed. Since most of us probably drive on the street, this means you could leave the 2L switch enabled as long as you like for quick switching in and out of 2L, whenever you want to just quickly turn the 4WD knob.
    It took me about 20 minutes to make the snips and the crimps to tweak it. Very happy with the results.
    Ninestar, Fireme, RushT and 5 others like this.
  8. May 31, 2025 at 11:20 AM
    #208
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Is there any way to implement a quick switch between 2lo and 4lo without having to stop and do a low/hi switch?
  9. May 31, 2025 at 11:25 AM
    #209
    BLtheP
    Plano, TX
    You’d have to control the ADD separately, and there is no easy way to do that because the computer controls it and manages it with limit switches.
    The 2L kit is simply bypassing the ADD before you go into Lo. To control the ADD while in Lo would be a different ballgame.
    Pablo8 and deusxanime like this.
  10. Jun 1, 2025 at 8:21 AM
    #210
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I’d think that would be mechanically inadvisable. Are there other vehicles that can do that?
  11. Jun 1, 2025 at 8:25 AM
    #211
    BLtheP
    Plano, TX
    There aren’t any vehicles that can do 2L from the factory regardless, except for those from the 90s and earlier that had locking hubs.
    The only thing that makes 2L happen is the ADD. To go from 2L to 4L you would just work the ADD. But there is no easy way to do that.
  12. Jun 1, 2025 at 8:38 AM
    #212
    RushT
    North Texas
    I was thinking about the transition from Hi to Lo, regardless of 2vs4. I thought the transition from Hi to Lo (or Lo to Hi) required very low gear speeds else bad things happened.
  13. Jun 1, 2025 at 9:03 AM
    #213
    Mach
    Yes but I am wanting to be able to switch between 2 and 4 in low so without the high low switch that you are supposed to be in neutral for.
    It works in high and is just switching the ADD so theoretically I would think would be possible. The problem is if you can't tell the ECU to do the switch then you would need to create a new system to do it.
  14. Jun 1, 2025 at 12:28 PM
    #214
    RushT
    North Texas
    Looking back, I totally misread the ask… I was thinking you wanted to go from 2hi to 2Lo without the obligatory stop. I’ll go back to things more my speed like mowing the lawn now. :rofl:
