Looking for a 4" or 5" lift kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CTacoma, Sep 6, 2011.
  1. Sep 6, 2011 at 5:39 PM
    CTacoma
    CTacoma [OP] Member
    I'm looking for a solid 4 or 5 inch lift for a 2nd generation tacoma. I would prefer that it be a full suspension lift, not a spacer or anything. I've been looking all over for a way to lift 4 or 5 inches..i don't know if they make a full lift kit thats a 4 or 5 inch, or if i have to get a few different things in order to make it work, I'm fairly new to this kind of stuff
  2. Sep 6, 2011 at 5:45 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
  3. Sep 6, 2011 at 5:46 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    4x4 or prerunner?
  4. Sep 6, 2011 at 5:54 PM
    CTacoma
    CTacoma [OP] Member
  5. Sep 6, 2011 at 5:54 PM
    CTacoma
    CTacoma [OP] Member
    4x4
  6. Sep 6, 2011 at 6:07 PM
    CTacoma
    CTacoma [OP] Member
  7. Sep 6, 2011 at 6:08 PM
    trdtaco10
    trdtaco10 Well-Known Member
    Fayetteville, NC
    '10 TRD OR 4X4
    UWS toolbox, window tint, Bilstein 5100s on all four corners, black 16" TRD FJ wheels, 14" Shorty Antenna, Weathertech all weather floor liners, Satoshi Grill Mod, Rear leaf TSB, OME 885x's, Desert Racing UCAs, Icon 3 leaf AAL
    Wheelers Offroad or Downsouth Motorsports sells them...i want to say around 1700-2000
  8. Sep 6, 2011 at 6:12 PM
    CTacoma
    CTacoma [OP] Member
    thats expensive dude, cheapest i found it for was like 2100, anything a little cheaper?
  9. Sep 6, 2011 at 6:18 PM
    KPT
    09 Prerunner
    There no inexpensive way to get over 3" of lift except for a body lift in combo with suspension.
  10. Sep 6, 2011 at 6:19 PM
    hamNswiss on rye
    hamNswiss on rye ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
    you could get a clean 3" out of the OME kit for $699
  11. Sep 6, 2011 at 6:20 PM
    CTacoma
    CTacoma [OP] Member
    yeah, how much could i do a body lift with a suspension lift for
  12. Sep 6, 2011 at 6:41 PM
    rsbmg
    Rob
    Vista,CA
  13. Sep 6, 2011 at 6:48 PM
    CTacoma
    CTacoma [OP] Member
    i got the link to work, i wanna do a 5 inch lift, and the rdc is like 2100, but i could do a 3 inch suspension, and then like a 2 inch body, for around 1300?
  14. Sep 6, 2011 at 6:57 PM
    rsbmg
    Rob
    Vista,CA
    Probably a little less than that but your safe at 1300. Your BL will be a special order from Roger Brown unless you want to make your own. I have no idea why you want a 5 inch lift but since this is your first post you may not have read through this site all that much. I suggest you spend a little time reading on here and other sites before taking the plunge into what you think you want right now. You may change your mind after you educate yourself a bit. It will save you time money and heartache down the road. At least make sure what you think you want is really what you want.
  15. Sep 6, 2011 at 7:01 PM
    CTacoma
    CTacoma [OP] Member
    well i want something a little more then a 3 inch lift which from what i see is a pretty standard lift for a tacoma, and the 6 inch too much cause I'm only doing 33s, and I saw this guy, http://www.tacomaworld.com/forum/2nd-gen-builds/66059-solus694s-build.html , has a 4-5 inch lift but i don't how he's done it
  16. Sep 6, 2011 at 7:07 PM
    rsbmg
    Rob
    Vista,CA
    Its in his post
    Suspension
    RCD 4"-5" drop bracket lift kit
    - TRD Off-Road coils
    - Bilstein extended length shocks (front and rear)
    - 4" Block (ugh)
    TSB Leaf pack
    Light Racing Upper Control Arms
    Well over $1300.00
    Save your money and keep saving while you research. By the time you have spent as much time as you should reading (6 months +) you may have enough saved and have changed your mind on what you want. Just a suggestion. Don't be in a rush to get a lift on you will end up piecing together a frakenstein and wont be happy with it.
  17. Sep 6, 2011 at 7:08 PM
    loaderman82
    loaderman82 Well-Known Member
    Dalton
    Flippin, AR
    2008 Off-Road
    If you read down below the pictures he tells you what lift is on his truck.
  18. Sep 6, 2011 at 7:49 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Body lifts suck.
  19. Sep 6, 2011 at 8:52 PM
    rsbmg
    Rob
    Vista,CA
    Wrong.
